Old Oct 25, 2014, 04:10 PM
Joined Sep 2011
FreeCAD script to generate EDF shroud
Folks, I am attaching this script I wrote to generate an EDF shroud, which can later be printed on Shapeways. This is for the benefit of all the micro EDF fans out there.
# Free for non-commercial use
from FreeCAD import Part
from FreeCAD import Base
from math import pi
thickness = 0.8
nacelle_outer_dia = 32
nacelle_inner_dia = 7.1
nacelle_outer_height = 12
nacelle_inner_height = 8
vane_height = 6
mount_hole_spacing = 4
mount_hole_dia = 0.4
cone_taper_height = 20
cone_taper_dia = 10
nacelle_outer_rad = (nacelle_outer_dia/2.0)
nacelle_inner_rad = (nacelle_inner_dia/2.0)
cone_taper_rad = (cone_taper_dia/2.0)
nacelle_outer_ring = nacelle_outer_rad + thickness
nacelle_inner_ring = nacelle_inner_rad + thickness
ring_outermost = Part.makeCylinder(nacelle_outer_ring, nacelle_outer_height)
ring_outer = Part.makeCylinder(nacelle_outer_rad, nacelle_outer_height)
outer_diff = ring_outermost.cut(ring_outer)
ring_inner_outermost = Part.makeCylinder(nacelle_inner_ring, nacelle_inner_height)
ring_inner = Part.makeCylinder(nacelle_inner_rad, nacelle_inner_height)
inner_diff = ring_inner_outermost.cut(ring_inner)
vane_1 = Part.makeBox(nacelle_outer_rad - nacelle_inner_ring + thickness, thickness, vane_height)
vane_2 = Part.makeBox(nacelle_outer_rad - nacelle_inner_ring + thickness, thickness, vane_height)
vane_3 = Part.makeBox(nacelle_outer_rad - nacelle_inner_ring + thickness, thickness, vane_height)
vane_4 = Part.makeBox(nacelle_outer_rad - nacelle_inner_ring + thickness, thickness, vane_height)
stub_length = nacelle_inner_rad - (mount_hole_spacing/2.0) + 1
stub_1 = Part.makeBox(stub_length, thickness, thickness)
stub_2 = Part.makeBox(stub_length, thickness, thickness)
trf_1 = Base.Matrix()
trf_2 = Base.Matrix()
trf_3 = Base.Matrix()
trf_4 = Base.Matrix()
trf_5 = Base.Matrix()
trf_6 = Base.Matrix()
trf_7 = Base.Matrix()
trf_8 = Base.Matrix()
trf_1.move(Base.Vector(nacelle_inner_ring - (thickness/2.0), -(thickness/2.0), 0))
trf_2.rotateZ(pi)
trf_2.move(Base.Vector(-nacelle_inner_ring + (thickness/2.0), (thickness/2.0), 0))
trf_3.rotateZ(pi/2)
trf_3.move(Base.Vector((thickness/2.0), nacelle_inner_ring - (thickness/2.0), 0))
trf_4.rotateZ((-pi)/2)
trf_4.move(Base.Vector(-(thickness/2.0), -nacelle_inner_ring + (thickness/2.0), 0))
trf_5.move(Base.Vector(nacelle_inner_rad - stub_length + (thickness/2.0), -(thickness/2.0), nacelle_inner_height - thickness))
trf_6.move(Base.Vector(-nacelle_inner_ring + (thickness/2.0), -(thickness/2.0), nacelle_inner_height - thickness))
hole_left = Part.makeCylinder((mount_hole_dia/2.0), thickness)
hole_right = Part.makeCylinder((mount_hole_dia/2.0), thickness)
trf_7.move(Base.Vector((mount_hole_spacing/2.0), 0, nacelle_inner_height - thickness))
trf_8.move(Base.Vector(-(mount_hole_spacing/2.0), 0, nacelle_inner_height - thickness))
vane_1.transformShape(trf_1)
vane_2.transformShape(trf_2)
vane_3.transformShape(trf_3)
vane_4.transformShape(trf_4)
stub_1.transformShape(trf_5)
stub_2.transformShape(trf_6)
hole_left.transformShape(trf_7)
hole_right.transformShape(trf_8)
stub_1_hole = stub_1.cut(hole_left)
stub_2_hole = stub_2.cut(hole_right)
Part.show(outer_diff)
Part.show(inner_diff)
Part.show(vane_1)
Part.show(vane_2)
Part.show(vane_3)
Part.show(vane_4)
Part.show(stub_1_hole)
Part.show(stub_2_hole)
c1 = Part.makeCone(cone_taper_rad,nacelle_outer_rad,con e_taper_height)
c2 = Part.makeCone(cone_taper_rad + thickness,nacelle_outer_rad + thickness,cone_taper_height)
nacelle = c2.cut(c1)
trf_nac = Base.Matrix()
trf_nac.move(Base.Vector(0,0,-cone_taper_height + (thickness/2)))
nacelle.transformShape(trf_nac)
Part.show(nacelle)
heli_radiohead is offline Find More Posts by heli_radiohead
Sold 9305 het shroud and fan 90mm edf c payne Aircraft - Electric - Jets (FS/W) 0 May 05, 2014 06:11 PM
Wanted E-Flite Delta V-15 EDF Shroud (housing) Jetsom Aircraft - Electric - Jets (FS/W) 0 Feb 20, 2014 10:06 PM
Wanted 40mm EDF rotor to fit AEO 40mm edf shroud Keenan smith Aircraft - Electric - Jets (FS/W) 4 Feb 14, 2013 04:05 PM
Where to get EDF inlets and shrouds for GWS. Darn Servo ! Foamies (Kits) 2 Jun 30, 2003 03:04 PM
