Old Oct 23, 2014, 04:35 PM
Jack of all master of none
splinterz25's Avatar
Baltimore MD USA
Joined Jan 2011
Originally Posted by bwigger View Post
I looked up the specs on some of those micros you mentioned. They seem to have a very low torque. Which models were you planning yo use?
I'm not sure how much torque you think you need but w/ two working together at 6V It's a good bit?
here's one of the Hitec servos I'm using a great deal.
http://www3.towerhobbies.com/cgi-bin...&I=LXN667&P=SM
And a Futaba servo
http://www3.towerhobbies.com/cgi-bin...?&I=LXDTB4&P=M
There's a bunch, look at sail plane servos there small but very strong, slimline there's a brand that sell mostly those but I can't think of it now there very pricey though.
Bruce
splinterz25 is online now Find More Posts by splinterz25
Old Oct 23, 2014, 05:28 PM
One step at a time......
Canada, BC, Courtenay
Joined Mar 2011
Now I get you! What I looked up was no where near the torques of these babies and cheap to boot!
I'm using mostly Futaba's and some HiTec's with 124 oz/87oz/57oz depending on my intended applications. Flaps/Rudder and Elevator with the higher torques and Ailerons and throttles with the lower torques. I do have some HS-81's that I may substitute for the ailerons, thanks to your suggestion of using two for each.
What do you plan to use to synchronize your servos?
bwigger is offline Find More Posts by bwigger
Old Oct 23, 2014, 05:51 PM
Baltimore MD USA
Joined Jan 2011
When I did the ELV w/ the rotary drives they worked fine w/ out any synchronizing at all; BUT SOMETHING YOU MAY WANT TO THINK ABOUT I'M using two RX's one on each side this saves on wiring / weight & headaches figuring out all those wires; and it's not slower and both move at the same time.
Bruce
For Sale P-38 Lightning 90'' for $199 richyan Aircraft - Fuel - Airplanes (FS/W) 10 Apr 08, 2011 11:53 PM
Sold Wing Mfg. 70" P-38 Lightning Short kit flying4food Aircraft - Fuel - Airplanes (FS/W) 3 Mar 29, 2011 09:23 PM
Build Log P-38 Lightning SSB (Slow Scratch Build) lessram Foamies (Scratchbuilt) 13 Jun 02, 2009 02:50 PM
Build Log Lil-Lightning P-38 Build nieb15 Foamies (Kits) 2 Mar 12, 2008 08:22 PM
