View Poll Results: What style of Turnigy 1/16 vehicle do you prefer?
Rally Extreme 47 38.21%
Mini Trooper 46 37.40%
Racing Buggy 30 24.39%
Voters: 123. You may not vote on this poll
Old Apr 11, 2015, 07:53 AM
Chubbs is offline
Find More Posts by Chubbs
FPV Noob KD0VMK
United States, MO, Platte City
Joined Jun 2012
Carbon fiber parts for the buggy
I thought i'd share my project last night with everyone. A couple of days ago I got some goodies from Carbonfiberglass.com. So, I made a carbon plate:
The plate was made with 2 layers of 3k carbon fiber, 2x2 twill pattern, 1 layer of 18oz woven roving fiberglass (mostly used as a filler to get more thickness), and then 2 more layers of carbon. All of that was smashed between 2 layers of plexiglass. It turned out "ok"...there were a couple of air bubbles on the surface I wish I could get rid of, and the surface finish on one side was a little rough due to excess wax used on the plexiglass. But all in all, not bad for my first attempt.
It turned out to be about 2.2mm thick, which is pretty darn close to how thick the plastic chassis is.
Then I trimmed it:
You can probably guess where this is going.
It turned out pretty well. I was a bit surprised it didn't seem to add as much torsional stiffness as I'd hoped. It was a LOT stiffer front to back, and side to side, but when twisted, it still flexed quite a bit. It's stiffer than the plastic chassis, but not by much.
By then I had a couple beers in me, and things started getting crazy
You'll have to forgive the sloppyness. When parts are this small, drilling all those holes is really hard. 1/32 or 1/64 of an inch is usually an acceptable margin of error, but when there are so many holes in such a small area, those tolerances just aren't good enough. So, some of it looks a little sloppy. Without a CNC machine, it's the best I could do. It works.
This stuff is like rich-man's chrome. Once you have access to it, you find that just about anything is better in carbon. Next project is a chassis for my severely overweight 4x4 trooper.
Chubbs is offline Find More Posts by Chubbs
Old Apr 11, 2015, 12:11 PM
Hammer Head is offline
Find More Posts by Hammer Head
the journey is the reward
Hammer Head's Avatar
Canada
Joined Apr 2002
Very cool Chubbs!
Hammer Head is offline Find More Posts by Hammer Head
Old Apr 12, 2015, 12:56 AM
Rockracer is offline
Find More Posts by Rockracer
Australia, QLD, Whyanbeel
Joined Jan 2015
Nice job.
Rockracer is offline Find More Posts by Rockracer
Old Apr 12, 2015, 12:05 PM
finguz is offline
Find More Posts by finguz
finguz's Avatar
United States, CA, San Diego
Joined Mar 2012
Looks great chubbs!
Which wheels are those?
finguz is offline Find More Posts by finguz
Old Apr 12, 2015, 12:57 PM
Canada
Joined Apr 2002
I order servo savers etc...shows in stock...order received with multiple parts not included and the needed servo saver.
This parts issue is getting ridiculous...HK is not going to get much more business from me.
Old Apr 12, 2015, 05:54 PM
Chubbs is offline
FPV Noob KD0VMK
Joined Jun 2012
Originally Posted by finguz View Post
Looks great chubbs!
Wheels are stock, withstandard 1/10 scale proline X2 compound scrubs that have been cut down to fit.
Old Apr 12, 2015, 06:21 PM
finguz is offline
finguz's Avatar
Joined Mar 2012
They look good! Good use of the stock wheels. Just wondering, what do you use for glue (considering the somewhat high speed application)? I've only trimmed and glued tires for low speed applications.
Old Apr 12, 2015, 08:11 PM
Chubbs is offline
FPV Noob KD0VMK
Joined Jun 2012
I used this stuff
http://www.hobbyking.com/hobbyking/s...Glue_1_oz.html
The idea came from this how-to
http://www.prolineracing.com/blog/20...si-mini-8ight/
At first I thought it was a pretty janky solution, but I didn't know what else to do for decent tires. I thought proline was a credible source, so I gave it a shot.
So far, they are holding up great. I probably only have 3 batteries through the car now (to be fair, a 2200mah lipo lasts about half an hour though), and the tires show no signs of failing at the glue joints. If you take your time and you're careful, the joints don't even look half bad.
Old Apr 13, 2015, 12:55 PM
finguz is offline
finguz's Avatar
Joined Mar 2012
I used this stuff
If the mini8 caught their eye so specifically, why didn't they make a tire for it ?!
That's cool that it has worked out for you, sounds like something definitely worth trying.
Another glue that might work even better is IC-2000 CA. I bought some for gluing tires to a set of metal rims I have (that aren't beadlocks). It's supposed to work great, it's really flexible, and it's black rubber color. I haven't tried it out yet.
Old Apr 13, 2015, 03:08 PM
Chubbs is offline
FPV Noob KD0VMK
Joined Jun 2012
Good question. It would have made my life a whole lot easier.
They make the whole process look easy in that tutorial, but believe me, those are not the first attempts they made. The very first one I tried was on an old scrap tire, and I'm glad it wasn't the real deal. I generally consider myself pretty darn good at this type of stuff, but that first tire was a mess.
Each tire I did got better, and by the time I was on the final buggy tire, they looked almost as good as they do in the tutorial. Still not perfect though. If you're going to attempt such a thing, practice on an old tire first.
Old Apr 13, 2015, 05:28 PM
finguz is offline
finguz's Avatar
Joined Mar 2012
Good to know Chubbs, I have done a couple trim jobs on tires but neither of them had much power behind them... in fact they were just kids toys for my nephew. Even then I can't say that the rubber held together great, but at the same time it has never come completely apart. That and I probably didn't do a great job of cutting, like you are saying, and also the rubber was a lot harder, so basically a different situation all together. But all in the same, it gave me a taste of what tire trimming was like, a pain the the butt.
And not like it's an easy thing to do, forcing yourself to cut into a brand new set of perfectly good tires.
It looks great though, especially on the buggy!
Sold Turnigy Trooper SCT 4x4 PLUS Another 4X4 SC with Many EXTRAS!!! Only 190 bucks!! Maseo54 Cars - Trucks and Parts (FS/W) 1 Apr 23, 2013 02:20 PM
Sold Turnigy Trooper SCT 4x4 AND another SC 4X4 With a TON of Extras!! Only 190 bucks!! Maseo54 Cars - Cars and Parts (FS/W) 0 Apr 23, 2013 04:48 AM
Sold HK Trooper 4wd 1/10 SCT - RTR, upgrades, extras coolboarder Cars - Trucks and Parts (FS/W) 3 Apr 01, 2013 01:44 PM
Discussion Can I bolt on some different on road rims/tires for my Trooper SCT 4x4? MrRetro Off-road Cars 2 Jan 30, 2013 04:54 PM
Discussion 1/16 e-revo or Turnigy Trooper Dan_eflyer Off-road Cars 15 Jan 25, 2013 10:25 AM
