Old May 12, 2015, 11:12 AM
Andrew Radcliffe is offline
Find More Posts by Andrew Radcliffe
Andrew Radcliffe
Andrew Radcliffe's Avatar
United States, FL, Clearwater
Joined Sep 2011
Build Log
NEW DAY VIDEO! THE ONE HIT WONDER (SEE PG4) 3d Dollar Tree foam plane
One Hit Wonder (1 min 58 sec)
The One Hit Wonder is a 30" Dollar Tree 3d plane we designed taking all of the positive flight characteristics of recent commercial foamies together with the positive characteristics of other similar size foamies we see posted here. We added a few thoughts of our own to the airframe and now know this one is too good not to share. For a total airframe investment of $2 and a couple of hours work including paint this bird outperforms any foam plane we have flown or seen flown to date.
The equipment is simple, a 1700kv Hobbyking Blue (actually now silver) wonder (https://www.hobbyking.com/hobbyking/...dProduct=38720), an 8 x 3.8 s.f. prop, a 20 amp (over sized) ESC, a DSM2 Lemon RX, two Turnigy 6 gram servos and one Turnigy 10 gram servo. Power is from a 450 ma two cell AGA USA battery (25C) http://www.aga-powerusa.com/batterie...50-25c-2s-7-4v , by far the best in it's class and we have found to out perform even 850 ma batteries of equal C rating. Angle the motor 3.5 degrees to the right and dead in line vertically to obtain the best stable hover.
The reinforcement consists of struts (bamboo skewers), a 28" long 1mm x 3mm CF rod in the wing, a couple of 1mm X 3mm strips at the stress points, a 1mm x 3mm strip on the elevator, and a couple of tail struts made from 2mm round CF. This reinforcement has been arrived at as we built this one, the prototype with a bare minimum of reinforcement and flew it through some hellish maneuvers doing everything possible to break it in the air. when we succeeded, we simply glued it together and added CF (and the struts....)
More about the reinforcement on the second page, read about the build 2 to see the evolution based on our learning curve.
There is one, and only one drawback to this airframe. It flies so well you will find yourself doing impossible maneuvers inches from the ground and flying threw gaps in tree branches and the like, because you find you can. And unfortunately, Dollar Tree foam is a bit too brittle when you do make that inevitable miss. But then again, it is just a matter of a bit of glue or at worst another $2.00 in foam and you are up and flying again. Do not make our mistake. If you airbrush it with a hand cut stencil, like we did, keep the stencil, you will need it! A small price to pay for the pleasure of flying this thing.
Andrew Radcliffe is offline Find More Posts by Andrew Radcliffe
Old May 13, 2015, 09:49 AM
Freddy5519 is offline
Find More Posts by Freddy5519
Joined May 2015
It looks like a lot of fun. Why is it the "one Hit Wonder"?
Freddy5519 is offline Find More Posts by Freddy5519
Old May 13, 2015, 10:11 AM
basicguy is online now
Find More Posts by basicguy
Ayn Rand Sez.............
basicguy's Avatar
United States, MO, La Plata
Joined Dec 2014
Hi,
What is the reason for the serrations on the ailerons?
basicguy is online now Find More Posts by basicguy
Old May 13, 2015, 03:55 PM
Granted is offline
Find More Posts by Granted
serial scratchbuilder
Granted's Avatar
Canada, BC, Mission
Joined Sep 2012
I'm guessing you've never built with dollar-store foamboard before. You only get one good crash.
Granted is offline Find More Posts by Granted
Old May 13, 2015, 04:26 PM
Andrew Radcliffe
Joined Sep 2011
Exactly, but actually, the bird itself is proving me wrong. I have hit the ground badly twice doing rolls a foot off the ground, and the light pole once, while I was brain dead!). Yet it has not broken too much to be glued YET, ( it flies again tonight!) I think the side-force generators have helped by adding a bit of extra rigidity at the end of the wings and some protection for the ailerons.
Old May 13, 2015, 04:30 PM
Andrew Radcliffe
Joined Sep 2011
Originally Posted by basicguy View Post
Hi,
It seems to add a bit of stability in a harrier. I do not know why, but on past planes it has been so, so we included them on this one. We got the idea the first time from the Twisted Hobby MXS-C and it seems to have merit.
Old May 14, 2015, 08:59 PM
Andrew Radcliffe
Joined Sep 2011
We flew again tonight and experimented a bit with determining the proper max build weight. The original plane weighed about 160 grams (+ 450 ma battery). We have flown it severely with the clear intent of breaking it in half in mid air. The idea is to reinforce the final build only in the stress areas and ignore the rest to save weight. We have identified the 4 spots the body fails and the area at the tips of the wings both broke when abused in the air. Those failure areas are now a mass of glue and we are at 172.2 grams right now and it flies great. We added two nickels at the cg to add ten grams and at 182.2 you can tell a little difference. Two more nickels hitting 192.2 grams, well it still flew well but the highest really we can stand is the 182.
So now we will do a bit of thinking about the best ways to isolate the stress areas and add the minimum amount of weight. Any Ideas anyone has to cut back weight in the final build would be much appreciated!
Old May 14, 2015, 09:49 PM
basicguy's Avatar
Joined Dec 2014
Can you move the components around to get your CG without added weight? Make them a structural part of your plane.
Old May 15, 2015, 06:26 AM
compressor man is offline
Find More Posts by compressor man
CAP smasher
compressor man's Avatar
GA,USA
Joined Jul 2010
Nice! Thanks for posting this!!
Chris
compressor man is offline Find More Posts by compressor man
Old May 15, 2015, 06:58 AM
Andrew Radcliffe
Joined Sep 2011
Chris
You are welcome. We are very interested in seeing others built it and hearing about their ideas. We build a lot of planes, but once and a while you run across one that seems to have real potential. And this community has a lot of people with all the best experience in the world!
Old May 15, 2015, 07:01 AM
Andrew Radcliffe
Joined Sep 2011
No, you misunderstand. the only weight to be added is reinforcement (and right now, as we beta test the thing) repair glue. The final CG is set by shifting the battery, not by adding weight. We had to lengthen the nose a bit from our first sketches to make it work out, but just 3/4" or so. Our challenge is to make it strong enough to take the abuse we are giving it yet keep it light enough to perform as intended, without using expensive of hard to find materials.
Old May 15, 2015, 07:05 AM
Andrew Radcliffe
Joined Sep 2011
Does anyone have any experience on covering small areas of Dollar Tree foam with doculam? One idea is to make inside painted colored "patches" of doculam laminating the stress points, spray them with 3m 77, and then iron them on to both sides of the spots expected to crack. That way we should get the strength of the lamination and color at the same time for very little weight added. I wonder about the iron heat..........
Old May 15, 2015, 07:10 AM
CAP smasher
GA,USA
Joined Jul 2010
Have you considered using colored shipping tape for lightweight reinforcement?
Old May 15, 2015, 07:45 AM
Granted is offline
Granted's Avatar
Canada, BC, Mission
Joined Sep 2012
I can try it when I get home, got lots of low-temp laminating film and foamboard.
Old May 15, 2015, 10:25 AM
sconnie is offline
Find More Posts by sconnie
a random dude
sconnie's Avatar
Joined Nov 2014
this is great. I've been building with dollar tree foam, so this might be my next build.
a couple of questions. Are you peeling the paper off of the foam, or is this with paper on? Do you use primarily hot glue or what kind of glue do you use?
thanks,
sconnie
sconnie is offline Find More Posts by sconnie
Discussion CreativeRCutah scratch build dollar store foam board plans creativercutah Hot Online Deals 1 Feb 06, 2015 08:54 AM
Help! Removing paper from Dollar Store foam Single Minded Foamies (Scratchbuilt) 10 Oct 07, 2014 06:05 PM
Joke Musical one-hit wonders (any genre) Slammr Humor 9 Oct 04, 2014 08:31 PM
Discussion Dollar store Foam Board DLG storage Box boomerwing Hand Launch 0 Jun 28, 2014 12:47 PM
