Old Apr 15, 2012, 03:30 PM
Joined Sep 2011
Wild Hawk Rx Channel Questions - *Fixed!*
Hi all.
I just finally decided to junk out the old fuselage on my Wild Hawk, and move everything into a new one, after the most recent crash. I ordered the parts, they came in, and I spent the earlier part of this afternoon swapping them into the new fuselage.
Stupidly, I didn't think to label each of the three cables plugged into the Rx, as I figured it'd be pretty easy to plug them in at a later time. Unfortunately, I'm now finding out that it wasn't as easy as I expected (and it's only a 3-channel!)
Basically, the Wild Hawk has three channels (throttle, elevator, and rudder). The receiver has four ports, one of which is a female port (the others are male), and is labeled "BATT". That left me with three ports, labelled channels 1, 2, and 3.
Unfortunately, I don't know which way to plug the cables into the Rx I've tried various ways, and the only way that I seem to even get any response from the Rx is if I have the battery plugged into CH 1, and everything else plugged into CH 2 and CH 3. However, this is not right, because then it appears that when I give throttle to the Tx, the rudder (or elevator) is actually what moves! So the battery / ESC obviously can't be plugged into that channel. So it needs to be plugged into CH 2 or CH 3. However, I don't get any response from the Rx when moving the controls on the Tx when plugging the battery / ESC into one of those other channels.
Am I doing something wrong? Am I just quite incompetent at this?
Thanks for any help!
kenzietech is offline Find More Posts by kenzietech
Old Apr 15, 2012, 03:52 PM
Joined Sep 2011
Nevermind! I guess all that I needed to do was complain a little bit.
Turns out, the problem was that when I screwed the power switch into the new fuselage, it must have torqued the switch just enough to cause the switch itself not to cross the terminals and turn on the plane. I loosened them up a bit, and it seems happy now.
Once that was figured out, I was able to then figure out where the connectors needed to go on the Rx.
Now to do it all over again tomorrow when my Turnigy 9x comes in the mail!
Giveaway Wild Hawk RC Tx/Rx, Channel 08! (Free Shipping Too!) kenzietech Non R/C Items (FS/W) 6 May 02, 2012 08:25 AM
Discussion cheapest wild hawk motor upgrade help! bigfoot216 Electric Plane Talk 5 Mar 05, 2012 06:23 PM
Discussion Wild Hawk/hawk Sky Flaps and Gyro? flashbang Electric Plane Talk 5 Jan 27, 2012 04:31 PM
Sold Wild Hawk 3ch tx/rx, brushed ESC, motor, 2 servos and wings cardnation Aircraft - General - Radio Equipment (FS/W) 3 Nov 02, 2011 11:35 AM
Discussion New RC Pilot with a Wild Hawk! Crashed it, and now I've got questions! kenzietech Beginner Training Area (Aircraft-Electric) 13 Sep 20, 2011 07:00 PM
