Old Apr 29, 2015, 04:32 AM
candane is offline
Find More Posts by candane
Turkey
Joined Oct 2008
BAE Hawk glow DF to electric
I think it is a nitroplanes.com Bae hawk but I am not sure.
http://www.nitroplanes.com/redardftu7al.html
One of the my friend gave me the plane. It has a dynamax glow fan.
I planned to replace with jetfan 120 and het 800 590 kv motor 12 S. I think it will be over power. But inlet suitıble this fan.
By the way I couldnt remove the dynamax rotor. I heated it but didnt work. I dont need glow motor and shroud I can use only rotor in the future. For this reason I think to cut glow motor and shroud. Does any body have any suggestions?
candane is offline Find More Posts by candane
Old Apr 29, 2015, 07:18 AM
CoolerByTheLake is offline
Find More Posts by CoolerByTheLake
Do it Right, the first time!
CoolerByTheLake's Avatar
United States, MN, Hermantown
Joined Dec 2008
Before you get to far along-- if your thinking of the jetfan 120m make sure you have an exit dia on tailpipe of at least 100 mm, 105mm is preferred. T
CoolerByTheLake is offline Find More Posts by CoolerByTheLake
Old Apr 29, 2015, 07:19 AM
Joined Dec 2008
double post
Old Apr 29, 2015, 09:05 AM
Chris True is offline
Find More Posts by Chris True
St. Mary, Maryland, United States
Joined Dec 1996
What pray tell did you heat?
Remove the allen head bolt, pop off the spinner, removed the nut then use a puller to pop the rotor off.
Chris True is offline Find More Posts by Chris True
Old Apr 29, 2015, 09:48 AM
candane is offline
Turkey
Joined Oct 2008
Thank you I checked exit diameter thrust tube 95 mm but I can do it 100 mm or more. Tailpipe is suitıble for jet fan 120. I have a jetfan 120 as redundant.
But this plane will be 5 kg but jetfan 120 thrust is 7-8kg.
Old Apr 29, 2015, 10:06 AM
candane is offline
Turkey
Joined Oct 2008
I heated allen bolt in spinner because I couldnt remove this bolt. I couldnt immobilized the rotor with my hand. Otherwise Either rotor will cut my hand or rotor will be broken. I can sacrifice engine and shroud to save rotor. Because I want to use dynamax rotor with hayoe 5 inch shroud.
Old Apr 29, 2015, 10:21 AM
Joined Dec 2008
I had a dynamax fan a few years back, I just made the PROPER tool to hold the rotor , very easy to do.
Scroll down just a bit, you;ll see what it looks like-- http://www.jetmodelproducts.com/dynamax.htm
DYNAMAX ROTOR WRENCH
Old Apr 30, 2015, 03:10 AM
jofro is offline
Find More Posts by jofro
Joined Jan 2010
What is the w/span ? I doubt you will be overpowered, with this size models you never are unless you build them out of foam. What do you expect to be AUW? This is my highly modified 72" IC one I converted to 2meter span to reduce the heavy w/loading. Much nicer flying model now.
jofro is offline Find More Posts by jofro
Old Apr 30, 2015, 04:42 AM
candane is offline
Turkey
Joined Oct 2008
Jofro, very nice plane. Mine is very ugly yet. Thank you the idea. I also can modify my wing like yours. I alredy removed wing covering film and I will do epoxyglass. I will paint completely.
This plane weight (with glow turbax 5 inch fan) is 4.5-5 kg. but with my electric setup maybe it will be 5.5kg. I had thought to fly it wiht 90 mm jetfan and 12 S. I believe She fly very vell with jetfan 90 . But planes inlet and ducts are very large. 120 mm more convenient.
I tried my jet fan 120 het 800 and 5000mah Gens age 12 S lipo thrust was more than 8 kg.
But If I modify it plane weight increase.
Old Apr 30, 2015, 11:22 AM
turbonut is offline
Find More Posts by turbonut
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
Your jet is a old AMD/Jet Hanger Hobbies hawk. Search here on RCG and you can find a lot of info on converting to epower.
Old Apr 30, 2015, 07:36 PM
jofro is offline
Joined Jan 2010
Nothing ugly about your model, looks great to me but what's the span? Sorry, but you must be dreaming thinking of 5.5kg AUW. Some of my 'FF' 90mm foamies are that weight, how did you work out that figure with 5" fan, 12S power and even fibreglassing wings? Just looking a it I would say easy 8kg + range.
Old Apr 30, 2015, 11:30 PM
turbonut is offline
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
That hawk will build out at 6.5kg any day...been done many times
Old May 06, 2015, 08:10 AM
candane is offline
Turkey
Joined Oct 2008
Yes this plane is AMD hawk. Jofro I think your plane is bigger than mine. Wing spane only140 cm.
I will go with JF 120. Because hawk has nice big intakes with rounded lips and large exhaust.
I have a Cermark F16 converted JF 90mm EDF . It is bigger and maybe heavier my hawk. Last week it flew with 90 mm EDF. But cermark inlet is narrow.
Old May 06, 2015, 10:39 AM
turbonut is offline
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
The Jetfan 120 will fly great in this plane. You could use the 90mm to make it lite weight and that is a good idea for this airframe. You will want to add the wing fences also to help with tipstall..
Old May 06, 2015, 01:30 PM
kevin is offline
Find More Posts by kevin
kevin's Avatar
ohio
Joined Aug 1999
Here is my conversion from 6 years ago...
http://www.rcgroups.com/forums/showt...k#post12298827
and video...
AMD/JHH BAE HAWK DUCTED FAN JET AKA VERTIKLEEZ (4 min 7 sec)
kevin is offline Find More Posts by kevin
Latest blog entry: Video of my HK Cobra
Sold BNIB Eflite BAE Hawk DF 15 with HiMax fan unit adgnade Aircraft - Electric - Jets (FS/W) 2 Nov 17, 2014 06:03 PM
Sold Eflite BAe Hawk 15 DF $95 lenci1938e Aircraft - Electric - Airplanes (FS/W) 1 Jan 06, 2014 07:19 PM
Discussion 70mm DF Hobby King BAE Hawk conversion Grantham Kid Pusher Prop Jet Models 4 Dec 25, 2013 10:28 PM
Cool New e-Flite BAe Hawk 15 DF DiabloKid Electric Ducted Fan Jet Talk 2 Oct 16, 2008 10:20 AM
Discussion New DF BAE Hawk ARF skyhawk Electric Ducted Fan Jet Talk 17 Jan 13, 2007 07:52 AM
