Old Jun 16, 2015, 06:44 PM
Forced_Inducti is offline
Find More Posts by Forced_Inducti
Joined Dec 2008
Nose heavy is not that bad, but tail heavy can be an airplane killer. In full size aviation it can cause the tail to stall before the wing and cause an unrecoverable stall. With rc it's not as bad but it makes it really difficult to control. With the plane trimmed for gliding with power off, put it into a 45° dive. It should nicely pull out of the dive. If it pulls up quickly you can move the cg back. If it stays in the dive or dives more, definitely move it forward.
I haven't measured mine but it'son the servo wires on a 2015 1720 and I'm probably going to move it forward a bit when I get my new pack in.
2 months old packs should be fine. Unless they've been seriously abused.
Forced_Inducti is offline Find More Posts by Forced_Inducti
Old Jun 16, 2015, 11:41 PM
bhoov128 is offline
Find More Posts by bhoov128
John 20:1-18
bhoov128's Avatar
United States, FL, Davenport
Joined May 2012
Originally Posted by jkishan16 View Post
Okay,
I think I may have sorted my issue out,
My batteries have low C ratings (20C)
Running the 1250KV with a 9x6 (changed it last night) pulling 30A (over 300W) on WOT and about 100W on half throttle (weird as I do not have a throttle curve/expo)
I am flying about 8 minutes per 3S 2650mAh battery and landing at a voltage of 11.2-11.4V (after resting for a minute after landing).
So, I think I can push to a 10 minute flight to drop down to perhaps 10.8V per cell (rest voltage) which seems reasonable (I assume)
She still behaves quite tail heavy though, (keeps the nose pointing slightly up) at the 125mm CG mark :S
More work to do I pressume ^^
EDIT:
Doing tests on my watt meter, batt falls to 10.5V on a 10-15A pull and down to 9.5V pulling 30A (when the starting voltage was 11.4V)
Resting voltage is probably the worst way to measure a pack's health or capacity. It tells you virtually nothing. It does not take into account a pack's internal resistance or ability to supply current.
You need to recharge it after a flight with a charger that will tell you how many mAh are charged back in, and follow the 80% rule: your 2650s should never be discharged past 80% of mAh capacity or 2120 mAh. If you're still weak on power and you know you're putting back a charge capacity well within 80% spec then I suspect your batteries may be junk.
bhoov128 is offline Find More Posts by bhoov128
Latest blog entry: Snice Slick
Old Jun 18, 2015, 03:05 PM
Buffythesaint is online now
Find More Posts by Buffythesaint
Joined Feb 2005
Some fun with the trusty Skywalker.
SkyWalker's Neighbourhood (20 min 55 sec)
Buffythesaint is online now Find More Posts by Buffythesaint
Old Jun 21, 2015, 05:28 PM
gatorb8 is online now
Find More Posts by gatorb8
Registered Offender
gatorb8's Avatar
United States, FL, Gulf Breeze
Joined Apr 2008
anyone know where the manual is for the 2014 skywalker 1800?
haven't flown mine in a year and can't find the manual to remember the CG
thanks!
gatorb8 is online now Find More Posts by gatorb8
Old Jun 22, 2015, 01:01 AM
mike_o is offline
Find More Posts by mike_o
mike_o's Avatar
Denmark, Nærum
Joined Jan 2012
thanks!
Haven't got the manual, but most planes fly with the CoG one third from the leading edge. That goes for the SW too, even though most version get better efficiency from CoG between 1/3 and 1/2 from LE.
I'd try just behind 1/3 from LE, and gradually move it back...
mike_o is offline Find More Posts by mike_o
Old Jun 22, 2015, 06:56 AM
Registered Offender
gatorb8's Avatar
Joined Apr 2008
will do, thanks
heading out this morning!
Old Jun 22, 2015, 05:32 PM
Registered Offender
gatorb8's Avatar
Joined Apr 2008
You guys interested in reports on the 1800 here?
The other thread seems dead
Old Jun 22, 2015, 11:33 PM
bhoov128 is offline
John 20:1-18
bhoov128's Avatar
Joined May 2012
Is anyone looking for a NIB Skywalker 1680?
Old Jun 23, 2015, 04:31 PM
jkishan16 is offline
Find More Posts by jkishan16
Getting Somewhere :D
United Kingdom, England, Loughborough
Joined Dec 2012
I'd love it but you in the US mate
jkishan16 is offline Find More Posts by jkishan16
Old Jun 30, 2015, 05:24 AM
Heppy Ket is online now
Find More Posts by Heppy Ket
What place .... is this ???
Australia, SA, Adelaide
Joined Oct 2011
My Skywalker makes an untimely exit due to lax procedure by the ground staff :0
Perkana Point FPV with Jase :) (9 min 5 sec)
Heppy Ket is online now Find More Posts by Heppy Ket
Old Jun 30, 2015, 07:45 AM
Registered Offender
gatorb8's Avatar
Joined Apr 2008
planes only die when you let them........
get the hot glue gun out!!!
Old Jun 30, 2015, 10:03 AM
Joined Dec 2008
i didnt let the motor on my SW start on fire =P. wish i would have gotten video of that one!
Question Best plane for FPV while on vacation? patricklupo FPV Aircraft 24 Nov 23, 2014 03:56 PM
Cool FPV plane rescue with an FPV truck :-) AnthonyRC FPV Aircraft 17 Feb 24, 2008 10:45 PM
For Sale Skywalker plane and a bunch of extras moody07747 Aircraft - Electric - Airplanes (FS/W) 8 Sep 19, 2006 09:34 PM
Discussion Aviator Skywalker RC plane given to me moody07747 Electric Plane Talk 46 Sep 12, 2006 11:45 AM
