Old Sep 27, 2014, 04:39 PM
Joined Sep 2014
RC Hovercraft for search and rescue
I'm currently planning to build a search and rescue hovercraft for my project study
Here are my stuffs:
(2) RC timer 850 KV motor
(2) 4500mAH 3s 11.1 v lipo batteries
(1) SJ400 action camera
(1) Boscam 1000mW transmitter
(1) Boscam 32 CH receiver
(1) 9.8" LCD tv
(1) 1500 mAH 3s 11.1v lipo batteries
(1) 5400 mAH 4s li po battery
(1) turnigy 9xr pro
(1) Fr sky D8R-II plus Tx Rx set
(1) turnigy 2200mAH battery for my Radio
which of those batteries shall i use?
Which material should I get for my base and skirt? and what type and size of prop would you recommend for (1) Hover and (1) Propulsion.
BTW im planning to make it 1mX0.5m or kindly give me advice on what is the ideal size for it.
Thanks in advance!
zeakfread is offline Find More Posts by zeakfread
Old Sep 28, 2014, 06:02 AM
Australia, VIC, Bass
Joined Jan 2013
10 inch props would be ok to start with,
foam for the base with balsa or ply for the motor mounts etc.
the skirt can be made from a plastic garbage bag then use this as a pattern to make a more durable one from lightweight ripstop nylon or similar material.
windnsea is offline Find More Posts by windnsea
Old Sep 28, 2014, 07:13 AM
Joined Sep 2014
what do you propose? a three blade or two?
and what weight is ideal that it can still move smoothly?
Old Sep 28, 2014, 08:38 PM
Joined Jan 2013
Three blades would be better for lift but depends on the weight you are lifting -try to keep it under 5 pounds.
Old Sep 28, 2014, 10:09 PM
Joined Sep 2014
Do I need to get higher KV rating or is 850 KV enough?
Old Sep 29, 2014, 04:24 AM
Joined Jan 2013
that should be ok with a 10 inch prop
Old Sep 30, 2014, 09:40 AM
Joined Sep 2014
I got styrofoam for my base going to do it one meter in length can you suggest ideal width for it? and BTW the foam thickness is 2 inches.
Old Sep 30, 2014, 10:22 PM
Joined Jan 2013
You could make it about 600 wide, but its not that important. I guess you will use a simple bag skirt ?
Old Sep 30, 2014, 11:22 PM
Joined Sep 2014
bag skirt? what do you mean?
Old Oct 01, 2014, 12:17 AM
Joined Jan 2013
What type of skirt are you using ?
Old Oct 01, 2014, 02:44 AM
Joined Sep 2014
Type of skirt? or material that I am going to use? If material is what you mean I am currently open for opinions. Does not have any ideas at the moment.
Old Oct 01, 2014, 03:02 AM
Joined Sep 2014
Oh about the type of skirt, I would like it to be the same with the original manned hovercraft, would that be a problem? any tips with its construction?
Old Oct 01, 2014, 04:22 AM
Joined Jan 2013
Hovercraft skirts can be tricky to make especially if you don't have a plan to follow. I think you can find some details reading through the forums and maybe some plans also.
Old Oct 01, 2014, 06:46 PM
Joined Sep 2014
I am planning to use finger skirt to make it durable compared to the simple bag skirt. Can you send me a picture of a pattern i found one on your posts but I did not quite understand it.
Old Oct 02, 2014, 04:19 AM
Joined Jan 2013
Ok here is a drawing showing how the skirt is made and attached to the model. The exact size of the segments is up to you but if you scale it up from the drawing it should work well.
Discussion Volunteer RC search and rescue FPV totally legal in USA? HoverbotFPV FPV Talk 1 Jul 21, 2014 08:58 PM
News Search and Rescue Jason Cole FPV Talk 13 Nov 14, 2013 12:12 PM
Discussion Helicopter Simulator: Search & Rescue - Greenlight access Ray_fly Simulators 0 Oct 27, 2013 03:21 PM
Discussion Use of RC AP/AV for search (and rescue) -- tips, tricks and tech ideas Arthur P. Aerial Photography 42 Feb 03, 2008 04:49 AM
Yippee! A succesfull Search and Rescue story (RC plane rescue) dogon1013 Aerial Photography 21 Jan 08, 2007 09:18 AM
