Old Feb 24, 2012, 06:06 PM
jtprouty is offline
Find More Posts by jtprouty
Inherent Tinkerer
Wichita, Kansas, USA
Joined Jul 2003
Anyone used Dragon Link and Dragon OSD V2 with Atto?
Hi Guys,
I'm trying to figure out if it's possible to use a Dragon Link and Dragon OSD V2 with an Atto V3 and how to hook them up. It looks like the Dragon Link hooks into the Dragon OSD through the PPM stream input and then I can take power, ground and signal from one channel to Atto and then signal and ground from the remaining servo outputs. Anyone know if that's correct?
Thanks!
Jimmy
jtprouty is offline Find More Posts by jtprouty
Old Feb 27, 2012, 08:51 PM
chancesAU is offline
Find More Posts by chancesAU
chancesAU's Avatar
Australia
Joined Apr 2008
Hi Jimmy,
There's a couple of ways you can hook up the OSD, im assuming you dont want to use the OSD as your autopilot so there is no need to use the PPM stream. It will just be an OSD which you will need to re-program to make any changes via USB-Serial cable and a computer.
On your Dragon UHF RX it will have 9 set's of pin's, ch1 - ch9. Just set it up like you would any other RX -> Atto and forget about the ch9 pins (PPM).
With the OSD there is no need to use the current sensor, just video, power, GPS and RSSI.
Like I said theres a few ways of doing it.
If you want, give me a call on Skype and I can explain it betterer
Cheers,
Max
chancesAU is offline Find More Posts by chancesAU
Old Feb 27, 2012, 09:06 PM
jtprouty is offline
Inherent Tinkerer
Joined Jul 2003
Thanks, Max.
Actually, this is being setup by someone else and they want to be able to use the Dragon OSD as a backup RTL in case Atto would fail. I realize that Atto is extremely reliable and chances of it failing are very remote but the project he's working on is driving his need to have the additional RTL. Not even sure if it's possible to set it up that way.....
Jimmy
Old Feb 27, 2012, 09:22 PM
chancesAU's Avatar
Australia
Joined Apr 2008
Ahh... well im not sure how you would do that off the top of my head as each servo would need to be plugged into both the Atto and DragonOSD control board's.
He would need a device would could hand control over to the other autopilot... id say the best bet would be to start with 2 identical AP's ??
Help! Wiring help Rmilec UHF(RD4047) with Dragon OSD+ v2 dr_serious Electric Plane Talk 0 Dec 18, 2011 03:56 PM
Discussion dragon labs osd v2 (dragon osd v2) gider FPV Talk 5 Oct 03, 2011 09:41 PM
For Sale My entire FPV rig must go - Dragon link, fatshark, OSD, antenna tracker, etc billdsb FPV Equipment (FS/W) 12 Sep 10, 2011 05:09 PM
For Sale New items for sale - GoPro HD, Dragon OSD V2, Headplay, 2.4 lawmate fpvhex FPV Equipment (FS/W) 2 Jul 01, 2011 01:11 AM
Discussion What is your experience with Dragon OSD+ V2? thygekm FPV Talk 4 Nov 23, 2010 12:35 AM
