Home-Made Current Shunts for Measuring Motor Current
I have seen many threads in the past asking how to measure current for our motors. It is easy if you have a digital voltmeter that has a high current scale, unfortunately, most of the meters only have a 10 Amp scale. This works well for small CD-ROM type motors, or little 22mm to 24mm outrunners, but they cannot measure the larger currents used in the bigger motors. Plus, if you try to measure currents in the 10-12 amp range, you will probably melt the insulation off your test leads because they are not designed to handle that much current!
As an Electrical Engineer, I have needed to measure very large currents in the past. These were in the 50 - 100 Amp range on a 24 volt DC system, so using a DVM was out of the question. In the lab, we use a thing called a precision current shunt to measure high currents. Basically they are a very low ohm, very high watt resistor, that drops a specific voltage across itself for every amp of current that passes through it. They typically have ratings such as 1 millivolt per Amp or 10 millivolts per amp with a maximum amperage rating. To use them, you simply insert one in line with the power lead and turn the equipment on. Then you take a Digital Voltmeter and measure the voltage drop across the shunt. For example, if you were using a 1 millivolt per amp shunt, and the equipment was drawing 58.6 amps of current, the shunt would read 58.6 millivolts when measured with the DVM. Pretty neat huh! If you were using a 10 millivolt per amp current shunt in the above example, your digital meter would read 586 millivolts in the display. in this case, you simply shift the decimal point over 1 position to the left and convert your reading to 58.6 amps. This way, almost no power is lost in the shunt, and you can measure the current with a simple voltmeter. Unfortunately, these precision current shunts are kinda pricey. One made for a Fluke DVM that is a 1 millivolt per amp shunt that has a 30 amp max rating costs $62.00. I don't know about you , but paying twice as much as my motor costs to see how much current it is using seems a bit foolish to me! So how about a cheap alternative that you can build yourself, from parts you probably already have, for a couple bucks, that works as good as the $60+ dollar units? Do I have your attention? OK, lets get started. To make our own current shunt, we can take advantage of one of the fundamental properties of copper wire. Copper wire, a very good conductor, is not a perfect conductor. Every piece of wire has a finite resistance. Granted it is small, but it is measureable and consistent, and we can use this information to our advantage. If you look at a wire table, it gives the parameters of the wire such as gauge size, diameter, Resitance in ohms per 1000 feet, current carrying capacity and other measurements. Here is a link to a wire chart that I found on the web. Wire Gauge Chart From this chart there are 2 very useful wire sizes for making current shunts, 10 ga wire and 18 ga wire. If you look at the parameters for 10 ga wire you will notice that the resistance of 1000 feet is equal to 0.9989 ohms, which is pretty darn close to exactly 1 ohm (only 1/10 of 1% off to be exact). This means if we cut a piece of 10ga wire that is exactly 12.01 inches long, the resistance will be equal to 0.001 ohms. This humble 12" piece of 10ga solid house wiring is in fact a precision 1 millivolt per amp current shunt! And if you look at the chart, it is rated for 55 amps of continuous current, and can take short bursts of 100 amps with no problem!Likewise, the 18ga wire has a resistance of 6.385 ohms per 1000 feet. based on this, if you take a piece of 18ga wire that is 18.79 inches long, it will have a resistance of exactly 0.01 ohms which makes a precision 10 millivolt per amp current shunt that can carry 16 amps of continous current with short bursts of up to 30 amps. Based on this info, lets get going with making our current shunts. The first one is a 1 millivolt per amp unit. To build it you will need the following: 1 - 13" piece of 10ga solid copper house wiring. (It must be solid, not stranded, since stranded wire has a different resistance) 2 - Banana Plugs 1 - Male battery connector 1 - Female battery connector A soldering iron and some solder. I use the small mini-banana type battery connectors, so that is what you will see in the photos below. You can use any type connector you choose on yours. Step 1. Cut the 13" piece of wire to length and trim 1/2" of insulation from each end. You want to leave the insulation exactly 12" long. (Each 1/8 of an inch off in this measurement will introduce a 1% error in the shunt so measure carefully.) See the photo below. Step 2. Take the wire and wind it around something round about 3/4" in diameter. I used a screwdriver handle. You can also use a piece of dowel rod or broom handle. Step 3. Solder a banana plug and a male battery connector on one end of the wire, then solder another banana plug and a female battery connector to the other end of the wire. Now you are done! Pretty easy huh! If you want, you can add some short lengths of wire just above the banana plugs and crimp or solder your battery connectors to these leads. The important measurement is that the current must travel through 12 inches of 10ga wire to be accurate, so be sure to atttach your wires right up next to the insulation on the 10ga wire.Here is a side view of the completed shunt showing the battery connector plugs. I repeated the process using a piece of solid 18ga wire that was 18.79 inches long. This forms a current shunt that reads 10 millivolts per amp. Here is a photo of this one. To use the shunt, plug it into the voltage and ground holes on your DVM as shown below. Make sure that the connector that mates into the battery goes into the voltage hole, and the connector that mates with the speed controller goes in the ground hole. (If you get it backwards it will still work, it will just display a negative value) Turn the voltmeter to the lowest voltage scale, usually 200mV or 300mV. The one in the photo below has a 200mV scale. Set up your test motor and plug the black lead from the battery to the black lead on the Speed Controller. Then plug the red lead from the speed controller to the proper connector on the DVM. Finally, hook the red lead from the battery to the other lead on the shunt. This will turn the system on, so make sure you have the throttle turned down! Now when you run up your motor, you will see the amps of current draw in the meter display. If the meter says 15.3, then you are drawing 15.3 amps. How cool is that! The other shunt works the same way, but since it is a 10mV per Amp shunt, you have to divide the value in the display by 10. In the above example, the meter will read 153, which you would divide by 10 to get 15.3 amps. Well there you go, a simple, easy, and best of all, cheap way to convert your DVM into an accurate 100 amp current meter for just a couple bucks worth of parts and a 1/2 hour of your time. If anybody else tries this technique, please add onto this thread and let us know how it turned out. Till next time............ Lucien |
Tip
There is available a dual banana plug that plugs straight into multimeters and can /has been used as a base for these shunts.
Latest blog entry: For motor builders
And if
your not up to the task http://www.halted.com/ccp17261-acce-...30a-emi039.htm
Florida
Joined Dec 2004
You want cheep you and you want non-inductive? Just like the Fluke shunt? How about $1.38 ? Good to about 45 AMPS continuous and short bursts up to 100 AMPS. Lucien. Looks like Fluke has a handsome profit for their $62 - 30AMP shunt!
This design will read 1 milivolt per amp just like Luciens 10ga wire shunt. Substitute the resistor below in place of Luciens shunt. Actually it is more accurate to do it near your battery/ESC connoector as Powerditto suggests in post #6 to keep the high current lead short. This is true even if you test only on the bench. http://www.mouser.com/index.cfm?hand..._pcodeid=71070 Albert |
| Thread Tools | |
| Rave This is awesome!!! Home-Made Current Shunts for Measuring Motor Current | SGTalon | Foamies (Scratchbuilt) | 14 | Mar 21, 2009 09:32 AM |
| My home made heat sink for PHA-01 | jhonnytoxic | Micro Helis | 0 | May 12, 2005 07:51 PM |
| Home-made aluminium head for a Twister CP | redryder | Micro Helis | 9 | Jan 02, 2005 07:57 PM |
| home made night blades for zoom | teebok | Mini Helis | 6 | Sep 25, 2004 09:48 PM |
| How high is the current of ESC for a 550 motor? | BreezyKenny | Power Systems | 3 | Jan 23, 2002 12:15 AM |
