Old May 22, 2010, 11:21 PM
Res Ipsa Aviatur
Longhorne's Avatar
Sonoma County CA!
Joined Jul 2007
Build Log
30" Nakajima Ki84 Hayate (Frank)
Cg note: after flying this design a bit I have moved the Cg point forward from where it is noted on the earlier plan drawings (Rev A). 40mm back from the root LE is a better starting point. Rev B drawings show the Cg in this new location
Next up on the scratch build docket is a 30" stick and tissue type playmate for the Wildcat. After reviewing a number of Japanese fighters, I gravitated toward the Ki84 because its proportions lend itself to RC a bit better than the rest. The nose is a little longer for ease of Cg placement, and the wings are long and fairly straight. Plus its a really sleek looking ship.
Technically, the Hayate didn't really become operational until 1944 and by that time the Wildcat was not much of a match. As a result, I doubt that the two ever met in combat but Bosley has already locked up a really nice Zero so here we are.
My understanding is that the Ki84 was a heck of an airplane. The US Army evaluated a captured copy and determined that it was more than a match for the P47 if the Japanese could get enough high octane fuel to feed it. Additionally it was plagued with quality problems in its metallurgy manufacture. In the end 3500 were built and they were respected by Allied pilots.
Longhorne is offline Find More Posts by Longhorne
Last edited by Longhorne; Oct 20, 2012 at 11:32 PM. Reason: Added Cg note, made Cg note more obvious
Old May 23, 2010, 08:15 AM
It flew once before...
jofrost's Avatar
Northwood , New Hampshire
Joined Jul 2004
Silently and eagerly watching !
jofrost is offline Find More Posts by jofrost
Old May 23, 2010, 08:54 AM
bosley's Avatar
United States, CA, Twentynine Palms
Joined Jun 2002
looky looky!!!!
Jeff
bosley is offline Find More Posts by bosley
Old May 25, 2010, 12:57 AM
Res Ipsa Aviatur
Longhorne's Avatar
Sonoma County CA!
Joined Jul 2007
Framing is done
John--I was hoping to lure you into my little web here.
Bosley, you had my son and me cracking up!
So here's the basic layout: lightweight 1/16" formers and keels with plenty of stringers. The wing will be removeable and there will be a small batt hatch between the upper cowling and canopy. The cowling, canopy, and chin scoop will be vacuum formed.
Now to get the cut files squared away.
Paul
Old May 25, 2010, 08:03 AM
danrc's Avatar
Rockford Illinois
subscribing to this one!
danrc is offline Find More Posts by danrc
Old May 25, 2010, 09:06 AM
Neophyte hacker
portablevcb's Avatar
Albuquerque, NM USA
Joined Sep 2003
Not sure about exact shapes, but...
Bosley has some nice plastic parts for the Zero that Sparky makes. Cowl, canopy, gun 'bumps' and spinner. Wonder if using those might make your life easier.
charlie
portablevcb is offline Find More Posts by portablevcb
Old May 25, 2010, 09:16 AM
D-Rock's Avatar
Phoenix, AZ
Very cool, looking forward to seeing this one progress- subscribed.
D-Rock
D-Rock is offline Find More Posts by D-Rock
Old May 25, 2010, 09:52 AM
Fly, dangit!!!
Led Zepplin's Avatar
Little Rock, AR USA
Joined Jan 2007
Loving the beautiful modeling! Best of luck!
J. B.
Led Zepplin is offline Find More Posts by Led Zepplin
Old May 26, 2010, 05:55 PM
roscoedude's Avatar
United States, OH, Cuyahoga Falls
Joined Oct 2006
Cool Paul, one of my fave Jap planes... kind of a Japanese version of the P-47 Thunderbolt....
Subscribed,
Dean
roscoedude is online now Find More Posts by roscoedude
Old May 27, 2010, 12:34 PM
Res Ipsa Aviatur
Longhorne's Avatar
Sonoma County CA!
Joined Jul 2007
Moving into the Building Phase
Charlie--thanks for that. I've been mulling Bosley's gear over too, but everything on the Hayate is a bit different but maybe the spinner. Might be able to massage the cowling by adding the characteristic carb scoop, but the canopy is pretty far.
Now that the cut files are done and plan drawing is roughed out, I'm happily headed out to the shop. Seems like a long time! First on the hit list is to get the forms made for the laminations. These were cut from 1" styrofoam on a scroll saw with fine blade. The styrofoam is a little soft but its easy to work with and once its faced with thick packing tape its rigid enough to do the trick.
Have fun,
Paul
Old May 27, 2010, 02:48 PM
Joined Sep 2005
Love the 'Frank'
Paul, as you can see the Ki-84 is one of my favs!! Good luck on this build-hope to see it in the air soon.
Best wishes,
Dale
Ascolta is offline Find More Posts by Ascolta
Old May 27, 2010, 03:19 PM
Res Ipsa Aviatur
Longhorne's Avatar
Sonoma County CA!
Joined Jul 2007
Dale--nice! I just looked at an Alfa kit that my buddy is in the middle of building and it looks like a nice construction. Just a little bigger than this one.
The paint scheme on your plastic model is exactly where I'm headed. Was that modeled from a particular aircraft?
Thanks!
Paul
Old May 27, 2010, 05:09 PM
Pile-it
Alien_Tech's Avatar
United States, CA, Palmdale
Joined Nov 2007
Any framing done yet?
Alien_Tech is offline Find More Posts by Alien_Tech
Old May 27, 2010, 05:43 PM
Joined Sep 2005
Paul, that was a long time ago, but I believe the decals supplied in the kit were of a specific aircraft.
Dale
Old May 27, 2010, 08:10 PM
D-Rock's Avatar
Phoenix, AZ
Paul, very nice design work, clean and efficient. Looking forward to seeing balsa flying .
D-Rock
Sold Alfa Nakajima Ki.84a "Hayate RTF Mikemynameis Aircraft - Electric - Airplanes (FS/W) 16 Oct 02, 2006 07:28 PM
Sold Alfa Nakajima Ki-84a Hayate RC Plane Brushless Electric gliders Aircraft - Electric - Airplanes (FS/W) 2 Sep 27, 2006 04:06 PM
Alfa Nakajima ki-84a Hayate CUBANO8 Parkflyers 24 Jun 26, 2005 09:04 PM
wtt alfa Nakajima Ki.84a "Hayate" ARF for leki kissfan Aircraft - Electric - Airplanes (FS/W) 4 May 02, 2005 03:21 PM
Alfa Ki84 Hayate has arrived at US! shschon Parkflyers 53 Dec 30, 2004 11:13 AM
