Old Apr 28, 2015, 01:38 PM
Tallahassee is offline
Find More Posts by Tallahassee
Joined Mar 2015
Great footage and recovery!
Originally Posted by AGuerrav View Post
Oh! it was... wf high about 30 mts... this is the place and the path of the flight
http://i.imgur.com/UAH0KRd.jpg?1
Are you following the 'copter just by watching it from the ground, or were you doing fpv or gps routing? Seems like it was a pretty long flight to be able to see it that far from the ground, I would've been pretty nervous even without the failure!
Tallahassee is offline Find More Posts by Tallahassee
Old May 02, 2015, 09:56 PM
RCFlyerGuy is offline
Find More Posts by RCFlyerGuy
Justin L
RCFlyerGuy's Avatar
United States, CA, Laguna Niguel
Joined Dec 2009
If any of you are interested, I have a brand new Tarot FY680 Pro airframe that I am going to sell. I wanted to give you guys on this thread the first opportunity before posting it on the classifieds. I bought it, unpacked it, loosely assembled the parts by hand and put it up on the shelf without ever building it. I've seen these as low as $180 online so I am asking $150 shipped within CONUS. PM me if you are interested. Thanks.
RCFlyerGuy is offline Find More Posts by RCFlyerGuy
Old Jul 04, 2015, 03:50 AM
tatoviola is offline
Find More Posts by tatoviola
Joined Oct 2014
Hi, some of you are using these media : TL68B34 . as you are ?
tatoviola is offline Find More Posts by tatoviola
Old Jul 12, 2015, 12:16 AM
RotoRon is online now
Find More Posts by RotoRon
RotoRon's Avatar
United States, UT, East Carbon
Joined Jan 2014
Would there be any benefit or detriment to mounting the motors upside down and running the props in a pusher prop configuration on this frame?
RotoRon is online now Find More Posts by RotoRon
Old Jul 12, 2015, 12:51 AM
Capt Buscemi is online now
Find More Posts by Capt Buscemi
Capt Buscemi's Avatar
Australia, QLD, Brisbane
Joined Aug 2012
OK. Why?
The benefits - and I'm speaking here of multirotors in general - are many, of mounting the motors and props on top:-
1. More ground clearance. Also means shorter landing gear and therefore lighter.
2. Easier access to motors and props.
3. Slightly higher centre of thrust and lift on each arm, which improves stability.
4. Cooling airflow over motors (and ESCs if they are mounted outboard).
5. Better safety if any wires or other accessories mounted on arms come loose (won't be chopped by props).
6. Looks better
Can't think of any benefit at all of mounting them underneath. But let us know how you go if you choose to go that way.
Capt Buscemi is online now Find More Posts by Capt Buscemi
Old Jul 12, 2015, 01:41 AM
RotoRon's Avatar
Joined Jan 2014
Originally Posted by Capt Buscemi View Post
OK. Why?
6. Looks better
Probably not going to try it. I just wanted someone to talk me out of it.
I had to put this build on hold for a year but I finally ordered the rest of the parts I needed (motors and props) and I'm going to start putting it together soon. I still need to order some batteries. I was thinking to get a pair of 4S 5000 packs that I could optionally run in parallel if I wanted longer flight times.
Old Jul 12, 2015, 03:04 PM
Joined Aug 2012
Tarot FY680 hex
That works very well. My build mirrors a friend's 690, which has one 5000mAh toward the rear of the gimbal rails to balance the gimbal, the second goes on top, at the centre of gravity. The 690 has a top battery plate, the 680 doesn't, so I'll be mounting my second battery underneath the centre, on the rail.
His flight times are about 9-10mins with one battery, 15-16 with two.
Old Jul 21, 2015, 11:50 AM
mike_kelly is offline
Find More Posts by mike_kelly
Wisconsin
United States, WI, Hayward
Joined Jan 2012
The benefit to mounting the props under the arms is that the air flow does not hit the arm and cause turbulence.
mike_kelly is offline Find More Posts by mike_kelly
Latest blog entry: Index of Articles and tutorials
Old Jul 21, 2015, 12:11 PM
CyberCrash is offline
Find More Posts by CyberCrash
Germany
Joined Sep 2009
I don't get that logic.
Wouldn't the "sucked in air" be hitting the arm causing turbulences, too?
CyberCrash is offline Find More Posts by CyberCrash
Old Jul 21, 2015, 04:35 PM
Joined Aug 2012
My guess is the effect would be barely calculable. Would be interested to see your rig if that's how you've done it.
Old Jul 22, 2015, 08:13 PM
Wisconsin
Joined Jan 2012
Whole thread on it.
http://www.rcgroups.com/forums/showthread.php?t=2007928
Old Jul 29, 2015, 08:32 PM
Wisconsin
Joined Jan 2012
Yes,
http://www.rcgroups.com/forums/showthread.php?t=2373498
Old Jul 29, 2015, 11:45 PM
RotoRon's Avatar
Joined Jan 2014
I almost have everything to complete my build now.
I ordered one of the battery hangers for it since I will be using an AVDome on top.
I have 6mm bullet connectors but wanted to ask what everyone is using for battery connectors.
Also, most power distribution boards aren't rated for the full capacity of 6 30A ESCs. (180 amps). which is better, a wire harness, or a power distribution board, and if the board is better, what are you using?
Ii have motors, batteries, escs, wire, Fixhawk, etc. I am just waiting to figure out how to wire it.
Old Jul 30, 2015, 09:12 AM
Germany
Joined Sep 2009
Anybody using this Multistar Elite 3508 - 268kv motor (8S + 13" x 3.8) on his FY680 ?
Until yesterday I was going for the 4108-380KV Turnigy Multistar 22 (6S + 13" x 5.5).
But now, I am thinking that maybe the 8S motor could be the better option?
I hope anybody is using this setup or can tell me if this is a good choice to go from 6S 4108 - 380kv to 8S 3508 - 268kv....
Discussion Interested in getting a Mikrokopter hex or a droidworx hex. How hard is set up? LMAO Multirotor Talk 8 Dec 28, 2010 07:47 AM
Discussion Tarot 450SE V2 GF helipr0 Mini Helis 12 Oct 19, 2009 04:47 PM
Discussion Tarot 450SE V2 GF Kit? carmen5.3 Electric Heli Talk 8 Sep 18, 2009 08:54 AM
Discussion Align, Tarot, CopterX edfardos Electric Heli Talk 4 Mar 13, 2009 11:15 PM
For Sale Tarot 450 V2 KIT KS-Model Aircraft - Electric - Helis (FS/W) 5 Nov 10, 2008 10:16 AM
