Something like this might work.
Hi,
Nice find, you need no more than 1500-1800 RPM at the prop and surprisingly little power, about 150 watts max, Brushless motors that have a low enough Kv for direct drive are almost always very large in power handling but the motor will only draw low current if set up for low RPM. For direct drive, a 300 Kv motor on 6 volts will draw about 20 amps so a 30 amp ESC minimum, 12 volts a 150 Kv motor and will draw about 10 amps, note the power is exactly the same and battery volume for the same runtime will also be the same so there is no real advantage for either system other than IMO getting a somewhat smaller motor for the 6 volt system say this http://www.hobbyking.com/hobbyking/s...ner_Motor.html with any car or boat ESC with reverse and over 30 amps and 2S capable. Cheers Nick |
| Thread Tools | |
| Discussion Zwarte Zee building tips please | Massey | Scale Boats | 4 | Feb 03, 2010 10:49 PM |
| Wanted Zwart zee | colin wale | Boats (FS/W) | 0 | Nov 02, 2009 12:34 PM |
| Build Log Zwarte Zee Build Up | Massey | Scale Boats | 102 | Nov 03, 2007 03:15 PM |
| Question Zwarte Zee | Bob D. | Scale Boats | 0 | Apr 12, 2006 08:34 AM |
| Discussion Zwarte Zee | Bob D. | Scale Boats | 3 | Apr 11, 2006 07:05 AM |
