Old Apr 22, 2013, 05:31 AM
Joined Oct 2010
IF 3D is your goal, and you prefer not to spend a lot, then Sketchup would probably be a good first choice (it's free from what I remember).
Once you get through the learning curve of 3D, then you might think it's worth it to shop for a "professional" CAD program.
Treeline is offline Find More Posts by Treeline
Old Apr 22, 2013, 06:54 PM
Jim C Patrick
jcpatrick's Avatar
Shenandoah County
Originally Posted by willhappy View Post
I can work in 2d but looking to design and work in 3d so i can see all componats fit and work together.
Good golly! If you want to 'design and work' in 3D then Autocad is the last software you should use.
jcpatrick is offline Find More Posts by jcpatrick
Old Apr 24, 2013, 02:22 PM
dpot's Avatar
France, Auvergne, Lapalisse
Joined Dec 2005
if you are just using cad for model airplanes and you are good with 2d autocad and you just need to see all complainants fit and work together Then
devcadcam devfuzcam and devwingcam all for 300 euro
it all fits
you get 3d views
sets up code for mach3 for cnc and exports dxf
you can scale it up or down with no problem spars and stringer all stay the same size you setup
make fuz and wing molds exporting as .STL
and is not that hard to understand
hi all
thanks guys for the help.
will
dpot is offline Find More Posts by dpot
Old May 05, 2013, 12:38 PM
Dpetsel's Avatar
United States, IA, Coralville
Joined Jun 2012
Here is a model I am building that I drew with Deltacad and had cut at AK-models.
Dpetsel is offline Find More Posts by Dpetsel
Discussion How to edit PDF files in Autocad? exhornet Foamies (Scratchbuilt) 5 Apr 01, 2013 08:35 PM
Help! HOw do i do 3D drawings in Autocad 2013 Keenan smith CAD/CAM 14 Mar 31, 2013 12:35 PM
Printing with autocad sarebro Electric Plane Talk 18 Oct 13, 2006 03:28 PM
Discussion diff between autocad 2004 and autocad R14 rohitjain22 The Builders Workshop 3 Sep 13, 2006 07:39 PM
cnc / autocad i-fly Power Systems 1 Dec 10, 2001 07:47 PM
