Old Jul 24, 2015, 07:25 PM
lordsirob is offline
Find More Posts by lordsirob
lordsirob's Avatar
United States, FL, North Palm Beach
Joined Jul 2004
Originally Posted by GryphonRCU View Post
Look at your per cell voltages.......something looks weird there.
V = W / A
V / 6 = per cell voltage
Other than per cell voltage numbers under load being very high (possibly great battery) , why are they the higherst under most AMPs when they should be lowest.
And in fact, under most AMPs, its so high that I Doubt it. 3.94V under 130A load???
G.
I remembered to log the 6.5x6 and 6.5x6.5 tests, so I am posting the graphs and raw data files from the OpenTx Companion logs. The batteries are Revolectrix 427 blends charged to 4.2 volts. I guess the batteries are pretty good after all.
I have the Frsky battery telemetry sensor, but did not bring it out. I'll make sure I get cell and cells telemetry next time.
lordsirob is offline Find More Posts by lordsirob
Old Jul 24, 2015, 09:04 PM
GryphonRCU is offline
Find More Posts by GryphonRCU
GryphonRCU's Avatar
United States, CA, SF
Joined Mar 2008
Only comment I can make is regarding data plucking.
Don't take the very first set of peak values. Try and move forward about 1.0 to 1.5 second past that and read all values from there.
7 data points, that means changing over 6 periods.
Consumption changing by 23 , I assume mAH
Average AMPs = 130A
I assume your logging rate is every 1.5 seconds if I did not screw up my math.
So use the next set of data values after peak initial AMP.
23.5V changed to 22.1V
22.1 V / 6 cells = 3.68 Volts per cell
3.68 is way more reasonable compared to 3.9V
Not sure how accurate the voltage values are but it seems like a pretty good battery.
Since you are holding higher voltage under load, your motor will draw more AMPs and Watts and turn a bit more RPM too than folks who were getting those premature cutoffs.....and produce more waste (heat).
I believe reports were that 130A were about max for speed runs.
Hopefully that battery will serve you well for a long time.
Please report back after its long term use.
Good luck and have fun,
Gryphon
GryphonRCU is offline Find More Posts by GryphonRCU
Old Jul 25, 2015, 08:57 AM
lordsirob's Avatar
Joined Jul 2004
Average AMPs = 130A
Gryphon
I appreciate you leaning in. I guess peak values are not really where it's at, unless one wants to cherry pick the data. Just wait until I get and post a GPS peak speed >215 mph!
All kidding aside, the 6.5x6.5 was still pulling ~2600 Watts after 8 seconds of wide open throttle. I hope a few limited full throttle runs won't kill a battery. What would be the fun in that? I'll be monitoring the battery's health.
Again, thanks for the information. The 22 series Mega upthread certainly looks interesting...
LSO.
P.S - Logging is at 0.1 second intervals
Old Jul 25, 2015, 02:03 PM
GryphonRCU's Avatar
Joined Mar 2008
LSO,
Thanks for the post. 0.1 sec it is.
That is not a calculation I Normally due since logging rates are usually seen/known.
Double checked a 130A range file for similar mAH.
Then reached in the trash can and pulled out my scribblings from last night to see what I had screwed up. Started inversed, and if that was not bad enough, left out the 6 periods too. Laughing at myself.
I like learning about different loggers.
Do you have a link for yours?
A friend needs one for hotlining pending max AMP capability.
Gryphon
Old Jul 25, 2015, 02:21 PM
lordsirob's Avatar
Joined Jul 2004
LSO,
Gryphon
I am using the telemetry logging that is part of the OpenTx Companion 2.0 software. It won't help unless you are using an OpenTx transmitter, such as Frsky's Taranis.
OpenTx Software
USA distributer for Taranis
Additionally, voltage and amps through Unisens-E telemetry sensor (software is in German, but there are english translations on the web)
Unisens-E thingy
HTHs.
LSO
Old Jul 25, 2015, 03:47 PM
GryphonRCU's Avatar
Joined Mar 2008
LSO,
Thank you for the reply.
By the way, that Transmitter's USA distributor is a nice guy.
Since they are just 10-15 minutes North of the Golden Gate Bridge, I dropped in once. Completely blown away by the insanely low prices for 16 and 32ch options that he was talking about. Hard to wrap my head around 16ch, let alone 32chs.
Gryphon
Old Jul 25, 2015, 07:36 PM
cjbucher is offline
Find More Posts by cjbucher
cjbucher's Avatar
Raleigh, NC
Joined Sep 2004
LSO,
Gryphon
You need to use your fingers and toes to use all 32 channels!
cjbucher is offline Find More Posts by cjbucher
Old Jul 26, 2015, 05:07 AM
brolley is offline
Find More Posts by brolley
brolley's Avatar
United States, PA, Center Valley
Joined Dec 2008
LSO
Is that a new battery? Have you conditioned it? Holding ~3.6V/cell would be a game changer.
Did you also buy their new charger? I was looking at these batts a few months ago but couldn't find many reviews.... decided to get a cheap Turnigy instead.
Let us know how that batt comes around. I'd be interested to see how it holds up.
brolley is offline Find More Posts by brolley
Old Jul 27, 2015, 07:43 AM
rimripper is offline
Find More Posts by rimripper
rimripper's Avatar
Alberta,Canada
Joined Nov 2009
You'll need more than 2600 watts for 215mph....
LSO.
rimripper is offline Find More Posts by rimripper
Old Jul 27, 2015, 08:20 AM
lordsirob's Avatar
Joined Jul 2004
Hence the use of "all kidding aside"
Old Yesterday, 05:34 PM
lordsirob's Avatar
Joined Jul 2004
finally got off the ground
I got my bungee launcher together and the heavy 6 cell FJU finally got airborne (after a few tries- now have the correct tension figured out). Bummed out, telemetry iffy, no 215+ mph on gps:
The first landing took two tries and I still managed to overrun the runway (takes forever to bleed off speed).
I had one 5 minute flight just taking it easy and only used 1600 ma on my 3000 ma packs.
I will post telemetry on my next weekend flights.
Ultra fun with this FJU!
Discussion Funjet Ultra, more fast more fun.... tbmg1 FPV Talk 34 Jul 28, 2010 08:36 AM
Discussion Muliplex EasyStar WBFlyer FPV Talk 9 Mar 10, 2010 03:09 PM
Sold muliplex ASW 27 NIB bushpilotx1 Aircraft - Sailplanes (FS/W) 7 Aug 31, 2009 05:41 PM
Question Muliplex Alpha Junior Radio Instalation Allan Glover Sailplane Talk 3 Apr 09, 2004 01:37 AM
Muliplex MultiCharger 4010DC - is mine faulty ? borgs Batteries and Chargers 0 Jul 12, 2003 07:01 AM
