Old Jun 08, 2014, 12:47 AM
Canada, BC, Castlegar
Joined May 2014
Help!
QRX350 Aileron / Rudder Mixing ?
Gentlemen :
Please feel free to submit any ideas for setting up a Devo7 FPV radio and Walkera QRX350 for the aileron / rudder mix .
I am still kinda new at the quadcopter stuff but have flown over 35 years with airplanes . The goal I am after is to set up a more co-ordinated turn with the quad as I am having thumb problems doing it with the rudder stick . I would love to see something with the rudder mix number being substantially higher than the aileron number .
All efforts so far have only resulted in seeing the aileron mix number at +- 100 with the rudder number at +-75 . It doesn't seem to be a straight up ratio and the expected results seen in the monitor function are kinda screwy at times . If there were only a rudder / aileron mix function !
THIS is going to sound stupid but .......................
What if a guy physically swaps the aileron and rudder RX outputs ? This would allow for the better numbers and would make the bird handle like a 3 channel airplane set-up . (Plugging in the rudder servo into the aileron channel )
I dunno . Is this too crazy of an idea ?
Thanx for supporting my blog .
RickC_RCAV8R
RickC_RCAV8R is offline Find More Posts by RickC_RCAV8R
Old Aug 16, 2014, 11:52 AM
United States, NY, Bronx County
Joined Nov 2008
Swapping Rudder and Aileron channel on Quad Copter
I was thinking of the same thing about the mixing of rudder and aileron I think that coming from fix wing flying that we have fix wing flying habits. Rotor head flying is a different thing all to get there and the more I fly the quad the better I get in both rotor and fix wing . I still at time I push the the throttle to go forward from a stand still and end up going up but a get use to it. LOL. Not a bad Idea to swap the rudder and aileron channel around when flying FPV and normal mode when line of flight flying. I will program a mix tonight. Thanks for the Idea.
Serafin is offline Find More Posts by Serafin
Discussion New to 4 Channel - Aileron/Rudder Mixing Questions sstephenson Electric Plane Talk 21 Mar 27, 2014 08:44 AM
Hitec Flash 5x--aileron/rudder mix problem cloudhopper Electric Plane Talk 4 Mar 10, 2002 07:25 AM
Aileron / Rudder mixing ques? me11owman Electric Sailplanes 5 Dec 30, 2001 07:13 PM
Mixing for Alliance (rudder, elevator,ailerons) JensJakob68 Electric Plane Talk 4 Dec 07, 2001 09:07 AM
Aileron/Rudder/Elevator w/ 2 mixed servos? hardlock Power Systems 13 Sep 29, 2001 02:42 AM
