Old May 13, 2014, 09:32 PM
Thermite + ice = Big boom.
boaterguy's Avatar
Canada, ON, Ottawa
Joined Apr 2009
Build Log
Forward swept 55mm EDF wing
I'm almost done building this wing, I didn't think to make a thread until now.
It has a KFM-2 airfoil, using strategies learned through flitetest.
I have one question - the spar is at 40% chord, where the kfm-2 should be, but the top surface (intentionally cut oversize) goes to about 50%. Should I cut the top surface back the the spar, or will it work fine at slightly <50%?
boaterguy is offline Find More Posts by boaterguy
Old May 14, 2014, 05:14 AM
USA
Joined Apr 2007
just build & fly
space 1 is offline Find More Posts by space 1
Old May 14, 2014, 08:01 PM
boaterguy's Avatar
Canada, ON, Ottawa
Joined Apr 2009
The maiden didn't go so well, the CG was way too far back and it would just pitch up as soon as it was launched, the wing may be too big for the weight of the plane.
Old May 15, 2014, 05:04 AM
USA
Joined Apr 2007
get CG right & try again wing is never to big
Old May 16, 2014, 04:34 AM
D_FAST's Avatar
Denver CO
Joined Apr 2008
http://wingcgcalc.bruder.com.br/en_US/
enter your data into this. just use - values in the sweep to get the forward swept wing
fyi
a forward swept wings tip, needs wash in, not wash out
D_FAST is offline Find More Posts by D_FAST
Old May 16, 2014, 05:58 AM
boaterguy's Avatar
Canada, ON, Ottawa
Joined Apr 2009
There is not wash in or out as it is foamboard and I wanted to keep it fairly simple.
I had previously calculated the CG, but before redesigning the fuselage I could not get it far enough forward, I just tried it anyways.
Old May 16, 2014, 06:42 PM
Aka: Tom Jenkins
ApexAero's Avatar
Palm Beach County, Fl.
Joined Aug 2008
This is coolness at its best to me! Glad to see someone doing a SF EDF!
You'll find it needs a long fulcrum out in front to balance, did you use full elevons or split the control?
The fastest I've ever flown R/C has been on a SF wing! right at 230mph!
ApexAero is offline Find More Posts by ApexAero
Old May 16, 2014, 07:28 PM
boaterguy's Avatar
Canada, ON, Ottawa
Joined Apr 2009
Well it didn't fly, I tried CG forward, back, right where the calc said, nothing worked.
After enough crashes it was no longer flyable.
Attempt number 2 will have a 28" span, 8" root, 6" tip, 4" sweep from root TE to tip TE.
The 55mm EDF unit is wrecked, something got into the blades, I can't decide between getting a big enough ESC for the 70mm unit I have or getting a new 55mm EDF.
Thoughts?
Old May 16, 2014, 10:42 PM
boaterguy's Avatar
Canada, ON, Ottawa
Joined Apr 2009
I guess I shouldn't be posting here anymore but since it's already a build thread I'll do it here.
I converted the EDF motor to a pusher config and will run it on 2S either 2650 or 2200mah.
I need to come up with something for the fuselage, any ideas?
Old May 17, 2014, 05:07 AM
USA
Joined Apr 2007
Not the same as EDF but you can keep it here
Old May 17, 2014, 02:08 PM
Do it Right, the first time!
CoolerByTheLake's Avatar
United States, MN, Hermantown
Joined Dec 2008
space 1, I'm Ok with it if boaterguy want s to keep it here.
So how about this??
OK, Not the same as scratch, but when I'm ready can I post it here?
I asked this question, with mixed results-- Where would you post this kind of build?
http://www.rcgroups.com/forums/showthread.php?t=2121119
Designed as a pusher, converted with lots of work for edf. Inside needs to be totally gutted, formers for edf, retracts, and flying stab ( bearing plates, shaft, and control horns. I need to cut new wing cores, (need bigger ones to make it a C model) , and will have Y/A spars--removable wings. Some or all of the inside will be glassed, along with entire outside of fuse.
BTW, this is 64" long , WS, will be 46" after new cores. JF90/Het 1200K on 12s...approx weight--11-12lb.
After thought-- pics of how stab shaft , bearings and control horn are set up
Right from the Y/A manual.
http://www.rcgroups.com/forums/showp...3&postcount=58
CoolerByTheLake is offline Find More Posts by CoolerByTheLake
Old May 17, 2014, 05:30 PM
USA
Joined Apr 2007
lots people call that Kit bashing I thank here is good
Old May 17, 2014, 06:56 PM
Joined Dec 2008
My apologies to boaterguy, I got a bit carried away. Hope you get it all figured out..
"Kit bashing " To the extreme.
Old May 17, 2014, 10:53 PM
boaterguy's Avatar
Canada, ON, Ottawa
Joined Apr 2009
My cg was too far forward on the last flight and it crashed into the ground. I need to get more hot glue and try to get it up tomorrow (if not, I'll take a pill, that should get it up ).
On a completely unrelated topic, has anyone found a good tutorial for the Taranis?
Old May 18, 2014, 04:38 AM
D_FAST's Avatar
Denver CO
Joined Apr 2008
not sure about a tutorial. But i do know ive stumbled onto a 1500+page thread on here.
Latest blog entry: Dassualt Alpha Jet
Discussion Quad tilt Rotor FORWARD swept wings project The_RattleSnake VTOLs 47 Jun 21, 2014 11:05 PM
Build Log Quad tilt Rotor FORWARD swept wings project The_RattleSnake FPV Talk 1 Feb 20, 2014 07:34 AM
Build Log F-Sweep 35mm EDF - a micro, forward swept wing, EDF jet! (flying in the wind) Arxangel Foamies (Scratchbuilt) 8 Jul 18, 2013 05:23 AM
Question what is this EDF with wings swept forward? snoshoe62 Foamy EDFs 6 May 03, 2008 12:36 AM
