Old Jul 23, 2014, 06:28 AM
United States, NY, Rochester
Joined Jan 2006
New Product
GHT EZ-GIMBAL PRO - NEW 3-axis
I just received the new Grouse House Technologies EZ-Gimbal PRO and in
my estimation, it has incorporated a nice combination of upgrades to the
original EZ-Gimbal. GHT always seems to take into consideration many
of the customer comments regarding improvements in their products
design.
LINKS:
http://www.grousehousetechnologies.com/
http://www.rcgroups.com/forums/showt...=GHT+EZ+Gimbal
Papajeff is offline Find More Posts by Papajeff
Old Jul 23, 2014, 08:54 AM
Joined Apr 2007
Nice, the only thing it is missing is a zoom function.
Do you have a weight as it is on the pictures?
That would be perfect for me as I want it front mounted - no need for a 3rd axis with a X8.
tritan is offline Find More Posts by tritan
Old Jul 23, 2014, 11:08 AM
Joined Jan 2006
The EZ-Gimbal Pro came pre-assembled, but it was in sections that just needed
some basic putting together. Each section was individually wrapped properly
and included all the necessary screws & bolts in little individual bags.
The pitch/roll assembly continues to be reinforced with narrow CF plates top and bottom
of the two backplates and both of the side arms have been lengthened. In addition the
balance adjustment slots now have rule markings so that once your camera has been
successfully balanced, it can be removed and relaced to the exact perfect balance position.
Also notice in the photos, that the roll and pitch motors are now LD Power 4008 hollow
shaft which will make wire routing much easier and neater.
Old Jul 23, 2014, 11:55 AM
Joined Jan 2006
For the gimbal mount I went with the Lightweight 2-axis with the 3rd axis
upgrade, with the hollow shaft 5208H-180T motor and slip ring.
http://www.grousehousetechnologies.c..._11873562.aspx
Notice that the Lightweight mount now includes an accessories tray for not only connecting
your gimbal control board but any other relevant device(video Tx, OSD, 12V UBEC etc.)
Old Jul 23, 2014, 12:12 PM
Joined Jan 2006
For the Interface, I thought that the 59/12mm, 4 grommet, 16 damper would be
the best option for my Tarot 690S that I have modded to be about 800mm and
lengthened the legs by 5" to accommodate this EZ-Gimbal Pro.
http://www.grousehousetechnologies.c..._11918208.aspx
Old Jul 23, 2014, 12:16 PM
Joined Jan 2006
I almost forgot that included with the EZ-Gimbal Pro are 2 different length
camera mount plates and both have the rule markings.
Old Jul 23, 2014, 12:19 PM
Joined May 2014
Is this pro versions just upgrades on the original or does it accommodate larger cameras as well, say a gh4?
bumninja is online now Find More Posts by bumninja
Old Jul 23, 2014, 12:36 PM
Joined Jan 2006
GHT has also added some other new upgrades;
1. A small CF plate on the pitch back plate for mounting the sensor.
2. The vertical slider length has been increased to allow for more depth to
accommodate some of the slightly larger cameras than the NEX, such as
the GH4.
3. The width of the camera cradle has been increased by another 2.5mm
to also allow the use of slightly larger cameras.
4. A grommeted pass through hole in the arm to route the pitch motor wires.
Old Jul 23, 2014, 01:00 PM
Joined May 2014
Thanks for the info and I look forward to more review after you have it mounted.
BTW I could not find the Pro model on their website. Is it not listed yet?
Seydou is offline Find More Posts by Seydou
Old Jul 23, 2014, 01:03 PM
Joined Jan 2006
I believe that all the weights of the various gimbals and options can be found
on the GHT web site;
Old Jul 23, 2014, 01:05 PM
Joined Jan 2006
I do believe that the Pro will accommodate a GH4.
Old Jul 23, 2014, 01:08 PM
Joined Jan 2006
I just checked the GHT site and it is not listed yet, but I did find a reference on
the GHT Facebook page;
Old Jul 24, 2014, 01:51 AM
Joined Apr 2007
Is there a price available yet?
Old Jul 24, 2014, 06:22 AM
Australia, NSW, Sydney
Joined Mar 2006
There will be a price as soon as the Pro is ready to put up for sale. The one PapaJeff is using is a prototype. The final one will be using a larger roll motor and larger mount for the GH4 size camera's. Just waiting for these roll motors to arrive in Australia from the USA. Said it left LAX on the 14th and still nothing. I can't move forward with this till I get them.
Sorry people!
eheheh is offline Find More Posts by eheheh
Old Jul 25, 2014, 08:38 AM
Joined Apr 2007
Ok John,
thanks for info.
Build Log 3-Axis GHT EZ-Gimbal Build Guide Papajeff Multirotor Talk 340 Aug 07, 2014 12:47 AM
Discussion ARRIS CM3000 PRO 3 Axis Brushless Gimbal for GoPro 3/3+ myrcmodel Multirotor Talk 13 Jul 06, 2014 06:50 AM
For Sale Tarot T810 + GHT Ez Gimbal (Reduced price, first come first serve!) KevinJoel Aircraft - Electric - Multirotor (FS/W) 4 Jul 02, 2014 11:41 PM
For Sale ARTF T810 Hexacopter + GHT EZ Gimbal (Priced to sell!) KevinJoel Aircraft - Electric - Multirotor (FS/W) 0 Jun 29, 2014 04:44 PM
Discussion Pros and Cons of 2-axis/3-axis gimbals? mongdex Multirotor Talk 6 Feb 03, 2014 06:57 PM
