Old Sep 07, 2012, 07:50 PM
Cope12 is offline
Find More Posts by Cope12
Joined Sep 2012
Blade 120 power just quits in flight.
Does anyone else have this same problem? Sometimes when I fly my 120 like tonight I was flying out side the heli just looses power and signal and falls to the ground. Tonight it fell on its top and did some damage. I have fresh batteries in the heli and transmitter. How far can the heli fly away from you before you loose signal? I am using the transmitter that came with it the rtf model. If it does get out or range is it supposed to just die?
Cope12 is offline Find More Posts by Cope12
Old Sep 08, 2012, 10:43 PM
balsa or carbon is offline
Find More Posts by balsa or carbon
Hot glue held together by foam
United States, WA, Vancouver
Joined Aug 2010
This thread is for airplanes , try this one http://www.rcgroups.com/beginner-tra...-electric-599/
balsa or carbon is offline Find More Posts by balsa or carbon
Discussion Zhengrun Z 008 just spins, lower blades haven't got any real power helimor Micro Helis 1 Sep 24, 2012 01:22 PM
Wanted Spinner 21/2 in 2 blade 120 jaimecuesta Aircraft - Fuel - Engines and Accessories (FS/W) 0 Jun 20, 2012 07:50 PM
Discussion OS 40 FP just quits UlteriorModem Engines 9 Apr 29, 2012 04:48 PM
Discussion Problem with Rimfire .10 quiting in flight JackA Power Systems 8 Mar 30, 2012 12:45 PM
