Old Jul 15, 2006, 06:49 AM
Joined Jul 2006
f-14 tomcat
hi guys i am a new user here but i have been around here for a while and i have a question...im building the 6mm fly rc tomcat kit and the airframe is almost completed but mine will have retracts and a few other scale items such as external fuel tanks and wing missle pylons,so my overall weight is going to be 38 to 42 oz... ..i am using the wemotec microfans,and himax 2025-5300s...now heres my question..the thrust according to motocalc is 9 to 10 oz of thrust per fan on a 3spack at 17 amps...so thats just enough thrust to get her in the air..but if i was to run a 4s pack per fan instead of 3s thrust goes up to 16 oz and 26 amps...now the motors according to himaxs Jravis,the motor will take the 60600 rpms,and the 26 amps that the 4s will make ...so..all i reall need is an answer..yes the motor,fan combos will handle the 4s pack and live to fly another day, or no...batts will be the thunderpower 2100 mah 4s .per motor...or will the 3s be enough...thanks alot and what a wonderful site.. ..\stumpy
stumpy777 is offline Find More Posts by stumpy777
Old Jul 15, 2006, 06:08 PM
Joined Jul 2006
can someone please help me with this i have both batt packs now but i dont want to do it untill i have a decent answer...soo all i need to know is if the himax 2025-5300s in a wemotec microfan will run on a 4 cell set up..?..or will the 3s be enough...edf gurus.....help..thanks....stumpy
Old Jul 15, 2006, 08:42 PM
Idle up!
PLATINUM's Avatar
USA, VT
Joined Nov 2004
max amps 25
max watts 175
max rpms 60k
PLATINUM is offline Find More Posts by PLATINUM
Old Jul 16, 2006, 07:36 AM
Joined Jul 2006
Hi Stump...
My foamy, profile, F-14s (19" to 41" WS, and sub 2oz to 10oz) fly with just a hand launch with 50% thrust to weight. They do not do loops from level flight, but are rolling fools, with just tailerons...
All but the 19" one, are one or more GWS "40" ducted fans, and are running on 3s...
Bob
. ComeUpHere
Bob C. Reynolds is offline Find More Posts by Bob C. Reynolds
Old Jul 17, 2006, 04:56 PM
Ed Waldrep's Avatar
Las Vegas, NV
Joined Dec 1996
On Thunderpower Gen2 lipos (the generation before the newer Prolites) my 2025-5300 pulled in the low to mid 20s on 3S. Say 23 amps at the start. So much so that sometimes the castle phoenix 25 would shut down on first startup because of the high voltage, but if I backed off a few clicks for the first few seconds it would settle. It'll probalby be about 25 amps on prolites for the first few seconds, maybe more, settling to over 20. 4S would be too much I think, unless you flew smaller cells and got a lot of voltage drop. Now that was one motor, keep in mind, not two. You'd need two packs with a twin of course, or one larger pack.
Ed Waldrep is offline Find More Posts by Ed Waldrep
Old Jul 20, 2006, 05:58 AM
Joined Jul 2006
thanks alot guys..mr kevin cox solved all my problems...im building the jetset tomcat but im adding a few other things scale but no retracts,that'll put me over the 45 oz limit..kevin said that she should fly fine from a handlaunch and im also glassing her too...thanks again and pics and a flight video will be up soon...stumpy
F-14 Tomcat Sound Effects Keychain jamin Aircraft - Fuel - Airplanes (FS/W) 1 Feb 22, 2003 02:33 AM
F-14 Tomcat plans EDF for sale bipeflyer Aircraft - Electric - Airplanes (FS/W) 2 Jul 31, 2002 08:10 AM
Plans for sale,Parkflyer Tiger Moth,F-14 Tomcat twin EDF bipeflyer Aircraft - Electric - Airplanes (FS/W) 1 Jan 16, 2002 11:57 AM
F-14 Tomcat EDF,pictures and questions bipeflyer Electric Ducted Fan Jet Talk 13 Jul 14, 2001 06:10 PM
