Old Sep 26, 2013, 05:12 PM
Little Red Plane
United States, TN, Knoxville
Joined Dec 2012
Turnigy GliderDrive SK3 Competition Series
Anyone use these motors?
What is your op[inion and how is their performance?
GarryOgilvie is online now Find More Posts by GarryOgilvie
Old Sep 26, 2013, 08:40 PM
I've been trying to find out too!
TreeFlyer is offline Find More Posts by TreeFlyer
Old Sep 26, 2013, 09:08 PM
United States, AZ, Surprise
Joined Jul 2002
4.6/480
Been using this motor to haul my Paragon with good results.
The cost is very good. Worth the try.
John
jcyr1 is offline Find More Posts by jcyr1
Old Sep 27, 2013, 04:40 AM
Romania, Dolj, Craiova
Joined Sep 2007
Same 3858 4.6/840 as John, in a 2.2kg/5lbs BoT, spinning a 14x8 from 3s.
Not far from MVVS used before, a 5.6/690, just a bit more noisy.
renatoa is offline Find More Posts by renatoa
Old Sep 27, 2013, 07:22 AM
LSF303 / AMA Life Member
tkallev's Avatar
USA, IL, Wheeling
Joined Jan 2003
Pic says it all ...
tkallev is online now Find More Posts by tkallev
Old Sep 27, 2013, 08:24 AM
Joined Sep 2007
Is Jonque, dude
Old Sep 27, 2013, 08:59 AM
Little Red Plane
Joined Dec 2012
tkallev, is that your opinion or your experience with that line of motors?
From what I have experienced only about 98% of all of the motors that we use are manufactured in China, so to say something is Chinese junk just because is was made in China is only opinion, and everyone has one.
What are the other options for that type of motor? MVVS? any others out there?
Old Sep 27, 2013, 09:02 AM
Red Merle ALES
Curtis Suter's Avatar
United States, Mt, Helena
Joined Apr 2002
I have several Hyperion motors glider and non-glider variety. They are having a fire sale on them however, the backorder wait may be long. But they are really nice motors, IMHO.
I like AlleRC for my motor purchases.
Curtis
Curtis Suter is online now Find More Posts by Curtis Suter
Old Sep 27, 2013, 10:31 AM
A witty saying proves nothing.
kcaldwel's Avatar
Joined Jan 2007
Originally Posted by tkallev View Post
Pic says it all ...
You mean you are acknowledging that the Chinese invented an efficient sailing method centuries before the western world?
I'm not sure this means they have a a couple hundred year lead in electric motors, but if you say so...
Kevin
kcaldwel is offline Find More Posts by kcaldwel
Old Sep 27, 2013, 05:41 PM
Little Red Plane
Joined Dec 2012
I have two of the Hyperion motors and am pleased with their performance, but I like to design of the MVVS, an outrunner in a can as they call it. The Turnigy GliderDrive motors seem to be similar in design, as the do not have the magnets rotating on the rear of the motor.
Anyone have any experience with the MVVS motors?
Old Sep 27, 2013, 06:18 PM
Red Merle ALES
Joined Apr 2002
There are a few pilots here in our club that have different sizes of MVVS motors. They all like them and I have heard of no ill results. They are heavier due to the external can I suppose, so if the weight isn't an issue I think you will like them too.
Curtis
Old Sep 27, 2013, 07:09 PM
kcaldwel's Avatar
Joined Jan 2007
I have a MVVS 5.6/960 motor in a Taborca with a 14.5x9 prop I think, 3S. It works very well, but is a bit heavy (270g). The Taborca is 4kg, and needs the nose weight anyway. It is nice to have the rotating bits hidden away, and it does make good power for this big, heavy glider.
Kevin
Old Sep 27, 2013, 07:18 PM
Joined Jul 2010
MVVS and Hobby King SK-3 and Hyperion
I have a number of ALES motors that I have bench tested with various diameter and pitch propellors and LiPo combinations.
In a direst comparison the MVVS 4.60/840 and the Hobby king 4.6/840 kv will swing the same prop at the same rpm's and current draw
I've been running the MVVS for a year now and am very happy.
If I compete I can switch motors quickly if needed.
The Hyperion glider motors are also very good on numbers,,,,,,,,,,,,,only drawback is the motor leads exit the housing toward the front of Motor (just behind where the tapered nose ends.
The MVVS and SK-3's have the leads exiting the rear of the motor,,,,,,,,,nice.
Rocketman60 is offline Find More Posts by Rocketman60
Old Sep 27, 2013, 07:31 PM
Little Red Plane
Joined Dec 2012
In comparing the 500watt motors the MVVS are the heaviest, but interestingly the Hyperion are not the lightest, I hope that I am comparing apples to apples, with in reason... Copy and paste from the websites:
MVVS 25 Series MVVS 3.5/960
Kv (rpm/V) 960
Max Power (W) 500W
Max Amp (15sec) 35A
Max Efficiency 85%
Io (No load A) 1.1A
Rm (Resistance) 0.0403Ohm
Shaft Diameter 5mm
Gearbox N/A
Motor Diameter 36mm
Motor Length 47.5mm
Motor Weight 168g
Built in Fan N/A
Max Rpm 25,000
Poles (Rotor/Stator) 12
Case Smooth
ESC Timing 20-25 deg
ESC Switching Freq. 8KHz
Turnigy GliderDrive SK3 Competition Series - 3850 - 3.5 960kv
Kv (rpm/v) 960
Weight (g) 142
Max Current (A) 35
Resistance (mh) 0
Max Voltage (V) 15
Power(W) 510
Shaft A (mm) 5
Length B (mm) 50
Diameter C (mm) 38
Can Length D (mm) 50
Total Length E (mm) 74
Update/Add my own data
Customer Data
Gs3014 Outrunner Motors Gs3014-16
Kv (rpm/V) 857
Max Power (W) 490W
Max Amp (15sec) 39A
Max Efficiency 85%
Io (No load A) 1.02A
Rm (Resistance) 0.038Ohm
Shaft Diameter 5mm
Gearbox N/A
Motor Diameter 37.5mm
Motor Length 46.3mm
Motor Weight 134g
Max Rpm 15,000
Poles 14
Case Outrunner
ESC Switching Freq. 8-16KHz
Gs3020 Outrunner Motors Gs3020-12
Kv (rpm/V) 780
Max Power (W) 550W
Max Amp (15sec) 50A
Max Efficiency 85%
Io (No load A) 1.21A
Rm (Resistance) 0.031Ohm
Shaft Diameter 5mm
Gearbox N/A
Motor Length 52.5mm
Motor Weight 176g
Max Rpm 15,000
Poles 14
Case Outrunner
All of these are around 500 watts and around 960kv.
I like it that the MVVS and the Glider
Drive don't have any rotating parts on the outside of the motors.
And just an FYI, I'm looking at reasonable costing motors that don't cost an arm and a leg, I actually know what an arm and a leg would cost, but I also want to spend my dollars wisely. If I'm going to spend big bucks I would rather spend them on something that doesn't just operate for 30 seconds...
Old Sep 27, 2013, 11:53 PM
tkallev's Avatar
USA, IL, Wheeling
Joined Jan 2003
[QUOTE=GarryOgilvie;26220914]tkallev, is that your opinion or your experience with that line of motors?/QUOTE]
3 for 3 ... crap.
There is quality product from China, it just isn't sold by Hobby King.
Mini-Review New Turnigy Sk3 Series Outrunners, Turnigy's "High end" Outrunner daign Multirotor Talk 22 Sep 12, 2014 04:42 AM
Discussion Turnigy Aerodrive SK3 OR NTM Prop Drive Series OR easy match series sebbe Power Systems 10 Dec 23, 2012 02:33 PM
Discussion Turnigy D or SK3 series? jtaylor996 Power Systems 2 Nov 29, 2012 09:25 PM
For Sale Turnigy Helidrive SK3 Competition Series 4 NIB blawren Aircraft - Electric - Helis (FS/W) 0 Nov 21, 2012 10:51 AM
For Sale Turnigy G60 and Turnigy SK3 4250 fnlrun Aircraft - Electric - Power Systems (FS/W) 3 May 21, 2012 12:20 PM
