Old Dec 06, 2007, 05:17 AM
GWS CHEN is offline
Find More Posts by GWS CHEN
Taipei, Taiwan
Joined Oct 2005
Alert
Connecting the charging leads with C3LP Lipoly charger
Hi Friends,
This is the Supplements for the manual of GWS C3-LP Lipoly Charger.
Warning : Users need to take great care for the following instructions when using the enclosed ''balance charging leads'' with this C3-LP (GWCHG004) Lipoly Charger. Never leave the charging Lipoly battery pack with the charger unattended during charging.
1. Be sure to connect the enclosed “balance charging leads” with the Lipoly battery pack correctly. The 7.4V leads, with white 3-pin plug, is for 2-cell 7.4V Lipoly battery pack, while the 11.1V leads, with white 4-pin plug, is for 3-cell 11.1V Lipoly battery pack. The JST red 2-pin plug is for connecting with the Lipoly battery pack. The wrong connections with the Lipoly battery pack and this charger will cause overcharging or even explosion and fire.
2. Be sure to plug ONE of the two balance charging leads, the 7.4V with 3-pin plug one or the 11.1V with 4-pin plug one into this charger ONLY during each charging. Make sure to EITHER plug the 3-pin plug into the 3 pin port/socket, OR plug the 4-pin plug into the 4-pin port/socket of this charger. Never plug both of these two leads / plugs into this charger during charging. Otherwise, there will be overcharging issue or even explosion and fire.
3. Do not connect any ruined, short circuit inside, Lipoly battery pack with this charger directly or indirectly.
It'd be much better to connect the lipoly battery pack with this charger directly without using any of the enclosed balance charging leads. Use the enclosed "Balance Charging Lead" ONLY when the plug of the Lipoly battery pack does not fit this charger, and make sure you have followed these instructions thoroughly.
There'd be no this issue at all if your Lipoly battery pack was also with 3-pin (7.4V) or 4-pin (11.1V) leads/plug, you just plug the plug into this C3LP Lipoly charger for charging. But never plug both 7.4V and 11.1V ones into this charger. Its manual has stated the same already.
Would you contact service@gws.com.tw if you do not understand this issue.
Chen
GWS CHEN is offline Find More Posts by GWS CHEN
Old Dec 07, 2007, 05:41 PM
GWS4CEO is offline
Find More Posts by GWS4CEO
Houng-wen Lin
GWS4CEO's Avatar
Shijr, Taiwan. DungGwan, China. City of Industry, California.
Joined Sep 2001
I am thinking how to make an idoit proof auto detector option circuit for "how many cells was link to charger?"
Sorry, this may cause your inconvenience!
GWS4CEO is offline Find More Posts by GWS4CEO
Discussion Charging NiMh with a lead/acid charger? HankF Batteries and Chargers 15 Aug 23, 2006 11:23 PM
Charging NiMh with Tx wall charger FULLSCALE Batteries and Chargers 1 Jan 05, 2005 11:24 PM
Problem Charging Kokams with Triton Charger Lhotta Batteries and Chargers 28 May 01, 2003 02:30 PM
charging NIMH with NICD charger pc_pilot Parkflyers 4 Sep 11, 2002 11:22 AM
Charging nmh batteries with a peak detection charger? Peter Young Electric Plane Talk 4 May 22, 2002 08:59 AM
