Old Feb 21, 2014, 10:47 AM
Joined Feb 2014
Thanks!; that is what it looked like "reverse-engineering" it. Does the control arm then "float" up if the strut is compressed?
jeffs117 is offline Find More Posts by jeffs117
Old Feb 21, 2014, 10:51 AM
Joined Feb 2014
No problem Flyer!
Old Feb 21, 2014, 04:24 PM
Hamburger Eatin' Fool
TomCrump's Avatar
Traverse City, Michigan
Joined Dec 2005
Yes.
You'll have to try different springs until you get the desired tension.
TomCrump is offline Find More Posts by TomCrump
Old Feb 24, 2014, 06:29 PM
Joined Feb 2014
I started building the tail wheel assembly this weekend. I purchased 3/16 brass rod for the yoke, 1/4 in. brass rod for the strut and 9/32 brass tube for the bearing shaft. The spring is from Ace Hardware and will compress enough to absorb a significant landing (hope to never test it though).
Fortunately, I was able to get some help from our A&P mechanic and drilled a #11 hole in the 1/4 in. brass for the yoke. The yoke was formed around a piece of steel round they had sitting around.
After forming the yoke, It was inserted in the strut and then soldered in place. The assembly is very strong at this time and should have no issues. I will solder the spring retainers (washers) on this week and trim the strut and yoke arms.
Our mechanic also ordered a piece of 7/8 in. aluminum round to make the RDS couplers. He has a machinist who can turn them in no time.
Old Feb 25, 2014, 04:14 AM
TomCrump's Avatar
Joined Dec 2005
You have a nice start on the tail wheel assembly.
Old Feb 25, 2014, 08:43 AM
Expert in sawdust production
flyerinokc's Avatar
United States, OK, Oklahoma City
Joined Aug 2007
I want to see this finished tail wheel it is already looking great!
flyerinokc is online now Find More Posts by flyerinokc
Old Feb 25, 2014, 03:51 PM
TomCrump's Avatar
Joined Dec 2005
I think he should send it to me, for approval.
Old Feb 26, 2014, 06:35 PM
Joined Feb 2014
LOL! I will certainly do that Tom! I soldered the washers on the assembly to retain the spring today. Just a note, don't use the brass strut to hold the washer to the bearing tube; use a wood dowel!
I will work some more tonight on the empennage (had to say it since it was beat into me during flight training) and build the support for the rudder servo. I picked up some 1" brass strips to secure the servos. Should have the RDS couplers turned this week and the remainder of the balsa to work on the fuse.
Old Feb 26, 2014, 07:19 PM
TomCrump's Avatar
Joined Dec 2005
Empennage?
I like big words.
Old Feb 26, 2014, 07:32 PM
wood is good
loNslo's Avatar
United States, CA, Marina Del Rey
Joined Jun 2012
Those Frenchmen again.
loNslo is online now Find More Posts by loNslo
Old Feb 27, 2014, 09:26 AM
flyerinokc's Avatar
Joined Aug 2007
Blame the Wright Brothers, if they hadn't been so secretive and so aggressive in patent enforcement to the point of trying to stop anyone else from build aircraft in the USA the French would not have taken the lead in aircraft development and named everything. We're just lucky Congress stepped in when they did and forced them to sell the patents to the government.
Old Mar 26, 2014, 08:22 PM
Joined Feb 2014
I'm finally back; I have been all over the Midwest on business lately and could get back to my build room. I have completed the jigs and will post them shortly. Stick balsa and bass have arrived so I will try to get fuse inner frame together this weekend.
RDS should be done soon also so I can start working on completing rudder assembly.
Old Mar 27, 2014, 10:24 AM
flyerinokc's Avatar
Joined Aug 2007
Jeffs117, buddy you are working way too hard and not on the airplane! Blame your parents, it's their fault you born so darn good looking instead of rich as h*ll!
Old Mar 27, 2014, 01:06 PM
Joined Feb 2014
That's funny!!! Unfortunately my biz can be sporadic with little warning as to when and where I need to go someone. Lately, I've had some place to go everyday so I'm ready for a break.
I just got "volunteered" for a training seminar to show how quads or "drones" as everyone else calls them can be used so I guess that is going to take a little of my time as well.
Here are some upside down images of my magnetic jig fixtures. I've tried to rotate them but the coding in the forum is not accepting the changes I made.
Old Mar 27, 2014, 04:12 PM
AMA 910957
EJWash1's Avatar
United States, WA, Hoodsport
Joined Mar 2008
Jeff,
If you have to build on the ceiling, you need a bigger shop!
EJ
EJWash1 is online now Find More Posts by EJWash1
3-View of Cessna 195 Wanted Dave Moore Foamies (Kits) 6 Jan 25, 2010 09:48 PM
GUILLOW'S CESSNA 172 SKYHAWK conversion to electric. reznikvova Parkflyers 25 May 03, 2008 12:56 AM
Discussion Cessna 195 E conversion Rich Uravitch Scale Kit/Scratch Built 12 Feb 20, 2007 03:37 PM
Wattage Cessna 195 Robert Stinson Parkflyers 44 May 06, 2005 12:31 AM
Discussion Wattage Cessna 195 gearup Scale Kit/Scratch Built 1 Jan 21, 2004 05:37 PM
