Comparison of Ground Control software
Someone (Bart?) was so kind as to put this comparison together http://biapalmeiro.github.io/gcs/GCSBenchmark.pdf
Any comments? Which GCS do you use, and why? |
I use Mission Planner because it works on all my devices and does everything I need. It's very easy to use - that's the main reason I will continue to use it. Updates parallel Pixhawk firmware development so all the new features are available immediately.
I recently started using a Pixhawk based antenna tracker. The Mission Planner will link to both my airplane and antenna tracker simultaneously. It creates logs for both. Not sure if the others will do that. . |
