Old Jan 02, 2012, 02:07 PM
Jsutherland8 is offline
Find More Posts by Jsutherland8
ELECTRIC R/C
Jsutherland8's Avatar
Canada, ON, Woodstock
Joined Feb 2006
Mini-HowTo
FrSky 2.4 Ghz V8HT in JR XP6102 DUAL TX
Well here it is.......Dual 6102.......
This DIY 2.4 Ghz MOD went well, and it gave my old JR XP6102 a new life. The FrSky 8 channel, V8HT, is a ACCST, (Advanced, Continuous, Channel, Shifting, Technology), with a fast rebind and RX Failsafe System.
Though the XP6102 is only a 6 channel TX, it is a solid 72 mHz radio with 10 model memories, and a good LCD display, with lots of extra space inside. I have 2 of these JR units and like the feel and dependability. The Spektrum and JR; DSMX, and DSM2 are ok, but not the best. I looked at 5 other 2.4 Mod Systems and found the FrSky to be the best one to use, because of 3 areas; Failsafe, Rebind Time, and Price of a wide product range.
I tried to do the MOD with as little change to the TX as possible. So if in a few years there is a better MOD, I do not have a problem with extra holes. I may also backlight this radio, so I kept things away from the CPU and Display area. I got some nice macro pictures of the modifications, and will try to discribe all the steps to make the job easy.
Jsutherland8 is offline Find More Posts by Jsutherland8
Old Jan 02, 2012, 04:50 PM
ELECTRIC R/C
Joined Feb 2006
FrSky 2.4 Ghz V8HT in JR XP6102 DUAL BAND
The Radio, FrSky Mod Kit, 1 DPDT switch, two 2-56(x.5), two (x.375) screws (2 nuts, 2 fibre washers), some wire, and a bit of heatshrink tube, would be all there is to this project. The tools are; digital 6" Caliper, drill and #bits upto 1/4", soldering iron + solder, wire cutters and strippers, some hot glue and a gun, plyers, and screw drivers.
When I opened my JR XP6102 there was some yellow specks of dust on the back and botton inside the case. I found this to be solder flux that had fallen off the PCB. Most electronics has this resin cleaned off to pervent problems later. JR needs a lesson on QC.
Check to see that all things in the radio are ok and secure. Get a rough idea of where things are to go and the order of assembly. Measure twice and drill once.
After the battery is unpluged, the back is removed (6 screws), and the power plug PCB can be removed ( 1 screw). Set back aside for now. Unscrew the antenna and set it aside too.
I started with the bind switch and power LED board. Setting it on center between the JR logo and the sound vent. It worked well with socket head cap screws, to clear the vent sides. All holes are marked and drilled with a 1/16" (#52) bit to check location. The LED is a 3mm (#33) hole and the pushbutton switch is 3.5mm (#29).The screw holes are clearance for #2-56 (#47) or 2.15mm.
I cut all 3 wires 1/2" up going to the RF PCB, after marking the - (neg) wire with a black permenant marker. I would resolder the - (neg) wire back to the same spot, but for now it would get the PCB out of the way. Take off the RF BCP. (4 screws)(just loosen bottom 2)(antenna wire still attached)
Take care not to short out the Memory Battery on the top side of the Power Switch PCB.
I drilled both the 2.4 Ghz Antenna hole and Mode switch hole with (#1) drill. Make sure to predrill with a 1/16" or ~ (#52) bit. Switch hole size may vary. The antenna is as close to the back so it still points up, and the switch is 5.5mm or 0.215" oc to the edge of the 72 Mhz antenna hub, or to suit your switch for internal clearance.
Old Jan 02, 2012, 07:12 PM
ELECTRIC R/C
Joined Feb 2006
The DPDT MODE switch is a bit tricky to solder. One of those 3rd hand things works well to hold the switch just above the radio.
Pull up the Power Switch PCB and untwist the + and PPM wires from the - neg wire. Rought the 2 wires under the Switch PCB on the other side of the Beeper and up to case top so they can be soldered to the Mode Switch. Slide on some 1/4" long 1/8 heat shrink tube and solder to center poles of the switch, with + close to the side where the FrSky TX board is located. With the front case upsidedown the FrSky wires go to the bottom of the switch Red to + side and signal to PPM side.
Solder a 4" white and a 4" red wire to the top 2 switch terminals Red +, and white to signal side. these 2 wires will go to the 72 Mhz PCB on the 1/2" wires on the connector, red to red and white to white. The - neg wire with the black marker on it goes up where it did before and reconnects to the spot it was cut from, with a 3/8" long 1/16" dia. heatshrink to insulate it.
Insert the switch in the hole with a nut and lock washer on the inside, and a flat washer and nut on the outside. This will make so the switch is back for the back antenna (2.4) and forward for 72 Mhz.
I have a piece if 1/16" thick double sided foam tape under the FrSky board, but velcro will also work.
Bend excess wire as shown in picture, and secure.
I put 3/16" of 1/8" dia heatshrink on two 2-56x .375 screws and tapped two holes, for the screws. These hold back the FrSky PCB, and antenna wire, from getting too close to the gimbles or pot wires.
I also put hot glue on the 3 wires going off the RF board and on the open coils at the bottom of the RF board for stability. Some hot glue where the wire bends back beside the screw post, to keep it down.
One tie wrap went on the wires ontop of the FrSky's PCB. A drop of nail pollish on the top of the 5-56 nuts will heep them in place.
Fit the 2.4 Ghz antenna connector in, and the battery plug PCB, screw in the antennas and the case screws. Plug in the battery and Test it out.
Old Jan 04, 2012, 12:01 PM
ELECTRIC R/C
Joined Feb 2006
FrSky 2.4 Ghz V8HT in JR XP6102, DUAL BAND TX
I have resized some more pics of the FrSky 2.4 Ghz, DIY, MOD in the XP6102 and I will be upgrading my other XP6102 as soon as I can get a V8HT board in from HobbyKing. The big trick is to find the item IN STOCK and on sale when you want it.
The Resolution of 3072 for the V8HT is a funny number, 2^11=2048 and 2^12=4096, and 11 and a 1/2 bits makes no sence. This could be just a typo too.
I also had to resolder the LED on the PCB to get it to 90*, check yours for propper position.
Old Jan 10, 2012, 11:36 PM
ELECTRIC R/C
Joined Feb 2006
Well we here in Southern Ontario have had some good weather for the 2nd week of January 2012. So I got in some more testing of the V8HT in the XP6102 outside with 5-6*C daytime high. In Range Test Mode I get full, no jitters, control, and a super fast rebind when I turn OFF and ON the transmitter.
I can't wait for HK to get some more TX's in stock, so I can convert my other XP6102. The next DIY MOD for me will be a Fly Sky 9X with a FrSky telemetry TX unit. Lots of YouTube video on how to do this one, but I will try to show a How To for a switchable dual 2.4 Ghz TX and back light LCD too.
Old Jan 17, 2012, 12:23 PM
ELECTRIC R/C
Joined Feb 2006
The V8HT 2.4 Ghz Transmitters are in at HobbyKing. Got my order in today. I hope I get it before the end of the month, with their New Year Holliday lasting 2 weeks, it may be a bit longer.
This also gave me a chance to order a HobbyKing 6 ch V2 RX, so I can make a wireless USB simulator adaptor for the computer to work with the TH9X Radio system. To top off the order I got myself one of the Bomb Drob Kits with servo release. I may put this on the JUG, P-47 Thunderbolt so I can interchange it with a Drop Tank.
Old Jan 23, 2012, 03:19 PM
Airlady is offline
Find More Posts by Airlady
Airlady
Airlady's Avatar
United States, TX
Joined Jan 2012
I like your Creativity
I have a bunch of RC heli Recievers and been thinking of making use of them plus a few old rc Car ones
Very Kool post and Excellent pictures
Airlady is offline Find More Posts by Airlady
Old Feb 21, 2012, 12:48 PM
mmatheny is offline
Find More Posts by mmatheny
mmatheny's Avatar
United States, TX, Dickinson
Joined Mar 2003
Only thing I would change (and I plan on doing my 7CHP Dual) is use a slide switch for the 2.4ghz - 72 mhz mode switch - less possibility of hitting it accidentally!
mmatheny is offline Find More Posts by mmatheny
Old Apr 23, 2012, 08:00 PM
ELECTRIC R/C
Joined Feb 2006
They make a locking toggle switch that you have to pull up on the lever to through it. I find it takes too much time to get a nice clean rectangular hole filed in to a transmitter case. It is also hard to cover up if you take out the switch. A 1/4" hole is easy to fill with a hole cap, and looks ok if it is on the centre line, or off in a unseen area.
Looks like I may do an old 72 Mhz, 6EX with a V8 HT 2.4 Ghz module as a dual band transmitter. The ACSST has a better range and better priced RX's with failsafe. I am not a big fan of the FASST 2.4 system, for the price.
Old Jun 28, 2012, 07:05 AM
Kruzer1 is offline
Find More Posts by Kruzer1
Nall-ified Pilot
Joined Jul 2007
JSutherland8, very helpful with identifying the signal/gnd wire.
Did one last night and it's good to go.
Did not use the dual option though.
Thanks for posting your mod.
Kruzer1 is offline Find More Posts by Kruzer1
Old Oct 15, 2012, 05:37 PM
aeajr is offline
Find More Posts by aeajr
Proud member of LISF and ESL
LI, New York, USA
Joined Mar 2003
It has been a few months did you did this JR6102 conversion. Still happy with it?
aeajr is offline Find More Posts by aeajr
Old Oct 15, 2012, 06:55 PM
XtalHunt is offline
Find More Posts by XtalHunt
United States, TX, Austin
Joined Sep 2012
Geez. looks like a lot of work!
XtalHunt is offline Find More Posts by XtalHunt
Reply With Quote  (Disabled)
Old Mar 27, 2013, 12:36 AM
boogyman is offline
Find More Posts by boogyman
United States, CA, Folsom
Joined Jun 2006
another dual conversion
Another successful dual conversion here; wanted to say thanks for all the info -- I used the pics and info in this post to do the conversion on my jr xp6102 with the newer frsky dht. I also relocated the cr2032 battery backup so that i could replace it easily if needed. I used a DPDT switch to toggle power & signal between the 72mhz and the frsky 2.4ghz. For some reason, my 6102 no longer beeps when selecting items/adjusting trim/etc but both radio modes work great.
boogyman is offline Find More Posts by boogyman
Sold JR XP6102 Mode 1 Tx and Package in original box aussief3b Aircraft - General - Radio Equipment (FS/W) 1 Dec 20, 2011 01:17 PM
Discussion FrSky V8HT 2.4G + Hitec Neon SS _shadow_ Radios 28 Nov 18, 2011 01:35 PM
Discussion Upgrading Futaba T6XHs To 2.4 GHz With Frsky DIY V8HT Module? FXG DIY Electronics 14 Aug 27, 2011 04:21 PM
Help! Problem with FrSky V8HT DIY module in Futaba tx RobEm Radios 5 Mar 30, 2011 11:21 PM
Discussion Connecting a tx in 2.4 ghz to a Rx in 1.2 ghz catamar FPV Talk 1 Dec 29, 2010 03:30 PM
