Old Apr 15, 2014, 08:59 PM
aircrew53 is offline
Find More Posts by aircrew53
Joined Oct 2012
power pod help
Hello all I am building a sophisticated lady arf . I an planning on scratch building a power pod for it . I will be running a brushless out runner with a 3 cell 2200 lipo swinging a 11x6 folding prop. Can anyone tell me what a good point to start at as far as degrees in up thrust or if I should have any right thrust and how high the pod should sit over the wing . Thanks
aircrew53 is offline Find More Posts by aircrew53
Old Apr 15, 2014, 10:10 PM
aeajr is offline
Find More Posts by aeajr
Proud member of LISF and ESL
LI, New York, USA
Joined Mar 2003
Just pick up one of these and mount your motor on this:
http://www.sigplanes.com/product.asp...FSqXOgod3BwAfA
Or this
http://www.ebay.com/itm/like/261360555481?lpid=82
aeajr is offline Find More Posts by aeajr
Old Apr 16, 2014, 10:33 AM
jcstalls is online now
Find More Posts by jcstalls
Dragons, WindMills, all Same
jcstalls's Avatar
United States, IN, Indianapolis
Joined May 2002
Use the simple search tool and use Power Pod as your keyword reference. Three pages saw I.
Jared
jcstalls is online now Find More Posts by jcstalls
Old Apr 17, 2014, 10:05 PM
gzkpez is online now
Find More Posts by gzkpez
Joined Jan 2006
You need a lot of up thrust. Its purpose is to get the airflow from the prop over the elevator, I think you have a T tail so that might come into play. 10 to 15 or more degrees. Launches might still a little hard (till it gets moving), launch it with low or no power then add power gradually when it is flying. After it gets moving it will be very stable, just the first 3 or so feet power from the pod will try to nose it in till the air starts to flow over your wings etc. Even if you do not get the power up fast it will just land, and may be do a touch and go. (try that with a front mounted prop on a glider ) If your field is nice grass you can even right off the ground it.
Keep the pod as low as you can, so it will be a little more stable., Be sure to leave prop clearance be sure to include the props center piece in you calculation.
I would not worry at all about right thrust, just correct with rudder on the way up; you could add a degree or two to feel good .
Since you are going to use a folding prop you probably should make it a pusher, remember the blades need to fold while rotating.
That is a pretty large battery for your plane, but if you need the weight go for it. What size outruner are you going to use a 28 mm 36 mm? I might go with a little smaller prop. You do not need a whole lot of power.
gzkpez is online now Find More Posts by gzkpez
Old Apr 21, 2014, 08:40 PM
Joined Oct 2012
I know this sounds crazy but I don't know the exact spects on the motor I do know it uses a 10x6 to 11x7 prop. I'm gonna start out using a 10x8 prop tractor not a pusher set up the pod will sit 6 inches over the wing wich it will put in line with the elevator I was told i needed only about 3 to 5 degrees up thrust 10 to 15 sounds like a lot
Old Apr 21, 2014, 08:53 PM
Sparky Paul is offline
Find More Posts by Sparky Paul
Ascended Master
Sparky Paul's Avatar
Palmdale, CA
Joined Oct 2000
Mount the motor with no offsets at first.
If any are needed, flight testing will find them.
Sparky Paul is offline Find More Posts by Sparky Paul
Old Apr 21, 2014, 11:27 PM
Joined Jan 2006
If you have the stock T tail then you can use much less up thrust; since it is inline with the elevator. The real purpose is mostly to get the air over the elevator and rudder, till you get some airspeed going; after the initial airspeed it will be nice most irregardless of what the thrust is, to get to altitude. Unlike power planes where you want to fly around level at all power levels, to fly real nice thrust line is critical on power planes. So if I had your glider with a t tail and pod I would go with 5 to 10 if it was me, it should not be to critical.
If you have a V tail you would need a little more and a conventional tail much more. Mostly I just point the thrust to the elevator, where the pod is on the wing and how long the fuselage matter. The higher your pod is the more you need up thrust you need, I learnt that the hard way, when I went from a glow to a more powerful electric with a much bigger prop and higher pod. When I launched it it at full throttle it really wanted to go down, till it started moving then there was no problem, I latter added a little more up thrust and leaned to slowly add power when launched .
I also have not seen any difference in a tractor or a pusher, in thrust or performance, other the the pusher you can add a folding prop (which is big). With an electric you can reverse the direction of the motor so no special prop is needed . Remember if you are using a folding prop to make provision for the Props center section.
Old May 17, 2014, 08:38 PM
Joined Oct 2012
Well I'm almost finished with the pod AUW of pod with motor esc and battery is 13.04 oz any input?
Help! Goldberg Electric Power pod Instructions... Demon-Leather Electric Sailplanes 4 Jan 14, 2014 05:49 PM
Sold 80" Electric Glider with retractable power pod $69 + S&H! unclegeorge Aircraft - Electric - Airplanes (FS/W) 0 Jan 03, 2014 03:55 PM
Wanted EMA power pod with gearbox xrx1113 Aircraft - Electric - Power Systems (FS/W) 0 Oct 02, 2013 08:07 PM
For Sale 15% off on Composite Pods and E-Pods, 20% off for fuselage pod sets ClmPro Aircraft - Sailplanes (FS/W) 0 Sep 24, 2013 09:45 AM
To Power Pod or not Power Pod? Axon-Five Sailplane Talk 7 Oct 20, 2002 01:28 PM
