Old Oct 15, 2014, 08:40 AM
Joined Feb 2013
Help!
Efuel 30a power supply (please help)
I bought this power supply about a year ago and its starting to act up. When I plug it in it shows me 19.8-19.9 volts on the display and my icharger goes into over voltage protection. Is there anything i can check or do to make this power supply work correctly again. Please let me know if you need ferther info.
scotthowell17 is offline Find More Posts by scotthowell17
Old Oct 15, 2014, 09:32 PM
Wintr's Avatar
USA, MO, Florissant
Joined Nov 2010
The internal feedback that regulates the voltage has failed; could be a bad solder joint, or a component failure. But, without a schematic, that's where my knowledge ends.
Wintr is offline Find More Posts by Wintr
Old Oct 15, 2014, 10:09 PM
Joined Feb 2013
Thanks for the reply. It's kinda weird sometime when I plug it in it works fine then when I put a bigger load on it, it goes to a higher voltage. Other times it just starts off high and stays there.
Old Oct 16, 2014, 07:40 AM
United States, FL, Orlando
Joined Oct 2013
A while ago, someone had a similar problem with a Hobbyking power supply. He opened it up and fond that the potentiometer that adjusted the voltage had developed a rough corroded spot which caused the voltage to go crazy. He turned the pot a bit to a different spot and it started working fine again.
CerealKiller159 is offline Find More Posts by CerealKiller159
Old Oct 16, 2014, 08:28 AM
Joined Feb 2013
I'll try cleaning it thanks for the reply.
Old Oct 16, 2014, 04:16 PM
Joined Feb 2013
I gave that a try and it's still the same no difference.
Wanted Wanted ,Power efuel supply , eFuel 1200W 60A 15V-24V Adjustable Airplane,Ed Aircraft - Electric - Batteries & Chargers (FS/W) 1 Feb 13, 2014 08:39 PM
Sold eFuel 540W 30A 9V-18V Adjustable Power Supply vr360 Aircraft - Electric - Batteries & Chargers (FS/W) 0 Jan 06, 2014 02:56 PM
Sold eFUEL switching DC Power Supply 1sicknickel Aircraft - Electric - Batteries & Chargers (FS/W) 0 Oct 07, 2013 03:53 PM
Sold eFuel 540W 30A 9V-18V Adjustable Power Supply lmpbpd Aircraft - Electric - Batteries & Chargers (FS/W) 0 Apr 06, 2013 05:35 PM
Sold eFuel 540W 30A 9V-18V Adjustable Power Supply Capt. Roll Aircraft - Electric - Batteries & Chargers (FS/W) 0 Mar 05, 2013 07:56 AM
