Old Apr 10, 2012, 01:03 AM
Joined Dec 2010
24mm outrunner motor recommendations
I did use google but can't find one with the specs I'm looking for.
I want a brushless 24mm (370) outrunner aircooled motor. The KV rating should be between 2500 to 3000.
SARCFAN is offline Find More Posts by SARCFAN
Old Apr 10, 2012, 07:53 AM
F1 madness's Avatar
Staffs UK
Joined Feb 2010
Why 24mm
be easier to find a 28mm diameter can round that KV
F1 madness is online now Find More Posts by F1 madness
Old Apr 10, 2012, 11:25 AM
Submarines, etc.
tsenecal's Avatar
Arvada, Colorado
Joined May 2005
I presume you need 24mm can, because the 370 brushed motor you are replacing is 24mm...
found this one but it is not in stock:
http://www.hobbypartz.com/96m268-2445-2900kv-17t.html
found these 20mm cans, can they fit?
http://www.hobbypartz.com/96m266-2040-2400kv-24t.html
http://www.hobbypartz.com/96m265-2040-2900kv-20t.html
tsenecal is offline Find More Posts by tsenecal
Old Apr 10, 2012, 11:38 AM
Joined Dec 2010
Guys sorry, I wasted your time because my title was incorrect. I was not suposed to say outboard, but outrunner I will see if I can correct the title. I want a outrunner as I will run it without watercooling. With the watercooling can/mount etc the space will be to limmited. The esc will be watercooled though.
Old Apr 10, 2012, 12:21 PM
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
Why 24mm? There's lots more selection in 26mm and 28mm.
wparsons is offline Find More Posts by wparsons
Old Apr 10, 2012, 12:32 PM
Joined Dec 2010
I always wanted to convert my Mini Wildcat to a brushless single but never did it. Now I want to. With the motor in the middle of the boat, on the higher part, the motor must be kept small in order not to touch the top of the boat. Also I think a 24mm motor will be a good balance between power and runtime on this small light cat. And it will keep the weight down as I will use smaller batteries as well. Bigger motor needs bigger batteries for the same runtimes.
Old Apr 10, 2012, 01:36 PM
RELAX. You'll live longer
785boats's Avatar
Brisbane- Australia
Joined Jul 2007
Will this do the trick?
http://www.hobbyking.com/hobbyking/s...00kv_300w.html
785boats is offline Find More Posts by 785boats
Old Apr 10, 2012, 01:51 PM
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
A slightly bigger motor (only 4mm bigger) won't draw more current unless you go to a bigger prop or one with more pitch. It'll also run cooler too since it's not running as close to it's limit.
How about:
http://www.hobbyking.com/hobbyking/s...er_2500KV.html
or:
http://www.hobbyking.com/hobbyking/s...er_2900KV.html
Old Apr 10, 2012, 10:24 PM
Joined Dec 2010
Originally Posted by 785boats View Post
I unfortunately want a motor without watercooling.
Old Apr 10, 2012, 10:29 PM
Joined Dec 2010
How about:
or:
They seem a bit big, but I will look at the boat again and see if it might not maybe work. I just might be possible to slip them in.
What driveline hardware, stinger, can I buy and where that will be a direct fit to the Mini Wildcat? I'm sure the standard driveline won't be able to handle all the extra power.
Old Apr 10, 2012, 10:41 PM
I feel the need for speed!
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
Surely you can make this one fit?
http://www.hobbyking.com/hobbyking/s...or_2700kv.html
scorpion1 is offline Find More Posts by scorpion1
Old Apr 10, 2012, 11:29 PM
Joined Dec 2010
It might Scorpion. Its the same size as what wparsons recommended. Since its is recommended by both of you it seems it must be the best option.
Now I just need stinger recomendations
Old Apr 11, 2012, 07:12 AM
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
You can't run a stinger on a cat with a single center mounted drive, you'll need a small strut.
Something like these should work, you'll need a new coupler and flexshaft still though
http://r2hobbies.com/rc-boat-alumini...ft-holder.html
http://r2hobbies.com/rc-boat-cnc-alu...ft-holder.html
and if you need a strut and rudder:
http://r2hobbies.com/rc-boat-aluminu...older-set.html
Old Apr 12, 2012, 01:01 AM
Joined Dec 2010
Thanks for the advice. I will brouwse though the site. I want a complete set, flexshaft included. I hate it when parts bought seperately don't match or fit each other 100%. Happenned to me before...
I will use the standerd plastic rudder that came with the boat as original equipment. I will have to wait and see if it will be up to the task. At least the boat should weigh less as there will be a complete motor and driveline less.
Discussion electric outboard motor ??? apex190 Racing Boats - Electric 16 May 08, 2012 07:53 PM
Sold Aquacraft r/c boat with ep1 outboard motor & decals pro fisherman radio control reddyrightnow Boats (FS/W) 0 Apr 02, 2012 08:56 PM
Sold GEAR DRIVES for 24mm & 36mm Motors old_dude Aircraft - Electric - Power Systems (FS/W) 4 Mar 31, 2012 05:19 PM
Discussion Proboar Stiletto outboard motor apex190 Racing Boats - Electric 6 Mar 18, 2012 09:43 AM
For Sale Himax 24mm x 24mm 4100kv ($25 shipped) RC_Bob Aircraft - Electric - Jets (FS/W) 0 Dec 14, 2011 10:47 PM
