Old Oct 12, 2014, 11:20 PM
Loose Sox Special Spec
LooseSox's Avatar
Australia, SA, Modbury North
Joined Feb 2012
PL6 issue?
Hi guys,
I've got an intermittent issue on both of my PL6 units I'm hoping you could shed some light on for me.
Ok so basic operation is push yes to confirm lipo, it sits there for 30-40 seconds then the charge cycle begins. Occasionally after confirming lipo, both my chargers will 'hang' I guess you could say? After 5-10, and sometimes I've left it run over 15 minutes the charge cycle still hasn't begun. This has happened on accurate, fast and high power modes. When the issue does present itself, I cancel the charge, go through the menus and start again. Sometimes this works, sometimes it happens over and over until I turn the chargers off and come back a couple hours later and it's all good again.
Any ideas on what might be wrong or what I could be doing differently?
LooseSox is offline Find More Posts by LooseSox
Old Oct 13, 2014, 12:30 AM
Seattle
Joined Sep 2007
What power supply are you using? Have you noticed if it only happens when both chargers are running? Or does it also happen when only one charger is connected to the supply?
Gregor99 is offline Find More Posts by Gregor99
Old Oct 13, 2014, 02:49 AM
LooseSox's Avatar
Joined Feb 2012
I'm using a ProtekRC 60A power supply. Both chargers are run off the one supply. They are not always necessarily in use when the issue presents itself but they are usually both powered on. The funny thing is if it happens on one charger, and I swap the MPA and batteries to the other charger, odds are good the issue will be there too.
Can I assume you're thinking a possible power supply issue? I had the same issue with my original PL6 with my old power supply before getting the second PL6 and larger power supply.
Old Oct 14, 2014, 12:43 PM
Seattle
Joined Sep 2007
During the initialization phase of the charge cycle, the charger is matching the input to the output. Normally this takes about 40 seconds. If DC supply fluctuates the input/output matching may have trouble locking in.
In your case I would try varying the supply voltage. Since its easily adjustable on that supply, I would start with 20v. If that helps the issue, increase to 22v. I would not run that supply at 24v when charging 6s packs. Running at 22v-23v will help keep the charger's DC-DC converter out of the buck-boost oscillation range.
Old Oct 14, 2014, 01:40 PM
LooseSox's Avatar
Joined Feb 2012
Ok I'll give that a try. I only charge 3S and 4S packs, as I currently don't own any 6S batteries at present.
Discussion Possible Revolectrix PL6 issue? LooseSox Batteries and Chargers 0 May 24, 2014 04:13 AM
Discussion PL6 regen discharge issue tsymonds Batteries and Chargers 3 Apr 12, 2014 07:01 AM
Discussion iCharger, Hyperion, PL6... juliend Batteries and Chargers 17 Nov 13, 2013 10:04 AM
Discussion PL6 and NiMh batteries Stikflyer FMA Direct 6 Nov 01, 2013 05:55 AM
Discussion PL6 issue? JGrn Batteries and Chargers 5 Apr 09, 2013 12:27 PM
