Old Jun 16, 2014, 12:52 AM
a.k.a Maltone
Australia, NSW, Goulburn
Joined Jan 2005
Oscar nomination anyone?
Shoey - metal is great to work with but does need a few extra tools and skills....
Now for my next exciting block-buster movie - a very early proof-of-concept trial for the retracts mechanism. It works perfectly but a few little improvements are needed to avoid any landing shocks getting back to the servo. But the idea works
HS75bb servo connected via a torque tube configured as a semi-flexible universal coupling. My main concern is accessibility and the last remaining issue is how to mount the servo so it can be removable (heaven forbid!) Maybe an aluminium bracket of some sort.....cogitating.
Pat
Model Avro Anson retract test (0 min 47 sec)
Pat Lynch is online now Find More Posts by Pat Lynch
Latest blog entry: A New Year's Project
Old Jun 16, 2014, 04:10 AM
a.k.a Maltone
Joined Jan 2005
...a small update
I was concerned the servo screws were almost impossible to access where I had the servo so it was mounted behind a new ply sub rib and screwed from behind - accessible through holes to be cut in the root rib. Now I'll make a decent ply subrib and repeat the process on the other wing - and I'm happier
I also realised with a duh! moment, I'll need a servo reverser on the other side. Having one wheel up and one down doesn't seem very useful
Pat
Old Jun 16, 2014, 06:18 AM
Liverpool, England
Joined Jan 2005
Gets an Oscar from me Pat, smooth as silk really nicely thought through
If you have to get hold of a reverser why not get one of these - http://www.hobbyking.co.uk/hobbyking...Regulator.html that way if you are using proportional servos you could slow the travel down to get even more realism as well as reversing one channel
I have used these on a few planes with absolutely no issues
Enjoying this build, Ken
heli_madken is offline Find More Posts by heli_madken
Old Jun 16, 2014, 06:57 AM
So I'M meant to be in control?
Colonel Blink's Avatar
Ilkley, West Yorkshire, UK
Joined Nov 2008
Now ain't that strange? I have never, ever thought of mounting a servo with screws going up from underneath the tabs......
Colonel Blink is offline Find More Posts by Colonel Blink
Old Jun 16, 2014, 07:03 AM
a.k.a Maltone
Joined Jan 2005
Thanks gents - Ken - the HS75 retract servos aren't proportional - they just run end to end. Has the advantage here that if there is any resistance at the end-points, they can't stall. BUT it means the mechanics have to be setup proper
I've ordered some straight reversers from HK Australia - a whole couple of dollars each!
Tomorrow I'll get the other wing done then I can move on. At last!
Pat
Old Jun 16, 2014, 08:02 AM
Parkcityflier
parkcityskier's Avatar
Park City, UT, USA
Joined Aug 2001
I'm blown away with what you have done, Pat. Your engineering skills are equal to your building talents. Very nicely done.
Jim
parkcityskier is offline Find More Posts by parkcityskier
Old Jun 16, 2014, 09:03 AM
The Hun in the Sun
vonJaerschky's Avatar
Canada, BC, Comox
Joined Nov 2003
Very nice, Pat! Many standard analog servos are quite easy to reverse without the need for a reverser. Open up the case and swap the wires to the motor and to the potentiometer. I had to do it for one of my HS-225's that I'm using for my gear doors.
vonJaerschky is offline Find More Posts by vonJaerschky
Old Jun 17, 2014, 12:36 AM
a.k.a Maltone
Joined Jan 2005
A complete reversal...
After some prompting from wise Frank, I took the back off the second HS75BB and reversed the wires on the potentiometer (right) and the motor(left) - you can see the swapped wire's colours have changed. Sure enough, the servo now works in reverse with no ill effects.
I know this process has been described dozens of times here on rcg, Youtube etc but I put it here to remind me it was done!
The blue masking tape was to hold the two parts of the case together not relishing a benchtop covered in small metal and nylon gears.......
Pat
Old Jun 17, 2014, 03:25 AM
a.k.a Maltone
Joined Jan 2005
...almost there...
The second servo was reversed, installed and connected and now I have two legs working together. A bit of tidying up and I'll have to think of where to next
Pat
Old Jun 17, 2014, 09:46 AM
Power Upward
GeorgeG97322's Avatar
United States, OR, Albany
Joined Jun 2007
Pat, awesome work as usual. Obviously more room to work with on a bigger model.
My Annie is calling my name... If I could just get my niece to take her CAT back I could get this out into the open again...
George
GeorgeG97322 is online now Find More Posts by GeorgeG97322
Old Jun 17, 2014, 11:34 AM
Senile Member
Lnagel's Avatar
Moab, Utah, USA
Joined Apr 2003
Excellent work, Pat. Definitely beyond my skill level. However, you have the photos in post #159 mislabeled, down should be up and up should be down. Don't you people in the southern hemisphere know up from down? Maybe it would be better to use the terms extended and retracted instead.
Larry
Lnagel is online now Find More Posts by Lnagel
Old Jun 17, 2014, 12:15 PM
nytjadens's Avatar
United States, NY, Dobbs Ferry
Joined Oct 2008
Larry
Now that's FUNNY! :-)
Stephen
nytjadens is offline Find More Posts by nytjadens
Old Jun 17, 2014, 12:22 PM
Huey N's Avatar
United States, CA, Emeryville
Joined May 2007
Larry strikes again.
Huey N is online now Find More Posts by Huey N
Old Jun 17, 2014, 12:27 PM
Parkcityflier
Park City, UT, USA
Joined Aug 2001
Now that brings up a question. If you are flying inverted, is "up" towards your feet or towards your head and is"down" towards your head or towards your feet? If it's the former in both cases then Pat's description looks OK since the wing is inverted. Of course, in Australia, the earth's pole is to the south where our's in to the north. Oh well, maybe using "retracted" and "extended" is better.
Old Jun 17, 2014, 03:26 PM
a.k.a Maltone
Joined Jan 2005
You northerners - always think you're right 'cos there's more of you I future I'll label my U/C directions as 35 deg south (extended,down) or 35 deg North (retracted, up). Ah what the hell - you know what I mean.........
WRT what is next, I want to build a wing alignment jig as the top sheeting must soon be applied. I must also remove the U/C legs to paint the wheel wells and upper legs....and think about where to route power wiring, flap servos, lighting wires, add some shear webbing,......I wont get bored This sort of 'plan build' is really testing - even with the 'benefit' of laser-cut parts but I love the problem-solving, plan interpretation and freedom of changing stuff as I see fit.
One of my over-arching concerns has been concerned with CG or balance. I also would like a small reserve of power so have upped the motors one size and have a pair of Turnigy G46s - a bit bigger than the Power 32 I was going to fit. This, along with batteries in the nacelles, should help get it right. The balance point is just behind the front spar so all my retract stuff is forward of CG - that is good! Getting the required batteries in the nacelles is more problematic. I may parallel some physically smaller LIPOs to get them to fit vertically accessible from the hatch on top of each nacelle.
Enough rambling....back soon - Pat
For Sale What, no Pilot? New Faces! 2 sizes WWII Pilots already painted for only $12.50!!! unclegeorge Aircraft - Fuel - Airplanes (FS/W) 7 Jan 24, 2013 09:55 AM
For Sale What, no Pilot? New Faces! 2 sizes WWII Pilots already painted for only $12.50!!! unclegeorge Aircraft - Fuel - Airplanes (FS/W) 0 Jan 04, 2013 12:27 PM
Discussion What do you do to prepare a glow model for electric? depronair Glow to Electric Conversions 1 Sep 03, 2010 04:06 PM
Discussion Evolution Model Technology, preparing to open for business Evolution Staff Product Announcements 0 Aug 07, 2006 07:13 PM
Question Whaddoya Think- Preparing for Axle build Hutch Slope 11 Aug 04, 2005 04:10 PM
