Old May 25, 2013, 11:53 AM
Joined Apr 2011
PL8 help
I am charging small lipos on a balanced charge witht the FMA board that allow up to 6 batteries. When I use the small lipo balanced charge preset and put in 1.8 amps ( the batteries are 1800). The charger decreases the amperage value for each lipo input on the board. Shouldn't the PL8 read 1.8 amps no matter how many parrallel units I put on the board? I guess what I am asking is whether or not 1.8 amps is charging each battery or is 1.8 amps being divided amount each battery? How can I maintain 1.8 amps for each battery to reduce time.
Maybe I am not understanding.
delirious1 is offline Find More Posts by delirious1
Old May 25, 2013, 12:08 PM
Seattle
Joined Sep 2007
The small lipo presets are tuned for 2 amps and below. 6 x 1.8 is just over 10 amps. You will need to use the high power preset for anything above 10 amps. the first two presets are tuned for 2 amps through 10 amps.
Gregor99 is online now Find More Posts by Gregor99
Old May 25, 2013, 01:16 PM
Joined Apr 2011
Thanks for the response. I'll do that. .....but why is it when I put on two packs the charging amps is 1 amps and with three packs it is 666 mAmps. Seems it is being divided which is still under 10 amps total charging
Old May 25, 2013, 01:24 PM
Seattle
Joined Sep 2007
Did you switch from the small lipo presets to either preset 1 or preset 2?
Old May 25, 2013, 01:43 PM
Joined Apr 2011
That is accessed through the computer program, as I don't see a preset menu to change?
If I am charging 3 X 1.8 amp batteries, I should set the PL8 to 3P and 5.4 amps (3 X 1.8), correct?
Or 6 batteries at 6p with 10.4 amps on the high setting? That would be 1.8 amps per battery?
Old May 25, 2013, 04:11 PM
Seattle
Joined Sep 2007
When you start the charger, after selecting the power source, you are in the preset menu. The list of presets is the "main menu" of the Powerlab. Use the INC and DEC buttons to scroll through the available presets. Preset 1 is the Generic Accurate charge, maxes out at 10 amps. Preset 2 is the Generic Fast charge also maxes out at 10 amps. Preset 3 is the High Power charge which maxes out at 40 amps.
If you are a recent firmware version, you set parallel packs to 3 and charge rate to 1.8. Total output current will be 5.4 amps. If you are seeing something different, you may need to update your firmware. Latest is 3.31. There was a parallel packs setting change in behavior. Don't remember the version this was changed, but it was a long time ago.
Old May 25, 2013, 04:48 PM
Joined Apr 2011
I'm good to go. The high power is working for me. Thanks everyone. Using firmware 3.31 now
Old May 25, 2013, 07:23 PM
Seattle
Joined Sep 2007
Glad to hear it. Thanks reporting back in. Enjoy the charger.
Discussion PL6 or PL8 or 4010DUO - help me decide cirrus_uk Batteries and Chargers 12 Apr 07, 2013 11:56 AM
Sold new powerlab pl8 v2 1344w 40a charger plus accessories ohsnap Aircraft - Electric - Batteries & Chargers (FS/W) 1 Jan 18, 2013 11:10 AM
Discussion PL8 error 85/safety charge Jack G Diaz FMA Direct 8 Jan 10, 2013 11:05 PM
Help! new pl8 v2 - bad cell count node wiring xh error.. help? ohsnap FMA Direct 13 Apr 05, 2012 04:23 PM
Discussion PL8 and 7s lipos,Help. epc2 Batteries and Chargers 5 Feb 27, 2012 10:42 PM
