Old May 21, 2015, 10:00 AM
BobTBuilder is offline
Find More Posts by BobTBuilder
Joined May 2015
Control Ronin from Potentiometer
Hi,
I posted this elsewhere on the forum but thought it might be better here as it's more of a DIY project...
I'm hoping someone might be able to help me here. I am trying to control my DJI Ronin from a potentiometer. So for example, if I move the dial 90 degrees to the left, the Ronin moves 90 degrees to the left - Much the same way as a servo works.
I have snippets of information but to all intents and purposes, lets just assume that I'm a noob
I'm using a Turnigy er9x but I'm happy to move to a different controller. We have an s-bus module arriving but I know that the potentiometers on the er9x will send out a speed signal and not a proportional signal. So the question is, is there any way to send out a proportional (stick position) signal via the er9x so that the Ronin will understand it?
Any help would be greatly appreciated!
Thanks, Bob
BobTBuilder is offline Find More Posts by BobTBuilder
Old May 23, 2015, 04:02 PM
Joined May 2015
Old May 23, 2015, 05:26 PM
srnet is offline
Find More Posts by srnet
Stuart
srnet's Avatar
UK, Cardiff
Joined Dec 2008
You might want to help people to help you by explaining what you mean by;
"DJI Ronin"
What is it ?
srnet is offline Find More Posts by srnet
Old May 24, 2015, 02:34 AM
slipstick is offline
Find More Posts by slipstick
Staffs, UK
Joined Nov 2003
I had a quick google and discovered it's apparently some sort of complex camera gimbal system. But I couldn't get any clear idea of how it's normally intended to be controlled which makes it difficult to suggest how anyone might change the way it's controlled .
Steve
slipstick is offline Find More Posts by slipstick
Old May 25, 2015, 08:03 AM
Joined May 2015
This is the DJI Ronin
DJI - Introducing the Ronin (4 min 12 sec)
Old May 25, 2015, 08:06 AM
Joined May 2015
It has a 2.4ghz transmitter plus it takes an s-bus input for 3rd party controllers. It also has an IMU port but I can't find any info about what it's for...
Discussion Control Ronin from Potentiometer BobTBuilder DJI-Innovations 1 May 23, 2015 04:00 PM
New Product New Potentiometer Board from ServoCity ! ServoCity Product Announcements 0 Apr 21, 2015 05:01 PM
Discussion Modifying a TX channel for potentiometer control luckyflyer DIY Electronics 3 Aug 10, 2007 06:58 AM
Discussion How to control a ESC by DC voltage(like from a potentiometer or microcontroller DAC)? dispatch DIY Electronics 1 Aug 10, 2006 03:55 PM
Multiplex control potentiometer Highflight Radios 4 Feb 25, 2004 09:26 AM
