Old May 25, 2015, 11:30 PM
RyoOhki1701 is offline
Find More Posts by RyoOhki1701
Counting Cubs
RyoOhki1701's Avatar
France, IdF, Paris
Joined Feb 2013
Originally Posted by Wamp View Post
Also humidity or rain.
Unless you use waterproof, it will melt or creep.
My buddy lost a 1/4 scale Sopwith Pup at Rhinebeck over rain.
Although covered some rain got in, ran down to the tailskid and all looked good.
The tail feathers failed up there
I indeed used a waterproof one
RyoOhki1701 is offline Find More Posts by RyoOhki1701
Old Jun 18, 2015, 08:41 AM
michaelpowell is offline
Find More Posts by michaelpowell
Joined Sep 2010
I have three of these now: one new, one flying, and one being repaired. They break only when I break them, I remain the weakest link in the chain. Even my five-year-old grand daughter, Eve, has them licked, it's the sweetest flying "full-house" in the business. My glow-plug chums are being converted, albeit slowly.
Gentleman Phil Kraft did a lot of good, he'd have been knighted decades ago if it was down to me, but the Das Ugly Stik clan was his best effort. I've still got six in four different sizes and all fly brilliantly. Thank you, Sir Philip!!
Just as everyone who enjoys cars should own an Alfa-Romeo, so should everyone in this hobby own a Stik. This one is good. If only Graupner would revive their Middle Stik, I'd be delighted. It was brilliant, but the sniggerers killed it.
michaelpowell is offline Find More Posts by michaelpowell
Old Jun 20, 2015, 04:24 PM
cwolfe is offline
Find More Posts by cwolfe
cwolfe's Avatar
United States, TX, Spring
Joined Aug 2011
Originally Posted by michaelpowell View Post
Just as everyone who enjoys cars should own an Alfa-Romeo, so should everyone in this hobby own a Stik. .
Agreed!
CW
cwolfe is offline Find More Posts by cwolfe
Old Jun 27, 2015, 12:53 AM
Counting Cubs
France, IdF, Paris
Joined Feb 2013
The heat is on - we're looking at 95F+ temperatures next week (not sure I've seen such high temps in my whole life over there), maybe just 84-85 this Sunday but the Ultra Stick will definitely tag along to the field. We'll see if and how the pegs hold !
Old Jun 27, 2015, 06:21 AM
Wamp is offline
Find More Posts by Wamp
Wamp's Avatar
Joined Mar 2012
I made note of ground effect conditions starting around there, on pavement landings can get squirley! Have fun!
Wamp is offline Find More Posts by Wamp
Old Jun 29, 2015, 01:23 AM
Counting Cubs
France, IdF, Paris
Joined Feb 2013
So far so good - the plane was a lot of fun and came through the five LiPos I had brought unscathed. Good thing the motor is outside the fuse too, it was hot yesterday afternoon. The wing pegs held tight but the covering blistered here and there. Nothing too serious some ironing can't fix.
A serious mistake from my part could have ended in a disaster though... Always looking for the reason my plane needed aileron trim I had worked on both flap servos thinking one was maybe sitting a bit off center, and one definitely had play, so I had replaced the control rod with assembly with a new one.
This had been weeks ago and apparently I had forgotten to secure the servo arms back in place...
The flaps did operate normally on the ground during the pre-flight check, but unbeknownst to me, the arms did a quick run for the hills once airborne! My luck was that I flight tested the flaps during a slow pass with some water under the keel. It had been a good flight up until now but something felt not so good when instead of gently slowing down and pitching up slightly, the plane engaged in a hard banking roll. Cripes!
I had time to retract the flaps and level the plane before it rekitted itself on the landing strip, and could proceed to land normally... Found one control rod hanging from the flap horn with the servo head screw missing, and the other still partly engaged with the screw hanging by nothing but a thread.
BIG time failure for me there (I'm usually paranoid about pre-flight checks...) and a lesson learned. It could have been the ailerons, and then...
Luckily I could finish the afternoon by removing the flap rods and taping the flaps to the ailerons! Ugly fix
Old Jul 02, 2015, 03:17 AM
Joined Sep 2010
Happy Again
I now have three 25e Ultra Stiks operational!! A quick blast with epoxy resin got the two duffers back looking fine, and when I come to take one from the van it's difficult to tell them apart.
And as it's now a half century old, the design got a decoration.
Old Jul 08, 2015, 05:47 PM
Wamp is offline
Wamp's Avatar
Joined Mar 2012
I thought the 25e was gone.
Back in stock at Horizon @$169.99.
One I don't want to be with out!
Wamp is offline
Wamp's Avatar
Joined Mar 2012
Cool work!
Old Jul 09, 2015, 05:09 PM
Wamp is offline
Wamp's Avatar
Joined Mar 2012
My buddy finally tried a 4 cell with the 32 and 12X6.
What a wake up.
Now he is hooked!
Old Jul 13, 2015, 06:28 PM
cwolfe is offline
cwolfe's Avatar
Joined Aug 2011
What a wake up.
Now he is hooked!
Yeah, It's got a bit of gt up and go with that set up. I'm on a 12x8 with that set up.
CW
Old Sep 11, 2015, 06:03 PM
griceluke is offline
Find More Posts by griceluke
Joined Sep 2015
help with power and prop
hello everyone, iv just acquired an US from someone
Bargin @ 60 with 1 battery, 4 hitec servos, Motor and Prop...
Problem is it lacks power after my first flight with it. Please can someone look at what I have detailed below and tell me what size Prop i need on this thing... i dont understand much about the technical side of the electric lark
Thank YOU in advance !!
Motor on (http://www.hobbystores.co.uk/default...=M-KMSQ2814/06)
KV Rating: 1290
LiPo: 2-4 cells
Max Current: 32A/60S
Max. Continuous Current: 24
Power: 300-400W
Propeller Range: 9.5 x 5, 9 x 6, 10 x 4.7, 10 x 5
CAME with a 10X5 propeller......
Came with a 4500 Tipple 3 cell Lipo
Told me it is a 40amp ESC
what should i change ?
griceluke is offline Find More Posts by griceluke
Old Sep 12, 2015, 02:11 AM
Counting Cubs
France, IdF, Paris
Joined Feb 2013
I would change the motor. Being rated for 24A continuous it will not be very powerful on 3S... Assuming it's giving all it can within the safe operational range it would be rated for something like 270W on 3S (24A times 11,5V => rough estimate of the voltage at the LiPo while at WOT), and that's only the power absorbed. The mechanical output will be even lower.
The advertised 400W can only be achieved on 4S.
It's probably a good motor to fly the Stick on 3S as a trainer but NOT for having fun with it. My own Stick is flying on 3S but with a heaviest motor which can take 40A continuous (and I'm nearly there at WOT). It goes vertical.
Alternative, get a 4S battery, a 9x6 prop (you'll need to downprop to not overwork the motor on 4S) and see what it does. Also a wattmeter to check your figures.
Old Sep 13, 2015, 09:55 AM
Wamp is offline
Wamp's Avatar
Joined Mar 2012
KV Rating: 1290
LiPo: 2-4 cells
Power: 300-400W
Since you have nursed a .25 size plane around the sky with a .15 power system, you have some skills!
Your motor has a fairly high KV. KV times volts =s RPM
Going to a 4 cell will bump up the speed, and perhaps relagate dropping prop load.
PLF prop load factor dia squared times pitch.
My intuitive take is a short prop will not get good air flow over the control surfaces.
This is fine for fast clean planes were air speed is kept up and landings are hot.
US is , strangly, cleaner than it looks.
A 40 A system seems small. Being used to 'get out of trouble' power I opted for a 60A. System.
Personally I would swap out your motor and esc for safety.
Mean while, I would ignore the prop chart, stay 3 cell and see what an 11X5.5 does for UL.
You have a great amount of cooling air with the motor hanging out there and a big box of air to keep the esc and battery cool.
Looking forward to flight reports.
Chris
Old Mar 05, 2016, 10:43 PM
spercelay is offline
Find More Posts by spercelay
United States, TN, Clarksville
Joined Mar 2016
Has your Ultrastick sold yet?
I am in Clarksville , very interested in the ultrastick. Is it still available?
spercelay is offline Find More Posts by spercelay
Question E-Flite Ultra Stick 25e parts ID? keninaz Electric Plane Talk 5 Oct 15, 2013 07:16 AM
Wanted Crashed E-flite Ultra Stick 25e and Mini Ultra Stick for parts westerman Aircraft - Electric - Airplanes (FS/W) 2 Mar 10, 2013 08:09 PM
Article E-flite Ultra Stick 25e 50" ParkFlyer Electric ARF Review rc2xs Sport Planes 29 Jan 16, 2010 03:56 PM
For Sale E-Flite Ultra Stick 25e Basicly brand new. litespeed Aircraft - Electric - Airplanes (FS/W) 0 Mar 31, 2007 12:49 PM
Wanted E-Flite Ultra Stick 25e killerstick Aircraft - Electric - Airplanes (FS/W) 2 Dec 14, 2006 07:22 AM
