Old Sep 20, 2014, 09:24 AM
Joined Jun 2014
Question
servos malfunction at full power
When I launched my AXN Floater Jet glider, it flew normally at first, but when I applied full power the servos(s) went nuts and it went out of control. When I backed off on the throttle, I regained control and it flew normally. I brought it up to altitude and tried full throttle again, and again it flew out of control. I again backed off on the throttle, regained control, and landed it normally. Does anyone have an idea what it could be? I'm guessing the ESC is bad. it's a fresh 2200 3S battery JG and a 30 amp speed control with 3 amp BEC. JG
JGallo is offline Find More Posts by JGallo
Old Sep 20, 2014, 10:42 AM
Y=C+I+G
cmdl's Avatar
United States, CA, Rosemead
Joined Jan 2012
yes, its an ESC issue - brad baker had the same problem here: http://www.rcgroups.com/forums/showt...441528&page=28
changing ESC should fix it.
cmdl is offline Find More Posts by cmdl
Old Sep 20, 2014, 01:16 PM
Joined Jun 2014
Thanks for the input. I'm thinking that when I apply full power, it robs the BEC, which supplies power to the servos. I'll replace the ESC. JG
Discussion full power at 60% on throttle stick on dx8.... lucasislost Electric Plane Talk 4 Aug 19, 2014 09:38 AM
Discussion Engine stuck at full power. Video of the save. Shung Fuel Plane Talk 18 Jul 17, 2014 08:29 PM
Help! Mini cp loses power at full throttle yomar Micro Helis 19 Jul 15, 2014 09:34 AM
Discussion "Two props running at half power produce more thrust than one prop at full power" noobflyer92 Modeling Science 17 Jul 11, 2014 05:44 PM
Discussion Wanted - howto modify servo to limited +-30 degrees at full 1000-2000us resolution? hamburger Multirotor Electronics 4 Jul 06, 2014 03:04 PM
