Old May 10, 2015, 02:38 PM
mior is offline
Find More Posts by mior
Slovakia, Nové Mesto nad Váhom
Joined Jun 2009
In this picture I see that the rear rotor is not aligned with the rudder. Is it right?
If yes, why?
mior is offline Find More Posts by mior
Old May 10, 2015, 10:36 PM
Ran D. St. Clair is offline
Find More Posts by Ran D. St. Clair
Ran D. St. Clair's Avatar
United States, CA, Sunnyvale
Joined Dec 2006
If yes, why?
Yes, it is intentional. The 4 wing motors are 2 CW and 2 CCW so in theory they cancel each other out in terms of torque. There is nothing to cancel the torque of the tail rotor however. It turns CCW when viewed from above, so the plane would naturally yaw to the right. by leaning the tail rotor to the right it drags the tail to the right, and nose to the left so it all cancels out. The plane then needs to lean slightly left to counter the right thrust from the tail, but it is such a tiny amount you can't even see it.
Ran D. St. Clair is offline Find More Posts by Ran D. St. Clair
Old May 11, 2015, 04:18 AM
mior is offline
Joined Jun 2009
And what is the angle of rotor, please?
Old May 11, 2015, 08:35 AM
Joined Dec 2006
You can measure it from the picture, or do what I did and see which way the plane wants to turn and adjust it from there. It is not critical. Yaw control is weak on the XC-142, since it is controlled by the ailerons. If there is any headwind, or the plane has any forward speed it will weathervane into the wind anyway. If flown indoors in a small room it will yaw somewhat randomly due to the air recirculation within the room. If you want to see the trim point you need to be outdoors on a calm day and at least 4 ft. off the ground.
Build Log Xc-142 malakiblunt VTOLs 76 May 11, 2014 02:52 PM
Discussion XC-142 VTOL Test Aircraft rimshotcopter VTOLs 17 Dec 25, 2013 10:46 PM
Build Log XC-142 VTOL Transport malakiblunt RC Airliners (Commercial, Cargo, Troop Carrier) 63 Jun 05, 2013 03:52 AM
Discussion Xc-142 malakiblunt VTOLs 22 Sep 28, 2010 03:39 AM
Discussion Vtol Xc-142 CESARNOGUEIRA VTOLs 0 Oct 01, 2009 09:25 PM
