Old Dec 01, 2013, 06:31 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
does it have retracts,and flaps?
AIR SALLY is offline Find More Posts by AIR SALLY
Old Dec 01, 2013, 06:38 PM
kremecheze's Avatar
United States, AR, North Little Rock
Joined Jun 2007
Yea it retracts and split flaps, there having a cash and carry sale this week for 99$ so I may take a drive down and a few up as spares
kremecheze is offline Find More Posts by kremecheze
Old Dec 01, 2013, 06:41 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
Wow sounds like a good deal ...widh i was closer
Old Dec 01, 2013, 06:48 PM
Scale Dail's Avatar
United States, CA, Santa Clarita
Joined Mar 2013
Oops! Wrong thread
Scale Dail is offline Find More Posts by Scale Dail
Old Dec 01, 2013, 07:48 PM
United States, FL, Altamonte Springs
Joined Jun 2012
Almost ready to maiden mine... will Hysol bits and bobs. Should I use the manuals CG? Any adjustments to it?
EDIT: CG is 1.3" forward the main spar. I know the panthers have a forward CG, but that's nearly where the grey paint meets the yellow. Unless I am mistake. What's the CG measured from the LE from the intakes?
May change the wheels to MPI aluminum wheels... I had these lying around.
voxel is offline Find More Posts by voxel
Old Dec 01, 2013, 08:42 PM
kremecheze's Avatar
Joined Jun 2007
i would maiden her a little nose heavy to be on the safe side
Old Dec 02, 2013, 12:43 AM
jefffassbinder's Avatar
United States, CA, Los Alamitos
Joined Jan 2011
Panther and Cougar
Does anyone have any videos of flights with the Cougar and Panther. I would pick both up. But want to see some flights. Also how is the weight on these models. I would put a JF 90mm 12s 3300. Works great in a few of my other 90mm setups.
Well if you have any photos and or videos please put some links. I saw someone say a sale. I checked the website didn't see a sale. If they are readying the thread can I save some cash by purchasing two models on shipping??
Well be interested in the weight compare to model I currently have of the Panther.
jefffassbinder is offline Find More Posts by jefffassbinder
Old Dec 02, 2013, 02:00 AM
Paul5910's Avatar
USA, TX, Houston
Joined Jul 2002
Good luck on you maiden voxel! I am looking forward to hearing back from you.
Paul
Paul5910 is offline Find More Posts by Paul5910
Old Dec 02, 2013, 08:21 AM
Joined Jun 2012
My dry weight is just under 3.2kg. The 9s (3 x 3700mah) lipos I plan to use are 924g - although it appears I need heavier lipos to get the CG right... maybe one or two 5000mah.
ExtremeRC JetFan 90mm (10s) alloy unit
Eflite 25-46
Castle 120HV
Hitec 85mg everywhere
Old Mar 28, 2014, 07:21 PM
Stay Thirsty My Friends
swarick's Avatar
USA, AZ, Gilbert
Joined Mar 2005
Any updated flights on this jet? Just started working on mine.
swarick is offline Find More Posts by swarick
Old Mar 29, 2014, 01:46 AM
United States, CA, Palm Desert
Joined Jan 2009
new news
any new updates on this easytiger panther. I'm planning on putting one together soon with retracts and a 8s etremerc fan with wemo evo 11 blade that puts out approx. 9 and 1/2 lbs of thrust. Sounds good right? On a 1 to 10 how would you guys that have built these jets, rate it? thanks for any info and wise tips on its construction. thanks, Stephan
stmbike is offline Find More Posts by stmbike
Old Mar 29, 2014, 02:06 AM
Joined Jun 2012
Haven't maidened it yet. LOL. After the holidays I got the FPV bug baaad so the jets went into hibernation and now my panther needs a better battery tray to hold 10s. On 8s, it's an insane amount of power already. Can't imagine on 10.
I also have the CMP t45 (built) and the CMP Cougar (half built). All need hysol here and there. The CMPs definitely need carbon tow in the intakes. Also started the ProDesign Mig 15 a few days ago after finishing the foamy Exceed mig 70mm (with extra weight for practice).
Old Mar 29, 2014, 10:03 AM
Joined Jan 2009
new news
Old Mar 29, 2014, 01:42 PM
United States, TX, Highland Village
Joined Mar 2010
Wing loading is high with retracts and 8s.
You will definitely need the flaps.
Good luck.
byronf16 is offline Find More Posts by byronf16
Discussion FIRE PHOENIX 90MM EDF - composite FOX ONE! Electric Ducted Fan Jet Talk 9 Jul 23, 2012 11:03 AM
Wanted hobby king 90mm composite F18 canopy V55EVO Aircraft - Electric - Jets (FS/W) 0 Jul 17, 2012 09:17 AM
Sold Aeronaut F9F Panther Full Composite 90MM EDF CARL SCHIMNOWSKI Aircraft - Electric - Jets (FS/W) 3 Jul 15, 2011 11:09 AM
Sold Aeronaut f9f panther full composite 90mm edf CARL SCHIMNOWSKI Aircraft - Electric - Jets (FS/W) 3 Jul 11, 2011 11:01 PM
For Sale Aeronaut 90mm composite F9F panther Socomon Aircraft - Electric - Jets (FS/W) 4 May 19, 2010 07:00 PM
