Old Mar 31, 2006, 11:47 PM
Joined Nov 2005
OS .50 SX Hyper Help
I'm pretty sure this is a tuning issue but don't know. The engine is in a Caliber 5. But here is the issue. It seems that it is just "bubbling" and "popping" a bit to much, in the lower end. I have not flown it yet for this reason. It just feels way inconsistent. When I do give it gas it does respond quite well though, no lag. Any and all help would be awsome as I am loosing my patients with this thing.
Gobig911 is offline Find More Posts by Gobig911
Old Apr 01, 2006, 02:00 AM
HobbyKing
Paul Susbauer's Avatar
Hong Kong, Hong Kong Island, Hong Kong
Joined Apr 2001
Try richening the low end ever so slightly. Depending on your pipe, the popping/pinging is an indication it is lean.
--Paul
Paul Susbauer is offline Find More Posts by Paul Susbauer
Site Sponsor
Old Apr 01, 2006, 02:33 PM
Joined Nov 2005
Thanks for the respnse, still a little confused I just spoke with a guy at the hobby shop who said I need to lean it on the low needle??? totally the opposite of your suggestion, now I'm totally lost.....
Old Apr 01, 2006, 04:06 PM
King_Ice_Flash's Avatar
WI
Has the (low speed) needle been changed since the factory setting?
King_Ice_Flash is offline Find More Posts by King_Ice_Flash
Old Apr 01, 2006, 05:35 PM
Joined Aug 2004
trying to diagnose an engine tuning problem over the net is like asking a mechanic to diagnose your car over the phone.
With the engine idling, pinch the fuel line and listen. If the rpms pick up for 3-5 seconds you are about right. If the engine dies or only picks up rpms for a sec or two before it dies you are too lean. If the Rpms stay revved up for more than 5 sec you are too rich.
Jeff H is offline Find More Posts by Jeff H
Old Apr 02, 2006, 02:03 PM
Joined Nov 2005
Thanks for the help I think I got it, it was running waaay rich. So I leaned it out slightly on the low end and about 1.2 turns open on the high needle. seems to be doing well. Also I did a pinch test and it responded great, leaning out for about 4 seconds.
Thanks again
Discussion Os 50 SX engine help and explanations wickkerr82 Engines 7 May 12, 2006 06:37 PM
Discussion OS-50 SX-H Hyper carb adjustment question King_Ice_Flash Fuel Heli Talk 4 Mar 14, 2006 07:40 PM
For Sale OS 50 SX-H hyper ring brand new unopened for $175 matrix_mimi Aircraft - Fuel - Helis (FS/W) 12 Jul 06, 2005 10:55 AM
FS: OS 50 SX-H Hyper for sale Jason WAI Aircraft - Fuel - Helis (FS/W) 6 Nov 21, 2004 08:28 PM
