Old Mar 12, 2015, 04:55 AM
mslr75 is offline
Find More Posts by mslr75
Joined Mar 2015
Question
Help to chose a first FPV (low budget)
Hi,
I want to buy a first FPV Quadcopter for fun my budget is arround $100
I want at least a 30cm quadcopter
I found 3 models
1) WLtoys V686G 4CH 5.8G FPV Real Time Transmission 2.4G RC Quadcopter with 2.0MP Camera Headless Mode Auto - Return Function
2) SKY HAWKEYE 1315S 5.8G FPV Real Time Transmission RC Quadcopter with 0.3MP HD Camera Headless Mode 2.4G 4 Channel 6 Axis Gyro RPV UFO
3) JJRC H9D 2.4G 4CH 6 Axis Gyro RC Quacopter with 0.3MP Camera FPV Real Time Transmission
or an another models
Could you help me and give me some advice
which of these models is the best for starting
Regards
Marc
mslr75 is offline Find More Posts by mslr75
Old Mar 12, 2015, 07:44 AM
Byrdman is offline
Find More Posts by Byrdman
Winter Haven FL
Byrdman's Avatar
Joined Dec 2003
Originally Posted by mslr75 View Post
Hi,
I found 3 models
Regards
Marc
IMO, you should save up another month or so and spend more. You can get so much more for your money if you do. Maybe get a $50 toy to practice flying until you are able to spend more.
Byrdman is offline Find More Posts by Byrdman
Old Mar 12, 2015, 08:01 AM
John Luciano is offline
Find More Posts by John Luciano
United States, CT, Kent
Joined Nov 2009
I agree. If you never have flown RC. You should buy a toy to crash with. It will be months before you will use any of the functions you think you need. Spending $100 more gets you 200% better quad. Also in the past 6 mo the price has dropped and the products have improved. What cost $600 last year is $350 this year. Would be a shame to watch your $200 quad go out and fly away because you lacked the experience.
John Luciano is offline Find More Posts by John Luciano
Old Mar 12, 2015, 10:00 AM
mslr75 is offline
Joined Mar 2015
Thank's a lot for your advice
so what do you think about the Huajun HJ818 ?
Marc
Old Mar 12, 2015, 10:42 AM
Joined Nov 2009
Read this post
http://www.rcgroups.com/forums/showthread.php?t=2353463
The V686 RTH is not really that. All that happens is it goes in the opposite it direction it was flying in when you press the camera button 3 times. Can be confusing when taking photos.
Old Apr 03, 2015, 08:19 PM
bgpoppatow is offline
Find More Posts by bgpoppatow
Canada, AB, Nanton
Joined Mar 2015
Actually fixed the motor. Was a gear shaft screw was loose and fell down on the shaft. I love it! handles quite well. Could use a better battery but got me interested enough to order a Cheerson cx 20 wch is a fabulous unit
bgpoppatow is offline Find More Posts by bgpoppatow
Old Apr 03, 2015, 09:11 PM
Oldgazer is offline
Find More Posts by Oldgazer
Oldgazer's Avatar
United States, VA, Richmond
Joined Dec 2013
You need more cash.
All of the aircraft you picked are toys, and the WL Toys V686 is the worst of the bunch.
Oldgazer is offline Find More Posts by Oldgazer
Old Apr 03, 2015, 10:04 PM
Factor is offline
Find More Posts by Factor
United States, VA, Mechanicsville
Joined Feb 2015
30cm on that budget is near impossible for anything worth owning I fear.
Personally, I'm having a ton of fun with a Blade Nano QX until the rest of my parts for my own 30cm FPV build comes in, but I've gone the exact opposite way and blown way too mu?ch on an overbuilt setup, but hey... its only money right? The Nano will save you a LOT of money in the long run. You can crash it full speed into just about anything and it will just bounce right off with little or no damage.
Factor is offline Find More Posts by Factor
Old Apr 04, 2015, 03:43 AM
freel is offline
Find More Posts by freel
Joined Feb 2015
Hi,
I found 3 models
Regards
Marc
You can get a pretty good introduction to FPV with a modified WLToys V686G. Out of the ones you've listed, its the only one that actually works well for FPV. You'll need to add a wide angle lens and mod the monitor into a pair of goggles. You'll also want to buy some extra batteries . For someone who has never flown FPV before, this quad gives a safe and cheap way to get introduced to the hobby. Safe because this is a very light quad with geared props that run at a fairly low RPM .. so you won't hurt yourself or someone else too badly if you were to crash it into someone. Despite this, it is a fairly responsive and acrobatic flyer.
freel is offline Find More Posts by freel
Discussion Looking to build first quad (low budget) kagenokaze Scratchbuilt Multirotors 10 Feb 23, 2015 10:13 AM
Wanted Apprentice PARTS needed HELP / low budget :( TIRCQ Aircraft - Electric - Airplanes (FS/W) 7 Feb 10, 2015 06:08 PM
Discussion Help deciding on first boat, budget under $50. David Heggood Dock Talk 2 Apr 18, 2014 01:13 PM
Build Log Bad weather low budget project: toy grade surface FPV rudyauction509 FPV Talk 10 Feb 26, 2014 12:51 AM
Help! First Build Low budget 1vh1 Multirotor Talk 3 Jan 20, 2014 12:37 AM
