Old Dec 22, 2012, 04:28 PM
1 can never have 2 many planes
chambo88's Avatar
Australia, QLD, Surfers Paradise
Joined Sep 2011
Build Log
BAE hawk EPP 950mm build (for a friend)
so after seeing my 900mm epp f-18 in action, i have been commissioned to build a BAE hawk for a friend if mine.. ended up not being able to pick it up so i kept it
specs:
wingspan 950mm
lenght 1150mm
weight 1.2kg
motor: NTM 28-36 2200kv B/O
esc: turnigy plush 60amp esc
battery: 3000mah 3s lipo (to start with) might get up to a 4000mah3s
servos: TG9e 9g all round apart from the elevator >> turnigy 3kg 19g servo
control surfaces:
ailerons
rudder
elevator (full flying control surface <same as the real hawk>)
the f-18 of this similar weight and size is fitted with a 2500kv motor putting out 450watts WOT.
the tested motor puts out a whopping 700watts at 60amps with a 9x6 cut down to a 6x6.. this is over the limits of the motor by 5amps.. but at 55amps the motor still turns out over 600watts.
should be a lil rocket, as the hornet pushes 100kph in level flight putting out 460watts on a 6x5 apc prop..
here is also a pic of the proposed paint scheme..
chambo88 is offline Find More Posts by chambo88
Old Dec 23, 2012, 05:04 AM
ExPat
Aero Andy's Avatar
Spain, Murcia, Mazarrón
Joined Apr 2010
Thanks for the link Mark, watching and waiting..
Andy
Aero Andy is offline Find More Posts by Aero Andy
Latest blog entry: Phoenix 2000
Old Jan 07, 2013, 05:35 PM
chambo88's Avatar
Joined Sep 2011
Right so foam arrived the other day.. Have drawn it out.. Still waiting on parts, but I'm plannin on cuttin out the shell 2moro
Old Jan 12, 2013, 04:06 PM
chambo88's Avatar
Joined Sep 2011
and so, airframe parts have all been removed from the sheets and pinned together to give a preview to the shear size of this one
Old Jan 15, 2013, 04:17 PM
chambo88's Avatar
Joined Sep 2011
got over my cold today thankfully and decided it was time to shape up the hawk..
have now finshed the basic shape. still needs intakes and exhausts to be cut and moulded.
cant wait till 2moro i can start fitting and playing around with the electronics.
Old Jan 15, 2013, 04:49 PM
iceaxe's Avatar
Joined Dec 2006
He'll yes mark looks awesome
iceaxe is online now Find More Posts by iceaxe
Old Jan 15, 2013, 05:24 PM
United Kingdom, England, Redcar
Joined Jan 2006
Wow looks like the start of a beautiful hawk , I always wanted the black/grey demonstrator version myself but ended up buying the powers 50mm hawk and doing a custom spray job.
Good luck.
scousethief is offline Find More Posts by scousethief
Old Jan 15, 2013, 05:39 PM
chambo88's Avatar
Joined Sep 2011
thanks guys can you believe in germany the amount of epp required to build a model of this size will only set you back about 35euro?? how crazily cheap is that! 4 weeks and epp at a similar prices will be available in australia
Old Jan 17, 2013, 06:56 AM
chambo88's Avatar
Joined Sep 2011
so i was able to get the day to myself yesterday, which meant i could also make a mess of the appartment as long as i have it cleaned up by the time someone gets home lol. due to this fact i had the time to get almost all of the electronics fitted and finished.
have included a few pics of how i installed the alloy wingspar, along with other pics of parts and points of interest around the plane.
the intakes and exhausts flow through the rear half of the fuse and act as cooling to the esc and motor.
under the canopy there is almost too much room as you can see with the battery fitted and receiver pushed back there is still almost enough room for my foot.. haha..
also the elevator throw's are a little extreme. (see pics) ill have to tone them down a notch so they stay on in flight.
hoping to maiden it as soon as the snow stops fallin here
Old Apr 03, 2013, 08:31 PM
chambo88's Avatar
Joined Sep 2011
paint scheme is now goin on over the yesterday today and most likely 2moro as well. here are the pics of my progress to date..
still need to finish the cougar and the ensign but its coming together.
chambo88's Avatar
Joined Sep 2011
ill be sure to get a flying video up very soon as well as i can see that i havent got one up here yet for some silly reason
Old Apr 04, 2013, 01:54 AM
chambo88's Avatar
Joined Sep 2011
so finished for today.. finished the ensign and the cougar on both sides. still needs a couple of little details on the tail and the ejection trace lines on the canopy..
Old Apr 06, 2013, 07:18 AM
iceaxe's Avatar
Joined Dec 2006
Damn she looks. Hot mark can't wait for mine
Old Apr 07, 2013, 05:18 AM
chambo88's Avatar
Joined Sep 2011
flight video, here you go..
BAE Hawk epp RC model pusher jet 950mm (2 min 40 sec)
Old Apr 07, 2013, 05:23 AM
United Kingdom, England, Hull
Joined Aug 2011
Wow, flys great Nice one.
Marlbororman is offline Find More Posts by Marlbororman
Discussion Instructions/CG for Smartmodel 70mm BAe Hawk? fh64_lucky Electric Ducted Fan Jet Talk 2 Oct 25, 2012 12:06 PM
Sold BAE Hawk back up for sale high quality 90mm Sell...er Aircraft - Electric - Jets (FS/W) 0 Oct 05, 2012 07:23 PM
Discussion Bae System Hawk 1.55m for 90-100 EDF kin Electric Ducted Fan Jet Talk 8 Jun 24, 2012 12:28 AM
For Sale NIB BAE E-Flight BAE Hawk (price lowered) dmize Aircraft - Electric - Jets (FS/W) 8 May 10, 2012 07:44 AM
Found Trade NIB BAe Hawk, fan and ESC for 3D plane 1stplaceaviator Aircraft - Electric - Airplanes (FS/W) 4 Mar 31, 2012 08:01 PM
