View Poll Results: Which livery do you like most?
Travel Service (blue) 9 19.57%
Travel Service (white) 4 8.70%
Czech Airlines (new c/s) 15 32.61%
Holidays Czech Airlines 11 23.91%
Czech Airlines (old c/s) 7 15.22%
Voters: 46. You may not vote on this poll
Old Aug 07, 2014, 03:30 PM
Doushiyou12's Avatar
Joined Feb 2010
Sorry to hear the results.
You did a fantastic job on this build. Keep your head up and I hope to see another build soon.
Doushiyou12 is offline Find More Posts by Doushiyou12
Old Aug 07, 2014, 03:54 PM
Up-Out-&-Gone
demondriver's Avatar
United States, SC, Charleston
Joined Mar 2007
I'm sorry indeed my brother. . . . It's times like this people see how hard this hobby truly is. . . I hope you build another A320.
Please build 2 planes next time.. . . . . Your a great builder! And your new A320 will rise from the tarmac!
demondriver is offline Find More Posts by demondriver
Old Aug 08, 2014, 02:51 PM
Up-Out-&-Gone
Joined Mar 2007
One trick I have learned to keep fan blade hub on the motor shift is the use of "thread-lock". . . I had the same problem happen to me with my Big-Bunny DC-9-30. . . I had a rotor hub fly off of my very 1st takeoff attempt. . .after that I applied thread-lock and applied it to all my fan units and never had that problem again.
Only problem now is I can't get the blade hub off the shift when I need to.
Old Aug 10, 2014, 07:27 AM
awacsCZE's Avatar
Joined Aug 2010
Like you glue the rotor directly to the shaft, or you secure the screw thread and the "hat" with it?
On the V-15, I mean this:
http://www.e-fliterc.com/ProdInfo/EF...LDF152-250.jpg
awacsCZE is offline Find More Posts by awacsCZE
Old Aug 10, 2014, 10:56 PM
Up-Out-&-Gone
Joined Mar 2007
Yes . . Thread-lock is a material that has the same thickness & consistency as milk. . . .you brush it on with a thin coat over the motor shaft then add the collet adapter.
Old Aug 11, 2014, 04:51 PM
awacsCZE's Avatar
Joined Aug 2010
And is there any issue with balancing, or is it ok? Anyway, how bad is it to pull it down after that?
Meantime, I finally got images of the aftermath Check your blades, guys, check your blades
Old Aug 11, 2014, 05:41 PM
Up-Out-&-Gone
Joined Mar 2007
adding thread lock to the motor shall will not interfere with balancing because the shaft is at the very center of the edf itself.
CZE all you need to do is build another forward half of your A320's fuselage . . And do some repair work on your right wingtip.
I've repaired worse Sir.
Old Aug 11, 2014, 05:50 PM
awacsCZE's Avatar
Joined Aug 2010
ok, thank you.
About repairing. I donīt know, I think to build it again and lighter and better with help of the laser would do better job. I am also affraid of some structural damage, that can be hidden inside and will show maybe at the 2nd flight, or more, slowly growing and some flight would be fatal too. It is not in clear view from the photos, but elevator seems to be broken inside under the balsa cover.
I would not have trust in that repaired thing to fly it.
Better safe than sorry again
P.S.: I think, that was the robust, heavy build, which caused to be in this condition
Old Aug 11, 2014, 06:01 PM
Up-Out-&-Gone
Joined Mar 2007
ok, thank you.
Sir Are you saying your A320 crashed because it was too heavy? Or because a rotor hub came off?
Old Aug 12, 2014, 01:07 AM
This is a fine fiddly business
Robert R's Avatar
United States, WA, Marysville
Joined May 2009
CZE,
You did a beautiful job on the build. I am very sorry for the loss of a lovely plane.
I think you are correct about several things:
1. The immediate cause of the crash was losing one engine. You will certainly check the propeller, fan assembly as a permanent part of your pre-flight check list. DD's suggestion of the non-permanent thread lock is a good thought. Avoid the permanent thread lock.
2. Weight is your mortal enemy. Around the time of your first attempted flight, I tried to calculate your wing loading. The calculated stall speed was quite high as I recall.
I think your idea of rebuilding but much lighter is sound. Wing cubic loading formulas could give you an estimate of a weight goal.
Calculate the wing cube loading for the full size airplane and aim for the same wing cube loading for your model. One reference below.
http://www.rcgroups.com/forums/showthread.php?t=604935
In the old free flight days there were very frequent crashes. Builders would look at their crashed models and say, "Every thing that didn't break in the crash should be build lighter in the next plane." Not a bad idea.
Another idea that might help would be to incorporate fixed flaps and slats. If they were fixed you would save a lot of weight on servos wire and linkages and still have increased lift and wing area. The down side is you always have to fly in landing configuration. Jeff of the Nefwaffe channel has done that to good effect.
AA Super 80 & USAir 757 (4 min 38 sec)
Best and condolences,
Robert
Robert R is online now Find More Posts by Robert R
Old Aug 12, 2014, 03:44 AM
mike_fish's Avatar
Russian Federation, Mosk. oblast', Grigorchikovo
Joined Jul 2005
It is a pity to hear such news.
I hope you will build one more A320, it is better and lighter than this. Good luck and new progress.
mike_fish is offline Find More Posts by mike_fish
Old Aug 12, 2014, 03:47 AM
awacsCZE's Avatar
Joined Aug 2010
I probably wrote that in bad way. I meant that many parts survived because I made it heavy and robust
Old Aug 12, 2014, 05:40 AM
awacsCZE's Avatar
Joined Aug 2010
Originally Posted by Robert R View Post
CZE,
Another idea that might help would be to incorporate fixed flaps and slats. If they were fixed you would save a lot of weight on servos wire and linkages and still have increased lift and wing area. The down side is you always have to fly in landing configuration. Jeff of the Nefwaffe channel has done that to good effect. https://www.youtube.com/watch?v=Efmk...8ffI0yDMrg4c5A
Robert
Yes, I will definitely try tu build it lighter, but I think building it much lighter wouldnīt be good idea, because of the strength of the airframe. I dontīt want to rebiuld it after every harder lading :-D
Goals for me for 2nd A320 are:
1) lighter - I think cut down 500-700g would be maybe possible. Because of the laser I will have to use balsa rubs in the fuse, but it will by light 2mm balsa, so it wont be big harm. I will keep three wing ribs which bear the engines in plywood 2mm, also light, but all other ribs will be from light balsa too (2-3mm). But the mos possible improvement will be in coating, which I will do from light or super light balsa, not from standard
2) Better wing angle - I did accidentaly smaller angle, which could cause unstability in turns, so goal is bigger angle.
3) Maybe better landing gear with some spring to deal with harder landings.
About flaps, well I followed the plan and they are not there. I donīt trust myself enough to do this. I donīt even know how to determine that Friend of mine encouraged me for moving flaps, but I donīt know, maybe, but I think it can be flown without them I tried faster flying with my T-34 and it was fine, I think if it will be right, it will fly good as the other builders report
Thank you very much for advices, I will try my best to do it better and right this time.
Old Aug 13, 2014, 04:07 PM
Up-Out-&-Gone
Joined Mar 2007
I'm sorry I misunderstood you Sir.
Airbus A320, new project(3mm depron) acrored Electric Ducted Fan Jet Talk 357 Mar 13, 2012 02:46 AM
Build Log Airbus A320 foamy bongose Scratchbuilt EDFs 88 Dec 15, 2011 05:48 AM
Discussion Twin edf Airbus A320 Dennis H. Electric Ducted Fan Jet Talk 110 May 23, 2010 12:17 PM
Discussion Prop driven Airbus A320 plans IWC Pusher Prop Jet Models 0 Jul 20, 2006 07:04 AM
Discussion GWS Airbus A320 series Tanguy&Laverdure GWS (Grand Wing Servo) 22 May 07, 2006 07:30 AM
