Old Jul 23, 2015, 09:22 PM
rc john is offline
Find More Posts by rc john
Joined Jan 2015
BVM Aggressor edf-90mm or 120mm?
I have recently come across a new in the box BVM Aggressor kit. It is untouched,but designed to be flown with an .82 sized nitro ducted fan.. I have had a couple of these planes years ago and would like to build this one for edf. I am just wondering if it would be better to build it around a jet fan 90mm v2 or a 120mm. I already own a couple of 90mm edf planes that fly very well on 8s 4000mah set ups. This Aggressor is larger than my HK Diablo or my HET Super Sniper 90XL.
rc john is offline Find More Posts by rc john
Old Jul 23, 2015, 09:48 PM
AIR SALLY is online now
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
I have inlet ducts for this that fit the JF 120 or BVM fan ,the ducts are longer and allow more room for batts and to adj CG .Mark from dinogy batts has some in his restore aggressor .
AIR SALLY is online now Find More Posts by AIR SALLY
Old Jul 23, 2015, 10:52 PM
Robert Belluomini is offline
Find More Posts by Robert Belluomini
EDF Jet Jam 2016, June 16 -19
Robert Belluomini's Avatar
United States, KY, Crestview Hills
Joined Dec 2000
I'd go with a hot 90 mm setup. 10-12S proper ducting
Robert Belluomini is offline Find More Posts by Robert Belluomini
Old Jul 24, 2015, 02:56 PM
db_sonic is offline
Find More Posts by db_sonic
Joined Feb 2010
I agree with Robert, I think a hot 10s 90mm setup is a great choice and keeps it lighter around the weight these had with the original DF setup or maybe just a tad over that.
~120mm power setup ~4.5 to 5kW you have to get creative with finding a place for the batteries. But of course it can be done and you will likely want to go 12s in this case. There you will be 14 or 15lbs.
I don't know if there are any 100mm setups out there that would work.
db_sonic is offline Find More Posts by db_sonic
Old Jul 25, 2015, 08:18 AM
Joined Dec 2000
Stu's 100mm fan would be the hot setup
Old Jul 25, 2015, 11:44 AM
Mike Warren is offline
Find More Posts by Mike Warren
BOHICA!
Mike Warren's Avatar
Joined Dec 2010
True statement.......however; unless you can find one on the "pre-owned" market I think you are out of luck.
Stuart made very few 100mm and as far as I know has not produced them in a few years now.
- Mike
Mike Warren is offline Find More Posts by Mike Warren
Old Jul 25, 2015, 11:47 AM
Chris True is offline
Find More Posts by Chris True
St. Mary, Maryland, United States
Joined Dec 1996
I like my 12.5 pound 90mm setup
9S
BVM Agressor (4 min 11 sec)
Chris True is offline Find More Posts by Chris True
Old Jul 28, 2015, 10:30 PM
demetrius is offline
Find More Posts by demetrius
demetrius's Avatar
Van Nuys
Joined Mar 2004
I've been looking for one for my A4 however not one response!
demetrius is offline Find More Posts by demetrius
Old Jul 29, 2015, 08:05 AM
stumax is offline
Find More Posts by stumax
The blade numbers go up to 11
stumax's Avatar
Sydney, Australia
Joined Aug 2002
- Mike
Sadly the 100-45 just hasn't been popular enough for me to get a batch of carbon tube type shrouds made up so I can produce them painlessly. It would actually reduce the fan price substantially, too, to around $230 or so. Hand making carbon shrouds is so painful & messy I just don't want to go there any more. If enough people wanted a 100-45 I would get a batch of shrouds made but there just aren't enough models aimed at 100mm fans except for these older ICDF models. The only reason these models are perfect is because they need to be built, meaning the builder will be able to modify the inlet ducting to suit, or could buy suitable ducting from Tam. Unfortunately I don't think there are any ARF's out there aimed at 100mm fans. It's a shame as it's a great size and the models are large enough to fly well and have presence but small enough not to require all expensive stuff inside.
Stu.
stumax is offline Find More Posts by stumax
Old Jul 29, 2015, 10:09 AM
pdawg is online now
Find More Posts by pdawg
Need 4 Speed!
pdawg's Avatar
United States, OH, Dayton
Joined Apr 2004
I would commit to purchase a 100mm at $230. Sounds perfect for the older BVM stuff which are pretty tight using the evf at around 115mm.
pdawg is online now Find More Posts by pdawg
Old Jul 29, 2015, 04:19 PM
Joined Dec 2000
Stu I'm in for one too!
Bob
Old Jul 29, 2015, 10:31 PM
demetrius's Avatar
Van Nuys
Joined Mar 2004
Ill definitely take one!
Old Jul 31, 2015, 03:02 PM
JamesK is offline
Find More Posts by JamesK
United States, ID, Nampa
Joined Mar 2011
I'd be in for one as well!
Regards,
James
JamesK is offline Find More Posts by JamesK
Old Jul 31, 2015, 08:44 PM
juanjulian is offline
Find More Posts by juanjulian
juanjulian's Avatar
Guatemala, Guate
Joined Jul 2007
What about building one.
Knife little describes very well how to use hayoe shroud, build a plate for motor to reinforce flimsy plastic, and can probably say that a cut down rotor will do the job really nice.
With the new het motors instead of outrunner motor should end with a nice efficient combo.
juanjulian is offline Find More Posts by juanjulian
Old Aug 04, 2015, 04:43 AM
candane is offline
Find More Posts by candane
Turkey
Joined Oct 2008
Stumax, I have 3 ICDF old planes. I want to buy 100 mm EDF.
Juanjulian, Lee can do this modification. But I coudnt it. I cut turbax rotor and I used a 100 mm hayoe shroud. I think balans wasnt very well. I was afraid to run. It would probably destroy. This job very dancer for me. I never try it.
candane is offline Find More Posts by candane
Discussion 90mm Jet with 120mm EDF Mr. UD Foamy EDFs 8 Jun 04, 2015 02:42 PM
Wanted BVM Aggressor, Ultra Viper or Maverick Pro Kit johnny9390 Aircraft - Fuel - Jets (FS/W) 3 Mar 31, 2015 03:12 PM
Build Log BVM Aggressor I edf build corsair nut Electric Ducted Fan Jet Talk 307 Jan 16, 2015 07:56 PM
Wanted BVM Viper,aggressor or Maverick Hollywood_07 Aircraft - Electric - Jets (FS/W) 0 Dec 29, 2014 10:02 PM
Wanted BVM Aggressor plans (version 1 or 2) chrisaviator Aircraft - Fuel - Jets (FS/W) 0 Jun 17, 2014 05:21 PM
