Old Today, 04:09 PM
John Gallagher is online now
Find More Posts by John Gallagher
John Gallagher's Avatar
Lindenwold, NJ, USA
Joined Dec 2000
Reduce voltage of 3 cell lipoly
I have an old speed 400 powered glider that I would like to convert to use the available 3 cell lipoly batts I used with my Radian - 1000 mah to 1300 mah.
I bought a brushed lipoly speed controller for it. On another glider the motor burnt out at this voltage. I used 8 cell (9.6 volts) nimh packs without a problem for the speed 400 motors.
Does anyone know of a voltage regulator that will bring the volts from 11.1 down to ~9.5 volts.
Please don't tell me to convert to a brushless. I have too many other projects to do this in the near future.
Please don't tell me to use 2 cell packs. I just bought a bunch of 3 cells and this glider has poor climb rate on 7.4 volts.
John Gallagher is online now Find More Posts by John Gallagher
Old Today, 04:40 PM
rev.iain is online now
Find More Posts by rev.iain
Mesa AZ, it's a dry heat!
USA, AZ, Mesa
There are not many easily obtainable high current regulators that will take a 3S down to about 10 volts and carry 12-15A. I would suggest you search on the internet, (Amazon maybe) for such a regulator.
If I was faced with the same situation I would make one, but that is not in everyone's skill set.
A cheap and dirty way to do it would be with some high wattage low resistance power resistors, hanging out in the breeze for cooling purposes. As I said, this is a quick and dirty fix, and needs some experimentation to find the right values.
Iain
rev.iain is online now Find More Posts by rev.iain
Old Today, 04:53 PM
Lindenwold, NJ, USA
Joined Dec 2000
Iain
Thanks Lain.
Electronics is Not my skill set. So far most regulators on Amazon are talking 2 or 3 amps. Will keep looking.
Old Today, 04:58 PM
Petem is offline
Find More Posts by Petem
If it flies - I want one!
Petem's Avatar
Australia, VIC, Werribee
Joined Jul 2008
Prop size
Just thinking in another direction - voltage may not be what kills motors; it's more likely excessive current.
Could you reduce the current draw by fitting a smaller prop?
Cheers,
PeteM
Petem is offline Find More Posts by Petem
Old Today, 05:53 PM
patmcc is offline
Find More Posts by patmcc
Northumberland, England
Joined Jan 2007
The limiting factor for the motor is the current. 8 cell nimhs probably only delivered about 8v under load whereas 1000 - 1300mAH lipo would give about 11v. There would be a huge jump in current if using the same prop. As Petem says a smaller prop could be used to limit the current, problem might be finding a suitable prop.
Alternative solutions would be :
a) 2s lipo with a bigger prop to bring the current to the same level as 8 nimhs (this would reduce the potential max watts but the increased efficiency of the bigger prop would compensate)
b) 3s LiFe would give a smaller increase in the delivered voltage fairly close to a freshly charged 8 cell nimhs battery. This might be OK with the original prop size.
patmcc is offline Find More Posts by patmcc
Old Today, 07:32 PM
Lindenwold, NJ, USA
Joined Dec 2000
I was using a 6x3 folder on motor that burned out. Would a plastic zagi prop be better? The zagi is 5x5.
If I cut the zagi prop down to 4.5 x 5 would that work?
edit: Even I realize that if you multiply the diameter x pitch you would get a larger power requirement for a 5 x 5 or 4.5 x 5 prop.
Old Today, 08:27 PM
Lindenwold, NJ, USA
Joined Dec 2000
If I limited my throttle to 75% using the computer transmitter, would that solve the problem?
Old Today, 09:12 PM
crosstrim is online now
Find More Posts by crosstrim
"Rocket Scientist"
crosstrim's Avatar
United States, AZ, Mesa
Joined Feb 2008
Intuitively, you would think so, but the speed controller will still be delivering the pack voltage, around11.X volts, to the motor, just for shorter bursts. It would be nice if you could just average it out, but most motors don't know how to do that
ct
crosstrim is online now Find More Posts by crosstrim
Old Today, 09:12 PM
USA, AZ, Mesa
The problem with running any ESC at reduced throttle is that the excess voltage is dropped across the ESC, and with the subsequent current flow generates heat and so will overheat and possibly burn it out.
Without a suitable regulator, and utilizing the batteries and motor you have, it is almost a case of not being able to get there from here.
If I can find an old S400 motor and a suitable ESC I will run some experiments with dropping resistors as I mentioned above.
Iain
Discussion HobbyKing Cell Key - 6s Lipoly Cell checker. ? starzak Electric Plane Talk 4 Apr 28, 2015 10:17 PM
Sold 3 Cell 1320 mAh "Pro Lite" 11.1V LiPoly REDUCED ASAMech Aircraft - Electric - Batteries & Chargers (FS/W) 2 Aug 11, 2008 01:49 PM
What Voltage to Input with CBA and 2 and 3 Cell Lipoly? aplphabandaid Batteries and Chargers 0 Apr 22, 2005 10:08 AM
Question Help! Need a Low Voltage Warning for my 3 Cell Lipoly Batteries LittleJoey Batteries and Chargers 16 Dec 19, 2003 05:17 AM
Reducing the voltage of a 3 cell Li-poly pack? KenP Batteries and Chargers 3 Sep 05, 2003 04:34 PM
