Old Sep 06, 2014, 02:50 PM
Joined Aug 2013
most efficient brushed rc boat motor
Hi guys
what type of brushed motor is the most efficient?
Im trying to get the longest run time on a scale boat
Using a nihm battery
the longest run I can think of is like the set up on my bristol bay
2 hours with a 5000nihm battery?
Please dont say brushless
thanx
hardrive is online now Find More Posts by hardrive
Old Sep 06, 2014, 03:12 PM
"MAYONNAISE"
Acetronics's Avatar
Le Treport, France
Joined Jun 2004
simple ...
you just have a look to the efficiency curves for your motor, and try to run it as close as possible to the best values ( ... )
that mean choosing carefully your propeller(s) pitch and diameter ... and even use variable pitch ones !!!
Brushless or not: same tweaking !!!
Alain
Acetronics is offline Find More Posts by Acetronics
Old Sep 07, 2014, 07:28 PM
Joined Nov 2007
As Acetronics said, you have to run at the peak of the efficiency curve. Here is a typical spec sheet:
http://www.jameco.com/Jameco/Products/ProdDS/232022.pdf
Note that the efficiency curve has a narrow peak and you have to hit the best RPM very close. Brushless motors also have a narrow peak.
mjsas is offline Find More Posts by mjsas
Old Sep 08, 2014, 04:47 PM
We want... Information!
Bruce Abbott's Avatar
Hastings, New Zealand
Joined Jan 2001
Don't over-power the model. Use a small motor with gearbox (3~4:1 ratio) and run the largest prop you can. The prop should have low pitch and large blade area to maximize thrust. Use an ESC with high rate PWM (3KHz+). Make sure that your running gear operates smoothly (couplers lined up, bearings well greased etc.).
People often use a large, low Kv (high voltage) motor direct drive, but this is an inefficient setup because at low speed the motor wastes a lot of power just turning itself over, and at high speed the motor's high armature resistance also wastes power.
Here's a freighter that I set up for a friend. He put three 12V 7Ah SLA batteries in it just for ballast, but it runs for hours on a single 6V 3Ah battery. The power system is a Speed 280 6V geared 4:1, driving a 50mm 4 blade brass prop. It achieves scale speed at 1/2 throttle.
Bruce Abbott is offline Find More Posts by Bruce Abbott
Old Sep 12, 2014, 02:39 AM
Joined Aug 2013
Thanx guys for replying
Bruce do you think maybe you could help me on a good motor set up for this historic boat
thanx
Old Sep 12, 2014, 02:40 AM
Joined Aug 2013
43 inchess in length
And 5 inches wide
For the hull
Discussion Most efficiency motors for Quadcopter under 800 grams without drive phoanglong Multirotor Talk 0 Jul 30, 2014 11:16 PM
Discussion What motor is most efficient I14R10 Multirotor Power Systems 3 Jul 15, 2014 10:55 PM
Question Most efficient prop for a given motor Armyguy8675309 Multirotor Power Systems 4 Mar 23, 2014 05:06 PM
For Sale Boat Load of Brushed ESCs, Gearboxes & Motors rctinman Aircraft - Electric - Power Systems (FS/W) 1 Nov 03, 2013 11:32 AM
Discussion most efficient speed 400 brushed motor kogibankole Electric Plane Talk 10 Apr 23, 2006 05:12 AM
