Old Sep 30, 2014, 03:37 PM
mandevil's Avatar
Joined Jun 2011
Originally Posted by u2builder View Post
Had pretty much the same thing happen with a similar sound. Turns out in my case it was a bad bullet connector or bullet connector solder joint so the motor dropped one of its 3 phases. I identified which connector was bad and replaced it. Worked fine. Obviously there are other possibilities like a seized bearing or a loose magnet.
Here it's really seized up, the motor won't yield when the prop is pushed by hand (should rotate fairly easily). I had a badly soldered connector on a Bixler and the symptoms were somewhat similar, so I tried to restart it once or twice during the flight.
mandevil is offline Find More Posts by mandevil
Old Sep 30, 2014, 03:39 PM
mandevil's Avatar
Joined Jun 2011
Originally Posted by PianoMan View Post
We wilIn the MEANTIME, however, our Turnigy 9X's with er9X firmware and the FrSky module/receiver are ROCK SOLID. So I'm pretty happy with FINALLY getting NO glitching. I tested it all week (so far only in my Bixler 1.1...but will test with the SSS soon) and it was completely and utterly glitch-free. So I'm a HUGE new fan boi of anything made by FrSky. Great stuff!
FrSky beeps a lot when I get into some not so big distance, not sure if it's just conservative. Previously I flew a rock bottom cheap HK 6-channel radio and never ever had slightest problem, not even at 700-800 m distance.
Old Sep 30, 2014, 04:43 PM
United States, DE, Wilmington
Joined Apr 2010
Originally Posted by BigIron357 View Post
Hi all, I'm very interested in this plane for doing some casual AP and have been slowly reading the entire thread for the last couple weeks.
Right now I'm on page 158 and for the last dozen or so pages I've been reading about an in flight catastrophic failure on chanyote66's plane where the top part of the fuselage which holds the wing in place just came off unprovoked!
And I've been reading about possible reinforcements and workarounds, etc. but the information is nearly 2 years old now.
Have there been any more reports of the fuse breaking up in flight? Is the current version of the SSS stronger? I was planning on getting the kit version so that I could run some wires inside for lights, etc. And also to allow some customization.
Did chanyote66 ever figure out exactly why his fuse broke apart in mid-air? Like unseen damage from a prior crash or high stress aerobatics, etc?
Thanks for any info!
Hello,
I have been flying my SSS for over a year now. My SSS is my short/medium range (2-3 Miles) FPV aircraft. would go longer range but I dont have enough battery power to go LONNG range. I fly this as a airliner style as much as possible. smooth and gentle and it does fly very stable inherently. Level flight with gentle turns. although it will turn sharply with no trouble at all. I have heard about the weak wing saddle so I decided never to do loops , rolls or pull and high G maneuvers. I have reinforced the wing saddle the best I could with extreme packing tape and all seems very solid to date. I do check periodically the wing saddle for any issues but all seems good so far. I upgraded the wing spar with the hollow carbon fiber tube to save weight. The wing still fits very tight . I know there are many very good fpv models out there but the SSS when treated with TLC has proven to hold up well. Hope this info helps.
coa106 is online now Find More Posts by coa106
Old Oct 19, 2014, 11:14 AM
25+ years of RC flying
BigIron357's Avatar
United States, FL
Joined Aug 2012
Originally Posted by coa106 View Post
Hello,
Thanks for the reply. Sorry it took me so long to catch up.
I finished reading the whole thread though! Am still considering this plane as my aerial video platform. Maybe I'll treat myself with a purchase before the end of the year. And I also read about the Nitroplanes version; seems to have a couple of neat features too.
Still researching...
BigIron357 is online now Find More Posts by BigIron357
Discussion Banana Hobby BlitzRCWorks Sky Surfer JoshB Electric Plane Talk 12 Feb 14, 2012 11:01 PM
Found Looking for BlitzRCWorks Sky Surfer Airframe Only or Wing Set cutty01 Aircraft - Electric - Airplanes (FS/W) 0 Aug 16, 2010 03:16 PM
Discussion BlitzRCWorks Sky Surfer Aerobatic Flench Beginner Training Area (Aircraft-Electric) 4 Feb 13, 2010 03:17 PM
Discussion sky surfer powered parachute $29.95 w/ Free shipping interplanet Hot Online Deals 26 Dec 30, 2008 10:58 PM
