Old Aug 13, 2015, 04:32 AM
tambeshakunt is offline
Find More Posts by tambeshakunt
Joined Sep 2014
5.8Ghz and 2.4Ghz interference???
Hi all,
So just built my APM quad and I have an RC305 RX and TS351 TX for FPV. They both transmit at 5.8Ghz and I am using cloverleaf antennas.
My quad with the turnigy i6 runs on 2.4Ghz.
However, when I have the radio TX and fpv TX both switched on, the fpv display flickers severely - indicating some interference!?
Why should this be if I am using two completely different frequencies?
thanks!
tambeshakunt is offline Find More Posts by tambeshakunt
Old Aug 13, 2015, 08:21 PM
ican3d is offline
Find More Posts by ican3d
flying ninja!
ican3d's Avatar
Joined Jun 2011
Not enough juice to power the cam and vtx? Probably. Check your current (A) requirement and make sure no 'ground loop' problem in your setup.
ican3d is offline Find More Posts by ican3d
Old Aug 14, 2015, 04:32 AM
RC Man is online now
Find More Posts by RC Man
A man with too many toys
United States
Joined Feb 2001
Have you tried a filter?
RC Man is online now Find More Posts by RC Man
Old Aug 14, 2015, 05:58 AM
Joined Sep 2014
Pretty sure current isn't a problem because I am using an 8400Mah 35C Lipo.
What do you mean by the 'ground loop'? I have the camera and vtx grounded to the GND of the minimosd.
Thanks!
Old Aug 14, 2015, 05:59 AM
Joined Sep 2014
Sorry, am new to the hobby, which filter are you referring to?
Thanks!
Old Aug 14, 2015, 06:36 AM
United States
Joined Feb 2001
http://www.sierrarc.com/index.php?ma...roducts_id=361
Most just make their own filter. You need a Schottky diode, Capacitor or two, and an inductor.
Old Aug 15, 2015, 05:37 AM
Joined Sep 2014
Ok thanks.
What type of filter would I need? An LC filter? A toroidal ferrite filter?
Would something like this be a good buy : http://tinyurl.com/okwdapl
Thanks for your help.
Old Aug 15, 2015, 08:25 PM
slappomatt is offline
Find More Posts by slappomatt
United States, CA, Lakeside
Joined Sep 2011
you could make one yourself for less that might actually work a little better but that is basically what people make
slappomatt is offline Find More Posts by slappomatt
Old Aug 16, 2015, 04:34 AM
United States
Joined Feb 2001
I have never understood why people spends lots of money for FPV but are too cheap to buy or make a good filter that actually works.
Old Aug 16, 2015, 08:01 AM
Xyrax is online now
Find More Posts by Xyrax
United States, NJ, Lincoln Park
Joined Sep 2010
Thanks!
Doesn't matter what your LiPo rating are if your 5 or 12 volt regulator/supply/BEC can't handle the current required by the VTx and camera.
However, you indicated it only occurs when both the vtx and RC tx are both on at the same time which likely means you need a filter as other suggested. If it was a current issue, it would likely happen regardless of the Turnigy TX's power state.
Xyrax is online now Find More Posts by Xyrax
Old Aug 17, 2015, 05:38 AM
Joined Sep 2014
Ok thanks. Well I am not using a BEC, I am using a PDB and have connected the vtx & camera straight to the lipo .
I have ordered the lc power filter and once it arrives and I have installed it, I will let you know if it helps.
thanks.
Old Aug 19, 2015, 05:04 PM
Joined Sep 2014
UPDATE: Got the LC filter and installed it. Made sure it was installed correctly.
However I don't think it has fully solved the problem and now I'm seeing some new problems (or maybe I didn't spot them before idk).
- The flickering video is now random - sometimes it happens sometimes it doesn't but it definitely NEVER happens if the radio TX is off.
- When I increase power suddenly to motors, the minimosd disappears?! Doesn't happen with smooth power/ throttle, only with a sudden change.
- The flickering, when it happens, increases with motor speed
Old Aug 20, 2015, 03:53 AM
crezzee is online now
Find More Posts by crezzee
Build Fly Crash Repeat
crezzee's Avatar
Worcester UK
Joined Nov 2004
Looks like you are not the only one to have this problem:
http://www.rcgroups.com/forums/showthread.php?t=2341809
edit:
Ok, I have done some more research into this and it seems that some CP antennas are very sensitive to RF harmonics. You should try removing the VRX antenna and see if your RC TX still interferes with the video (do not remove the VTX antenna while the power is on). Then try the old dipole rubber duck antennas on you VTX and VRX. If things improve try some different CP antennas.
crezzee is online now Find More Posts by crezzee
Old Aug 21, 2015, 04:15 AM
Joined Sep 2014
edit:
That video is exactly what I'm experiencing. I will give the original dipole antennas a try and report back. thanks!
Still can't figure why the minimosd is cutting out with sudden throttle changes though
thanks for the help.
For Sale DJI Phantom 2 Vision Transmitter 5.8GHz PTV581 + RE500 2.4GHz WiFi Extender + FPVLR L gfredrone Aircraft - General - Radio Equipment (FS/W) 1 Jun 20, 2015 06:52 AM
Mini-HowTo Converting your Fatshark RCV922 Aviator Edition from 2.4ghz to 5.8ghz Daedalus_BE FPV Equipment 4 Jun 16, 2015 10:05 AM
Help! My 5.8GHz Video TX interfer with 433MHz telemetry TX GSW14 FPV Talk 5 May 02, 2015 05:17 PM
Help! 2.4GHz radio transmitter interfering with 5.8GHz video receiver? Jhangir FPV Talk 2 Feb 06, 2015 10:29 PM
Found 5.8Ghz /2.4Ghz Patch Antennas & Fatshark 5.8Ghz SpiroNet Antennas WANTED BajaSky619 FPV Equipment (FS/W) 0 Jun 22, 2014 06:31 PM
