Old Nov 10, 2015, 01:46 PM
ekips357 is offline
Find More Posts by ekips357
AKA : NOCOMSTUDIO_FPV
Joined Oct 2014
I've burned a HS1177 cam, please help me !
Hi every one,
i've simple burned my new HS1177 cam ( 5-22V) , after a really good FPV session, i come back to home and connected my quad on USB without propeller to calibrate again my ESC and change a little my PID, i've connected my lipo 4S ( fully charged ) and i've try some armed disarmed to check motors and when i play with throttle little burst ( 50%) white smoke just came off the HS1177 body ....
Inside there is a component that is fry , it's a 511Q1 AZ00 like a little step down with 3 pins each side, the middle one of one side is burned ...
My setup was 4S lipo to a PDB, and the cam was directly powered from the lipo 16,8V
Edit : when throttle acceleration during flight, there was some line on the image, more throttle % was = to more noise on the image so i wanted to try powered from the pololu 5V step down that i have oh the quad.
someone can tell me what have gone wrong ?
ekips357 is offline Find More Posts by ekips357
Old Nov 10, 2015, 01:56 PM
derelicte is offline
Find More Posts by derelicte
Joined Aug 2006
good news and bad news!
bad news: it sounds like the camera is dead. even if you replace the regulator there is no guarantee that something else is bad or will fail at a later time.
good news: the hs1177 is on sale today for $30 so replacing it won't be as expensive!
derelicte is offline Find More Posts by derelicte
Old Nov 10, 2015, 02:09 PM
ekips357 is offline
Joined Oct 2014
i've buy a new one at 30$, but i really want to understand what happended, why was it working on FPV flight ( even with noise ) and burned on motor test without prop and USB on on cleanflight .....
Old Nov 10, 2015, 02:16 PM
Made in Austria is online now
Find More Posts by Made in Austria
Made in Austria's Avatar
United States, NV, Las Vegas
Joined Dec 2013
Hard to tell what happened. To the lines in the image, you need an LC Filter between the battery and the cam to filter all the noise out that are caused by the ESC's, motors, etc.
Made in Austria is online now Find More Posts by Made in Austria
Old Nov 10, 2015, 02:25 PM
Joined Aug 2006
if your vtx has a 5v output, try powering the camera with that.
Old Nov 10, 2015, 02:42 PM
ekips357 is offline
Joined Oct 2014
I've tried that first, but the vtx output is more 4V than 5v so the camera was not correctly powered
Old Nov 10, 2015, 02:54 PM
Joined Aug 2006
too bad.
Old Nov 12, 2015, 08:46 PM
acegunn is offline
Find More Posts by acegunn
United States, IA, Cedar Rapids
Joined Mar 2013
Had the same thing happen to my HS1177 powering directly from 4S. Looks like the same component fried, 6 pin regulator, but it was labeled 437P3 AZ00.
Worked fine one day, then was dead the next. I've sent a message to Surveilzone. We'll see what they say.
I plan on using a 12V pololu for both camera and vtx from now on.
acegunn is offline Find More Posts by acegunn
Old Nov 13, 2015, 02:56 AM
ekips357 is offline
Joined Oct 2014
Two guys on the Alien thread have got exactly the same problem.
I've contacted surveillzone, they will try to improve this regulator on the hs1177 because it is very sensible.
They send me a new one for free
Old Nov 13, 2015, 12:44 PM
dirtdiverfpv is offline
Find More Posts by dirtdiverfpv
Joined Aug 2015
Same issue happened to me just now. On my bench, testing vTx range issue I've been having, arming and disarming while checking my goggles, the HS1177 wired directly to Alien PDB, then poof. Magic smoke released.
Super bummed out. First I have crap range on the new Alien frame, now I'm unable to fly at all
dirtdiverfpv is offline Find More Posts by dirtdiverfpv
Old Nov 13, 2015, 01:58 PM
Joined Dec 2013
Looks like the voltage regulator in this cam sucks. I ordered this cam a few days ago. No way I mount this cam in my copter. I will shelf it when it has arrived.
Old Nov 14, 2015, 12:30 PM
acegunn is offline
Joined Mar 2013
I sent a message to SZ through their web site but haven't heard anything back yet.
Did you contact them through the user area, or send them an email?
thanks
Old Nov 18, 2015, 12:12 PM
SurveilZone is offline
Find More Posts by SurveilZone
Joined Sep 2013
thanks
Sorry for any inconvenience.
We've tested the cameras before shipment. If it is defective or DOA, pls contact us and we will have it solved.
Please send email to info@surveilzone.com, we will reply as soon as possible.
SurveilZone is offline Find More Posts by SurveilZone
Old Nov 18, 2015, 02:18 PM
ekips357 is offline
Joined Oct 2014
thanks
i'm a little late but it's cool that SZ is on Regroups keep us informed !
I've received the new one, powered with the pololu 5V 500ma SD that also power my naze32 everything is working fine, i've only some diagonal line on the video
Old Nov 19, 2015, 09:50 PM
Enginerd1 is offline
Find More Posts by Enginerd1
United States, CA, San Diego
Joined Jan 2014
Anyone know the spec for this component? I assume the first number is some sort of batch or manufacturer identifier but don't get any hits on AZ00 regulator at DigiKey but I'm no electronics expert. Looks like it might be a DC converter, maybe getting closer. Just hate to loose a $36 buck camera over a part that costs a few cents. Yes other things could be damaged, but worth a shot for a buck or two unless Surveilzone wants to honor an exchange for two cameras purchased through one of their re-sellers.
Enginerd1 is offline Find More Posts by Enginerd1
Discussion xuav-SKUA+PIXHAWK-Pleas help swar Beginner Training Area (Aircraft-Electric) 0 Jun 24, 2015 08:20 PM
Discussion xuav-SKUA+PIXHAWK-Pleas help swar Electric Plane Talk 0 Jun 24, 2015 08:14 PM
Discussion burn msp430f1232 of cellpro 4s , help me rc my life Batteries and Chargers 3 May 27, 2014 09:30 AM
Help! Mcpx brushless conversion PLEAS HELP ME Newbie77 Beginner Training Area (Heli-Electric) 3 Nov 19, 2013 06:35 AM
Discussion Pleas Help me with walkera 36 WK-0701 Tx kaushiksad Simulators 1 Dec 03, 2007 07:26 PM
