Old Aug 22, 2013, 09:54 AM
rjrobbin is offline
Find More Posts by rjrobbin
United States, OH, Powell
Joined Dec 2006
Build Log
12 foot Telemaster Laser Cut kit
I saw this kit advertised several months ago. I have built several large kits, ie. Ray Hayes Olympic III, Big Birds and Merlyn etc. Including a senior Telemaster.
I was attracted by the term 'building experience'. So I ordered the kit on Monday and received it on Wednesday.
I have done other build logs. So I will do the same here. I hope it will provide some enjoyment as I progress along.
As mentioned above, I have a senior Telemaster and it flies great.
This will be much larger. I am not a giant airplane type person..I only have a car to transport the planes to the flying field. The seats fold down so I can get some large sail plane wings in it.
Not sure this plane will fit..However, my daughter has a van and I will call on here if required. One other thing...I feel kind of like the guy who built a boat in his basement and no idea of how he was going to get it to water...this is where I am.
I am attaching the out of the box photo. The box weighed 35#....all wood. The laser cutting is excellent...The four sheets of plans are included along with a build manual and hardware pack.
I will do my best to follow the recommended process.
rjrobbin is offline Find More Posts by rjrobbin
Old Aug 22, 2013, 02:32 PM
jonquinn is offline
Find More Posts by jonquinn
USA, PA, Westmoreland Co.
Joined Aug 2008
Neat. I'd like to build one of these too - is this the new laser cut version? Isn't this supposed to break down into smaller pieces (2 piece fuselage) but of course the wings would still be pretty big at 6' each.
Have you watched the video of the 12' telecaster dropping payloads of corn for deer to eat?
12' Telemaster Deer Feeder.wmv (8 min 16 sec)
This very deer feeding plane sold not long ago here on RCG, and for a pretty nice price too. I wish I was still traveling down to Tuscaloosa for work, as I would have jumped on that deal.
jonquinn is offline Find More Posts by jonquinn
Old Aug 22, 2013, 02:58 PM
rjrobbin is offline
Joined Dec 2006
http://m.youtube.com/watch?v=cdLnhCW...%3DcdLnhCWbHqw
Yes this is the laser cut version
Well....the fuselage does not break down..however, the stabilizer and rudder/fin can be removed as an assembly. The servos are mounted to the assembly...this could be the saving grace as far as getting the bird into my car. The wings are 6 feet and the chord is almost 24 inches......
I may end selling this once I get it built...( make offers ) i.e may be just to big to haul around with my transportation...nothing against the kit..i.e advertised as big....
Old Aug 23, 2013, 10:47 AM
rjrobbin is offline
Joined Dec 2006
Getting started
I did an inventory of the supplied items as suggested in the build guide.
Several laser cut sheets were duplicated..ie. probably just an error in the manual and an extra sheet 1a that was not listed. There were some 36 inch x 1/16 inch sheets that were only 4 inches wide compared to the manual that indicated 6 inch wide sheets....Sent a note off to Hobby Lobby for clarification.
I bundled the sticks according to size and separated the hardware. Looked as if everything else was complete.
I organized the laser cut sheets in numerical order as suggested. 91 sheets in all counting the duplicates. Because of the laser cutting, parts will tend to fall out if not careful. I used masking tape to hold some parts in place...not an issue. Just be careful handling the sheets.
Prepared an 8 foot building surface...its only 18 inches wide which may be an issue.
Next the assembly.
Old Aug 27, 2013, 07:53 AM
rjrobbin is offline
Joined Dec 2006
Stabilizer
After constructing the alignment pins, I started on the stabilizer. The yellow rule on the top is my straight edge..it has a nice edge for aligning parts. The center section has lead shot bags to keep the parts against the boards..the outer ribs are space holders keep the trailing edge in place..I had to splice the two 1/8 by 1/2 inch hardwood spars.
Note...I am following the build log on rc-universe. I cut away the material against the pin area on the blocks so that when the nail was inserted, it didn't cause a dimple that would interfere with parts placed on top for alignment.
Old Aug 28, 2013, 08:44 AM
rjrobbin is offline
Joined Dec 2006
Stabilizer almost done
I have the shear webs, leading edge and hinge point blocks installed.
The plans called for a 1/2 x 3/4 x 48 inch stick for the leading edge....not there. I used two 1/2 x 1 x 36 inch sticks spliced together and trimmed to size.
The directions call for placing the shear webs against the inside of the ribs..the shear webs are about 3/16 inch short of filling the area between the ribs...from my sail plane building, I always try to get a tight fit here so that when the top spar is placed, the structure is stronger ( my belief ). I also sanded the top of the shear webs just slightly so that when the top spar is in place it is flush with the ribs......
Old Aug 28, 2013, 05:49 PM
rjrobbin is offline
Joined Dec 2006
Stabilzer done
I finished the stabilizer. Did the initial sanding.
On the wing tips, I used a 1/8 inch spacer to set the gussets then did the 45 degree sanding....came out good.
The parts for the kit have fit very well...Impressed with the laser cutting
This is big...can't image how big the wings are going to end up..
Old Aug 29, 2013, 05:53 AM
malitape is offline
Find More Posts by malitape
malitape's Avatar
USA, FL, Palm Bay
Joined May 2008
Glad to have found this thread. I plan on building one in near future. Pics are worth a thousand etc, etc. So please take a lot of them to share.
pete
malitape is offline Find More Posts by malitape
Old Aug 29, 2013, 06:55 AM
rjrobbin is offline
Joined Dec 2006
pete
There is another build thread in rcuniverse....it has lots of pictures..that guy is three months ahead of me......It has been enjoyable so far. Thanks for looking in.
Old Aug 30, 2013, 02:46 PM
rjrobbin is offline
Joined Dec 2006
Elevator finished
I doubled up on the hinge blocks...i.e two at a time on the alignment pins.
The assembly went together with out any issue. I have one picture showing the structure with masking tape holding the leading edge of the elevator so I had good contact with the ribs and hinge blocks.
I used blue painters tape to protect the ribs while sanding.
I have several views with the elevator with the sanding done.
I used a band saw and cut the hinge bevels per the directions.i.e 26 up 35 down.
The last two shots show the stabilizer elevator assemble.
Old Aug 30, 2013, 03:10 PM
rjrobbin is offline
Joined Dec 2006
Vertical fin
The vertical fin is made up of four laminated parts...construction is straight forward.
The tail group is taking shape.
Old Aug 30, 2013, 11:16 PM
KNS is offline
KNS
Find More Posts by KNS
KNS
Switzerland, SO, Olten
Joined Dec 2012
subscribed and watching with interest
KNS is offline Find More Posts by KNS
Old Aug 31, 2013, 07:06 AM
Ken USA is offline
Find More Posts by Ken USA
United States, IN, Hammond
Joined Jan 2013
That video really presents a nice flying plane. WOW!
Looks like an awe inspiring build.
Ken USA is offline Find More Posts by Ken USA
Old Sep 04, 2013, 01:24 PM
rjrobbin is offline
Joined Dec 2006
Rudder assembly
The rudder parts were laid out and then glued together according to the instructions...nothing special...I did some sanding, beveled the leading edge and added it to the tail assembly....nest the fuselage.
Old Sep 06, 2013, 01:37 PM
rjrobbin is offline
Joined Dec 2006
Fuselage side assembly
The forward fuselage is composed of six parts that are glued together and then laminated. The aft-end of the fuselage is composed of 4 parts. I glued and laminated the two forward sides with gorilla glue. I practiced with some scrap wood to get the process down. If you use to much, the glue will foam and make a mess. I attempted to clean up any excess as it was curing, especially in the cut outs.
Notice, there is a decision point here...i.e make two right sides, make two left sides or in my case, a left and a right. I marked the inner surface with an 'I'.
I laid all the parts out then glued them together. I had the outside surface down. I then turned that side over, inserted the alignment pins and place the other side over it. i.e outside surface together. I then glued the assembly. The point here is that I was attempting to get both sides identical.
I assembled the anti-pivot plate. working on the firewall lamination.
Question 12 Foot Telemaster Plans from Hobby Lobby getndirty Balsa Builders 28 May 09, 2015 05:22 PM
Sold 12 foot Telemaster kit build chyorn Aircraft - Fuel - Airplanes (FS/W) 11 Sep 28, 2013 03:23 PM
For Sale 12 FOOT ELECTRIC TELEMASTER, BNF by Hobby Lobby harrymc Aircraft - Electric - Airplanes (FS/W) 6 May 15, 2013 03:40 PM
For Sale Receiver ready 12 FOOT WINGSPAN TELEMASTER with new Quadra 42cc! Great deal $799 !l shooboy Aircraft - Fuel - Airplanes (FS/W) 14 Jan 21, 2013 04:05 PM
Sold 12' Foot Giant Telemaster Hacker A80 w/Candy Drop Alkaline Aircraft - Electric - Airplanes (FS/W) 2 Jan 05, 2013 07:42 PM
