Old Nov 19, 2006, 02:05 PM
rcmarty is offline
Find More Posts by rcmarty
Penticton, B.C.
Joined Jun 2004
HV T600 motor : Z50A-800 ? compares to 600l
Trying to find a fit for the t600 hv application. I want to use the 123 cells in preferably 10 cell bricks as they come but may have to goto 15 or 14 cells.
The z50 have been doing well in the 620 bladed applications (raptor50 conversions) and the t600 is swinging 600's and i understand is about the same weight or lighter.
I'm comparing kv's to see if i'm going to be able to gear it for desired headspeed.
Z50a-800 motor : kV: 780 for 10 cell applications
Align 600L has a kv of 1620 for 6 cell applications
780 kv x 10 cell lipo's (40v) i get : 31200 rpm
1620kv x 6 cell lipo (24) i get : 38880 rpm
I'm out 7680 rpm.
oz has been using the 1512(2y ?) neu motor wich has a kv of 1100 on 10 123 cells (which i plan on using).
Is this still gearable to work in the t-600 for 2000 rpm , looking for 3d machine that is as good or preferable better than a hyper50 raptor on 30% coolpower.
The Z power motors would surely keep the cost down as there alot less, i have a neu in my swift and it's a nice efficient motor but is alot more $$.
Martin
rcmarty is offline Find More Posts by rcmarty
Old Nov 19, 2006, 03:03 PM
northwood is offline
Find More Posts by northwood
northwood's Avatar
Joined Aug 2005
If you can get hold of some Mikado steel pinions (0.7) you can probably gear for almost any motor.
I use the Z-Power 50, KV:565 with an 18 tooth pinion (straight cut gear). Headspeed around 2050 - 2150 I think.
Using 10S FP EVO20"NF" 3700.
northwood is offline Find More Posts by northwood
Old Nov 19, 2006, 04:49 PM
kogibankole is offline
Find More Posts by kogibankole
Permanently Banned
kogibankole's Avatar
Albuquerque
Joined Nov 2004
here is what im doing...im making 2 7 cell packs and mounting them infront like where the lipo pack is supposed to be...so that the packs will fit into the frame im mounting them diagonally. Im using the lipo tray to extend the front end so that i can get the packs more diagonal and so that tehy will fit..ill get pics up when im done however im still waiting for the zpower motors!
kogibankole is offline Find More Posts by kogibankole
Old Nov 19, 2006, 05:13 PM
ozace is offline
Find More Posts by ozace
Renewed interest
ozace's Avatar
Melbourne , Australia
Joined Jun 2002
I'm out 7680 rpm.
Martin
Nope i am using the 1400kv 1512 motor and 11t straight pinion.
ozace is offline Find More Posts by ozace
Old Nov 19, 2006, 09:29 PM
rcmarty is offline
Penticton, B.C.
Joined Jun 2004
I'm not sure what gearing options there are out there for the t600.
I should be able to make up 7680 rpm on the motor shaft then ?
The logo pinions do have a nice selection though.
ozace ... if your running a 1400kv motor and 10 cell 123's on yor t600, what should i be using for voltage under load to compare to the 600L motor ? Or am i going to need more cells with the z50a-800 ?
Thanks for the help ,
MArtin
Old Nov 19, 2006, 09:31 PM
ozace is offline
Renewed interest
ozace's Avatar
Joined Jun 2002
Logo 14 pinions fit , so you should have no trouble with the 800kv motor and a 17t or 19t pinion (at a guess). I use 28v as a rough guide under load for the 10s pack.
Old Nov 19, 2006, 09:54 PM
Permanently Banned
Albuquerque
Joined Nov 2004
on a 600 10 m1 cells wont just cut it...you need at least 14..comon!
Old Nov 19, 2006, 10:10 PM
ozace is offline
Renewed interest
ozace's Avatar
Joined Jun 2002
More than enough for me. Its light and it goes harder than i can
Keep in mind, my name is Adam not Gary
Sold Z50A-800, like new condition. A total of 12 five minute flights on motor. (SOLD) rickc Aircraft - Electric - Power Systems (FS/W) 3 Feb 15, 2007 10:48 PM
Discussion spreading plastic logo frames with heat to fit Z50A-800? cptsnoopy Electric Heli Talk 3 Dec 04, 2006 12:11 PM
Discussion HV 45 Motor Motor Probs e-heliflyer Castle Creations 4 Oct 08, 2006 12:04 PM
Eolo HV - Medusa Motor initial test results CustomPC Electric Heli Talk 2 Apr 06, 2005 05:49 PM
WTB: Motor PJS 800/1000 Dead or Alive. Cas123 Aircraft - Electric - Airplanes (FS/W) 2 Jul 08, 2004 11:28 AM
