Old Apr 27, 2016, 05:50 PM
jmxp69 is offline
Find More Posts by jmxp69
jmxp69's Avatar
United States, AZ, Glendale
Joined May 2015
Mini-HowTo
FPV Preflight Checklist - Taranis
I can't count how many times I've gone FPV'n with friends only to have someone comment on the need to document a preflight checklist. It's so easy to miss something like turning on a recorder, checking a battery, etc...
I finally put together a checklist and enabled it on my Taranis. I also put together a quick video how-to on YouTube:
Tech - FPV Preflight Checklist with Taranis (5 min 37 sec)
Here is my checklist. Would be happy to see your checklist ideas!
J
Code:
  *** FPV Pre-Flight Checklist ***
BATTERY VOLTAGES
  Ground Station   [Confirmed]
  Goggles          [Confirmed]
  Radio TX         [Confirmed]
  Aircraft         [Confirmed]
AIRCRAFT
 Aircraft Antennas [Secure]
 Control Surfaces  [Verified]
 Pan/Tilt Movement [Verified]
 Aircraft Canopy   [Secure]
 Wings             [Secure]
GROUND STATION
 Antennas          [Installed/Secure]
 Antenna Tracker   [On/Calibrated]
 VRX Relay         [On]
 HD Recorder       [On/Recording]
 DVR               [On/Recording]
 Goggles           [On/Good Video]
RADIO
 Flight Mode       [Set Manual/2D]
 Gain Knob         [Set 100]
 RSSI              [Verified]
 TX Antenna        [Secure]
   Orientation     [Verified]
  *** Checklist Complete ***
jmxp69 is offline Find More Posts by jmxp69
Old Apr 28, 2016, 04:44 PM
jmxp69 is offline
jmxp69's Avatar
Joined May 2015
Took a good idea from another member and added some extra configuration information to my preflight checklist.
Code:
      *** Vector Parameters ***
Fly Home Altitude  [400']
RTH Altitude       [350']
Home Rad           [400']
Loiter/RTH Circle  [135']
Minimum GS         [15mph]
Turn Gain          [45%]
Vertical Gain      [55%]
Default Gain       [45%]
Old May 11, 2016, 11:02 PM
LFP_Flyer is offline
Find More Posts by LFP_Flyer
Flying high over WA
United States, WA, Seattle
Joined Sep 2013
Question: Will a Sky Walker fly with only 2 rubber bands holding the wing on?
Answer: Yes! But I don't recommend it
Really needed a check list that day!
Here is an AIRCRAFT check-list item for you:
Wing [Secure]
Thanks for the video. I'm setting up check-lists on my Taranis.
LFP_Flyer is offline Find More Posts by LFP_Flyer
Old May 12, 2016, 01:30 AM
jmxp69 is offline
jmxp69's Avatar
Joined May 2015
That's the thing about checklists. Everything is good until you forget that one time
So....any video of this two rubber band flying fun??
Old May 12, 2016, 09:42 AM
Flying high over WA
Joined Sep 2013
I recorded the flight, but you can't tell that anything is wrong. I didn't realize I had forgotten to properly secure the wing until I landed. It was a shocking moment when I realized what had happened! The FPV gods were smiling upon me that day...
I had another 'oh crap' moment last year that could have been avoided with a check-list. My video looked good so I launched, and within 20 feet I completely lost video. I was able to transition to LOS and land the plane without incident. The cause? Forgot to put the antenna on my VRX!
I've also added a new section with a few items that I've been known to forget
Code:
FLIGHT CONTROLLER
 Air Speed Sensor  [Reset]
 Trims             [Reset]
 GPS Lock          [Confirmed]
 Home Location     [Confirmed]
Added to AIRCRAFT section: Failsafe [Confirmed]
rc aircraft preflight checklist hihptsi Aerial Photography 23 May 07, 2014 04:10 AM
Mini-HowTo Lama V3 preflight checklist for dummies (like me!) CCbusa05 Coaxial Helicopters 16 May 10, 2008 05:25 AM
Discussion Preflight Checklist & Flight Log - FEEDBACK SOUGHT cosgrove Micro Helis 7 Dec 02, 2007 06:00 PM
Discussion Preflight Checklist & Flight Log - FEEDBACK SOUGHT cosgrove Coaxial Helicopters 2 Dec 02, 2007 08:10 AM
Discussion Preflight Checklists for New HB FP misfire Micro Helis 17 Oct 19, 2007 01:01 PM
