Old May 06, 2014, 05:52 PM
Should've, Would've, Could've
v8truckin's Avatar
United States, CA
Joined Dec 2010
Originally Posted by Frankensteen View Post
I'm using the RCL Cougar retracts Set in mine, and tho' heavy they look and work well.
60 -120s are way overkill for this jet. 25-46 E flites would be perfect IMO.
If you decide to sell your 120s, sold! I'm looking to replace the crappy RCL units on my 13lb+ RCL T33.
Ya figured they woukd be overkill, wasnt sure what the end weight would be on 6s. Ive got a spare set of freewing e-tracts I can drop in. The 60-120 are spares for my 1.7m P51 & P47 , so imma hold on to em.
Originally Posted by turbonut View Post
Yea the 60 120 are way over kill
Thx for the reply
v8truckin is online now Find More Posts by v8truckin
Old May 06, 2014, 10:52 PM
Ken W
ken willis's Avatar
United States, UT, Ogden
Joined Dec 2009
I used the 25 -46 eflite with two inch wheels and they fit perfect and retract fully
ken willis is offline Find More Posts by ken willis
Old May 06, 2014, 11:54 PM
v8truckin's Avatar
United States, CA
Joined Dec 2010
Is your nose retract also a 25-46?
Old May 07, 2014, 08:57 AM
Ken W
ken willis's Avatar
Joined Dec 2009
yes it is . It sticks down alittle because the casing on the nose gear is a bit larger than the mains. It works very and the nose wheel is 1 3/4 inches
Old May 07, 2014, 09:06 AM
v8truckin's Avatar
United States, CA
Joined Dec 2010
I got spare tricycle set of these so ill use em, they weight 48g with pin.
http://www.toysonics.com/digital-ser...5091m-1pc.html
Old May 07, 2014, 04:36 PM
Ken W
ken willis's Avatar
Joined Dec 2009
You will like the fit. You have to dremel the edge of the wood so the piano wire will fit other than that its a piece of cake
Old Jul 07, 2014, 06:37 PM
Joined Nov 2007
Does anyone have a set of Used Electric retracts for sale that would work on the Cougar ?
itsparks is offline Find More Posts by itsparks
Old Jul 07, 2014, 08:31 PM
Electrified User
Ashveratu's Avatar
United States, MD, Aberdeen
Joined Aug 2012
PM has been sent with link to pictures.
Ashveratu is offline Find More Posts by Ashveratu
Old Jul 18, 2014, 05:57 PM
Joined Apr 2008
Flight test results
Maidened mine yesterday and more flying today. I like, but lots of issues to be aware of and ways to overcome them.
Since mine is the PNP RTF version, I'll report results, necessary mods, amps, CG etc , on that thread.
You can find it here http://www.rcgroups.com/forums/showt...9#post28939339
Big question I have for all you who have gone before with the ARF version, is have you experienced any wing rocking, wobbliing or wagging, as I have.
My CG is at only 90mm to keep the nose on the ground given the Cougar's design defective main gear location. Wing wobble at medium speed--a very noticeable problem--got better when I moved the CG back from 80 to 90, but its still serious. I guess the problem is the cg is still too far forwatd which means I could solve it only by moving the entire landing gear structure back (forget that) or buying trailing link mains to counter the design defect. See my posts for details on this.
softshell29 is offline Find More Posts by softshell29
Old Jul 19, 2014, 12:17 AM
v8truckin's Avatar
United States, CA
Joined Dec 2010
thanks! totally what ive been waiting for. Ive had mine on the bench for a few months and havent progressed much due to time, parts, and build info/point of views. I have all parts now for a 6s setup, but am contemplating a 8s setup, but that requires more $$$ and weight.
Old Jul 31, 2014, 01:39 AM
MADISONMaster's Avatar
France, Burgandy, Dijon
Joined Jun 2010
Hey guys got a video. This is a fast jet and that works for me. http://youtu.be/rgSRciN7sEU
Hello ken willis
I have not started building my Cougar, but after your experience, I have already plan to move back to the landing gear 15 to 25mm , how mutch ?
I will put the JETFAN 90 and HET 700-60 39mm 2085Kv on 6S 5000 45C.
I hope have weight of 8.3 lbs with RC lander électric retract, GPS, UniSens-E
...(Graupner Hott or Futaba FassTest)
Thank's
MADISONMaster
MADISONMaster is offline Find More Posts by MADISONMaster
Old Aug 11, 2014, 08:09 AM
Ken W
ken willis's Avatar
Joined Dec 2009
I'm sorry it took me awhile to respond. Been working 16 hour days. I wouldn't move them but if you really want to about 20mm. When you give this jet power the nose comes off the ground but when you give it full throttle it stays down. And it lands nice. Dont move
Old Aug 12, 2014, 01:16 AM
Pasadena, CA
Joined Mar 2007
just about done with mybuild. retract installed with a basswood block to keep the gear from entering the fan intake area.
just read through the ENTIRE THREAD trying to find out if it was necessary to close that gap between the intake joint and the fan.
it seems like everyone is running it with the gap left open?
just want to make sure all the flying videos went with the standard ducting setup.
spent the last two days trying to figure out if i should run full intake ducting all the way up to the fan .
Brutikus is offline Find More Posts by Brutikus
Old Aug 17, 2014, 11:27 PM
Habanero's Avatar
United States, CA, Milpitas
Joined Jul 2008
Hi everyone - I think it was the manufacturer here said something about spare parts for this thing being available but I go to HK and I don't see jack for this plane anyone bought spare parts?
Habanero is offline Find More Posts by Habanero
Old Sep 02, 2014, 01:33 AM
Habanero's Avatar
Joined Jul 2008
Ok hk just answered my question "no they don't have parts available but they will work on it." I did see retract doors on H.k.'s site but that's it and by now I suppose it's irrelevant as this plane itself is on infinite back order I will never get my hands on one.
Discussion RCLander F9F-8 Cougar - 70mm EDF mw46mw46 Foamy EDFs 6 Jun 22, 2013 05:11 AM
Discussion Hobby King F-18 EDF 90mm Jet Fiberglass 920mm cprice Electric Ducted Fan Jet Talk 1 Feb 18, 2013 08:39 PM
Wanted Rc Lander PNP f9f 8 Cougar josephcharles Aircraft - Electric - Jets (FS/W) 2 Jan 03, 2013 04:06 AM
Sold Jet Hangar Hobbies f9f-8 cougar little joe Aircraft - Fuel - Jets (FS/W) 8 Sep 02, 2011 11:22 AM
Discussion RCLander F9F-8 Cougar w/DPS 76mm edf flying video Tim Wan Foamy EDFs 0 May 05, 2011 11:48 AM
